Author Topic: New member here and seeking some advise  (Read 1208 times)
Offline Inaotherlife
Re: New member here and seeking some advise
« Reply #20 on: January 09, 2019, 05:10:20 PM »
I'd just buy a more expensive saw to start with before I went buying a clutch hub/rim sprocket and an expensive new bar for a brand new saw.
Also, if you're wife is going to run a saw she might appreciate the 310 or 352 over a 40cc saw.
Offline samandothers
« Reply #21 on: January 09, 2019, 05:41:51 PM »
Good evening and welcome!
I have two Echo's at CS341 and a CS620.  I Like the Echos  they start easy and run well.   I have a MS250 (home owner saw) Sthil I had before the other two.  I was my only saw for many years and handled all I needed.  The small saw is handy and I enjoy using it around the mill and for limbs.  I have not ran the CS620 much but it sure helped me put several trees down quickly.  The CS620 is pretty heavy with the 24 inch bar.  I look forward to gaining more experience with it.
My brother has a CS400 and likes it.  I seems to be a good size and not too heavy.  If I was starting over I might get the CS590 or maybe CS620 with a 20" bar and the CS400 with a 16".  Maybe you can find an Echo dealer near you having a 'Dealer Day' and get a large percentage off your saws.   I got 20% off the CS620 back early November and that helped a bunch!
Good luck with your selection!  Thank you for your service!
Offline John Mc
« Reply #22 on: January 09, 2019, 10:12:43 PM »
Welcome COLRJbrinkman,
My advice is 60cc maximum displacement saw, 20" maximum bar/chain. Second saw 40-50cc with 16" max.
24" bars dull way too many chains in your size of trees.
I agree with Holmentree. I'd start with the 60cc saw. I would not put a 24" bar on it. Most 60cc saws seem to balance better with a 20" bar. It's just easier to maneuver and deal with, and less tiring to use. You can always get a 24" bar down the road, if you really want. Since most of the trees I cut are under 16", my 60cc saw wears a 16" bar most of the time. I'd rather have the lighter weight and better maneuverability of that shorter bar, even if it means I occasionally have to cut from two sides to get all the way through a tree.
I do own a 20" bar for my 60cc saw, but I only bother to put it on if I know I'm going to be making a large number of 16-20" cuts that day (for example cutting up a bunch of 18" logs into firewood). If there are a lot of cuts to make over 20", I drop back to the 16" saw, since I'm going to have to cut from both sides anyway. With the 16" bar, It's not too cumbersome to use it for limbing as well (though if I have a lot of limbing to do, I'll switch to my smaller, lighter saw).
Online lxskllr
  • dummy with saw
« Reply #23 on: January 09, 2019, 10:41:33 PM »
 As for the smaller saw, sounds like a 40cc is better than a 30cc, so Ill have to relook
Don't let me talk you out of a small saw if *you* think a smaller one would be better. My reasoning is 20cc increments allow overlap at both ends of the spectrum. You can pick your primary saw of the job, and use it for everything. 60cc will get you up to 80cc work for occasional use, and also isn't completely ridiculous for 40cc use. Likewise, a 40cc saw is pretty light by my standards, but will still get you up to occasional 60cc work, and is much nicer to carry. With the shorter bar, it's also *much* nicer to sharpen. Seems to take forever to get around a 24" chain with a file. When I do my 16", it's "Hey! I'm done already!"  :^D
That said, I've got a 25cc saw on order. I'm still pretty close to my 20cc spread, so I'm not a liar, but I don't exactly need it either. It's just a nifty little unit, and I treat this stuff as my recreation, so it isn't merely a "business expense". If it were, I'd just use what I had. 40cc-60cc-80cc. I don't see me ever needing an 80cc saw, but the slot's open if I do. Wasn't that long ago I didn't see me needing a chainsaw at all. No telling what the future will bring.
Offline COLRJBrinkman
  • Retired Army Colonel
« Reply #24 on: January 09, 2019, 10:46:46 PM »
She's on chemo so she'll only be helping loading. However, she will want to use a smaller one in the future, hence my interest in a MS170/180 series or CS-310. I am rebuilding my Poulan Wild Thing which is a 40cc, never was a fan of it hopefully after the rebuild it will be better as a third backup saw.
Poulan P4018WTL being rebuilt and modded
Ryobi electric pole trimmer
Echo CS-352 with 16 bar
Echo CS-590 with 20 PowerMatch bar upgrade and rim sprocket upgrade
Offline H Ray G
« Reply #25 on: January 09, 2019, 10:54:20 PM »
I have an Echo 352 with the 16 in bar and like the way it handles. I mix the oil with premium fuel and it starts and runs good remember that in cold weather you have a cap/rubber dcisc to move under the air cleaner cover.
« Reply #26 on: January 09, 2019, 11:28:14 PM »
The next Echo dealer event where I will be buying my saw(s) is April.  I can get a 10% mil discount at my local dealer here, but they won't be the dealer Ill be dealing with at the wooded property.  Yes I handled a 620 with a 24" and it is a hefty one.  I'm almost 64 and 5'5" but pretty healthy and YES I don't want to lug round a heavy saw all day.  I can get the 590 for 359 then add 65 for the rim sprocket and 55 for a Powermatch bar is still cheaper than getting a 620 for 514 with my discount.  I think the 310/400 might be the small saw as I think my wife can field the 310 all day once she feels better.
