Author Topic: Vacuum Kiln Tour  (Read 609 times)
Offline canadianwoodworks
Vacuum Kiln Tour
« on: January 08, 2019, 09:33:24 PM »
Hello fellow members,
I have been operating a DX Haibo RF Vacuum kiln for 2 solid years. With loads taking 4 to 18 days, I've been able to run a lot of lumber through this kiln and learn a lot!
This unit can fit 2800 bdft of lumber, I typically dry live edge lumber because of this my loads are typically 1300 to 2000 bdft, depending on the sizes and curves of the slabs.
The cost is about $1500 a month to operate, I am in canada and heat a 50x30 shop/office space with the excess heat.
Most commonly dried lumber
12/4 Walnut - 9-11 days (4-6 month air dry for colour)
5/4 Walnut - 6-7 days (1 month air dry)
12/4 Ash - 8-10 days (Zero Air Dry)
8/4 Soft Maple - 6-7 days (Zero Air Dry)
4/4 Tamarak - 4 days (Zero Air Dry)
Unique dried lumber
9'' thick, 15' long Okan from Africa
11'' thick 48-50'' diameter White Oak cookies
Thanks for watching, any questions please ask!
Offline bkaimwood
  • Life's too short to sweat the small stuff
Re: Vacuum Kiln Tour
« Reply #1 on: January 13, 2019, 06:26:43 PM »
Thanks for sharing Canadianwoodworks. Great video, very informative. Love the press and its impact on flat slabs. The obvious 2 questions I canít believe nobodyís asked...where do you get one and how much do they cost? Did a quick google search on the manufacturer/model and came up with zippo... Mostly just curious at this point...
bk
« Reply #2 on: January 20, 2019, 10:53:47 PM »
Hi,
Hfwoodworking dot come is where to go, this is a medium sized one at about $50,000 usd
I actually bought it through Alibaba
Thanks for watching
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #3 on: January 22, 2019, 04:58:45 PM »
I have been watching your channel.
What power requirements are needed to operate that vacuum kiln you're running?
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline schwanee
  • Urban sawmill
    • Urban Timber Harvest
« Reply #4 on: March 03, 2019, 05:54:34 PM »
Tha is for the info!  I have a question for you if you donít mind. Does your kiln have hot water plumbed to it, or do you have some sort of recirculating process? Any problem with freezing up there?
question
DIY Vacuum Kiln . . . HELP!
Started by MemphisLogger on Drying and Processing
Last post March 08, 2005, 10:52:53 PM
by serg
Looking at a used vacuum kiln
Started by Sawyerfortyish on Drying and Processing
Last post October 04, 2013, 11:25:39 AM
by old3dogg
Wet Vacuum Kiln
Started by Ole CB on Drying and Processing
Last post April 17, 2011, 08:52:38 PM
by jimF
Vacuum Kiln
Started by shopteacher on Drying and Processing
Last post January 12, 2005, 05:47:21 PM
by Tom_Averwater
