Author Topic: Lt 15 set lever  (Read 254 times)
Offline Escavader
  • Sawmill/Planermill operator since1984
Lt 15 set lever
« on: January 08, 2019, 05:39:29 PM »
 Having an issue with handle not wanting to release to lock in.saw hasnt been used much .mabey im doing it wrong.releasing the lever and find the hole.
  I think something is catching inside the mechanism or something. Just asking if anyones had an issue.
Alan Bickford
Hammond lumber company/Yates American A20 planer with dbl profilers Newman feed table multiple saw trimmer destacker automatic stacking machine Baker resaw MS log corner machine  4 large capacity Nyles dehumidification kilns JCB 8000 lb forklifts woodmizer lt 15 and mp100 and blower
Offline Brad_bb
    • My timberframe blog
Re: Lt 15 set lever
« Reply #1 on: January 08, 2019, 05:55:40 PM »
If you're talking about the up down crank?  It's got a spring loaded pin that enters the detent on the wheel?
or are you talking about the handle to crank the head forwards?
Or are you talking about the lever to engage the blade drive?
Offline Escavader
Re: Lt 15 set lever
« Reply #2 on: January 08, 2019, 06:17:30 PM »
Up and down crank .its like its sticking and springs not pushing it in i have to mess with it,even when its over the hole
Alan Bickford
Offline Resonator
  • Board Footage and Cord Woodage
Re: Lt 15 set lever
« Reply #3 on: January 08, 2019, 06:27:31 PM »
Check if its frozen, I put anti-seize inside the crank on my LT28 to prevent this.
Offline Southside
Re: Lt 15 set lever
« Reply #4 on: January 08, 2019, 06:34:23 PM »
Put the penetrating oil to it then keep a good dose of never-sieze on the insides of the assembly.  My edger has the same set up and it did the same thing, after I got the grease to it I have never had an issue again.
Offline Brad_bb
Re: Lt 15 set lever
« Reply #5 on: January 08, 2019, 07:16:20 PM »
Use some BLUECREEPER!  Sponsor on this website, and tested by many many of the members on here.  I have at least a dozen bottles in various locations and tool boxes.  Awesome stuff!
Bluecreeper Lubricants, penetrant and degreaser - Bluecreeper Lubricants, Penetrants and Degreasers
TJ lever handles
Started by mf40diesel on Forestry and Logging
Last post March 12, 2017, 09:22:32 PM
by mf40diesel
230 Transfercase Lever
Started by larry1 on Forestry and Logging
Last post August 21, 2015, 08:45:40 PM
by Mooseknuckle
Skidding Lever
Started by 4x4American on Forestry and Logging
Last post October 03, 2015, 11:28:49 PM
by Pine Ridge
question
hydraulic lever problem
Started by goatman on Sawmills and Milling
Last post August 13, 2018, 09:43:25 PM
by PAmizerman