Offline doc henderson
« Reply #27 on: January 09, 2019, 11:30:38 PM »
Hello Colonel.  Sorry to hear your wife is sick.  Nice that you guys work together.  You prob. have all the advice you need and more.  If you wanted to buy 1 saw, and I am a Stihl guy,  a farm boss is an option.  Many firewood guys cutting for them selves only own that one saw.  used to be a 290 now a 271 I think.  Or the equiv. in another good brand, so you can get parts and service.  My Amish guys are so good they can often Dx. over the phone, and once I was in the middle of getting several trees and had an oiler and a fuel line crack failure.  My guy worked through his lunch to fix it.  Having a good dealer is important.  Are you near Ks.?
« Reply #28 on: January 10, 2019, 12:33:33 AM »
I like the idea of having a longer bar that would cut all the way through.
That's a pretty big saw and having to reach over, climb over, or walk around to the other side to make every cut would make cutting that up seem too much like work.
Just lay it up there and let the saw do the work.
It may cut a bit slower but it'll get there. And with the time and energy you'd waste reaching over with that heavy saw or going to the other side to finish it off, you should come out ahead with the longer bar.
But I also would like the extra power of the 620P for pulling that longer chain.
And the aluminum handlebar to give it a more solid feel.
I'd probably buy the 590 though. And just run it as is. $359 would leave more room in your budget for a nicer small saw that you'd probably end up using a lot more than you think you would. I figure on letting bars and sprockets getting a little wear on them before I'd spring for new ones.
Funny, because that's how it worked for me. Out of three brand new saws that I bought, all three Echo's, I spent by far the least on the big one. A CS-490, with a too long 20" bar, that I got at a super sale price. Then my small rear handle saw, the 361P, that I also got at 20% off, but still a chunk more than the 490. Then I spent the most on a little top handle, the 2511T, that I only got 5% off on.
The CS-361P, for me, by far sees the most use. It's a great little saw that's both lighter and more powerful than a 310 or 352. But a bit pricier too.
If I'd have had a budget, I went well over it. But mainly I wanted the versatilty of the three different saws and not spend too much on any single one.
PS, I actually like that too long 20" bar and chain on the 50cc 490. I'm not trying to win any races with it. I just wanted something that would get through some bigger stuff in one wack.
Offline hedgerow
« Reply #29 on: January 10, 2019, 09:16:08 AM »
Sorry to hear about your wife. For years I cut a ton of firewood with one saw a 038 Stihl. Sounds like you have a echo dealer you like and that's half the battle. I would look at a CS-620 it has the compression release us old guys like and a 60 cc saw is a good all round size saw. A 20 inch bar will cut most trees you could throw a 24 on if needed once an a while. Saw like you already have a smaller saw once you get it going again.
« Reply #30 on: January 16, 2019, 08:13:02 PM »
I was at my local Deere dealer today ordering a part for my Deere 522 snowblower, which they had to order, but I also bought two Echos. A Cs-352 with 16 bar and the CS-590 with 20 PowerMatch bar upgrade as well as the rim sprocket upgrade. Will pick them up in a week all tuned and ready to work.
« Reply #31 on: January 17, 2019, 08:09:25 AM »
Sounds like you got some great equipment and are ready to work!  Congrats.
Offline hedgerow
« Reply #32 on: January 17, 2019, 11:11:28 AM »
I think you will enjoy the Echo's. I hope this next storm run's out of gas before it hits everyone. We got around 8 inch's last weekend and about a inch last night. Sounds like the temp is going to be dropping for several days. I better throw some more hedge in the Garn.
Offline Allar
  • Firewood Warrior!
« Reply #33 on: January 17, 2019, 12:53:00 PM »
It's alot easier and cheaper to buy a 50cc all-around chainsaw than buying a chainsaw for every different task. 8)
Since you into Echo, why not buy Echo- cs501P.
Firewood & Chainsaw videos: Firewood Warrior - YouTube
« Reply #34 on: January 17, 2019, 06:19:40 PM »
Congrats on the purchase and sounds like a great combo!
« Reply #35 on: January 17, 2019, 10:19:09 PM »
That's terrific. I hope you enjoy using them.
« Reply #36 on: January 17, 2019, 10:22:19 PM »
That's crazy!
Molder/planer seeking advise
Started by buck65 on Sawmills and Milling
Last post March 13, 2015, 07:33:03 PM
by buck65
Novice Land Owner Seeking Advise
Started by pellethead on General Board
Last post July 13, 2001, 06:45:23 AM
by Jeff
Advise appreciated. Eager rookie seeking to avoid unnecessary growing pains.
Started by k9klf on Sawmills and Milling
Last post October 28, 2014, 09:41:14 PM
by FarmingSawyer
New member seeking sawmill
Started by Jeff on Wanted
Last post July 20, 2007, 12:35:47 PM
by WAGZ
