Author Topic: drag sharpener fix  (Read 462 times)
Offline pineywoods
drag sharpener fix
« on: January 10, 2019, 08:58:27 AM »
My old wm drag sharpener quit. Can't really complain, the thing is 24 years old, doesn't ow me much. The control circuit board smoked. Parts are unobtainum. Looked like time for a new one, but my scottish ancestry demanded at least a try at fixin. A search on ebay turned up a 20 amp dc motor speed control for $7.50 Deleted the push buttons for start and stop, replaced with a spst toggle switch. Removed the old circuit board, and mounted the new speed controller in it's place. 4 wires to the new board and I'm ready to go. Ok, I lost the automatic shutoff, but never used that anyway. Works like a champ
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: drag sharpener fix
« Reply #1 on: January 10, 2019, 09:30:48 AM »
I have never questioned nor doubted your ingenuity my Friend.  Nice fix !!  ;D
Tell Nelda "Hi" for us.  :)
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #2 on: January 10, 2019, 09:48:39 AM »
Because of the fact that I have an old drag sharpener I'll keep this in mind.
1992 LT40HD
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: January 10, 2019, 10:16:31 AM »
And for those of you that do not know, I was absolutely not referring to Nelda as "an old drag".
Seen here with PatD at Nelda and pineywood's home.
Offline Darrel
« Reply #4 on: January 10, 2019, 10:30:52 AM »
But still, I'm sure that she does her share of sharpening. (Pineywoods might be kinda dull without her smile.)  :)
1992 LT40HD
Offline barbender
« Reply #5 on: January 10, 2019, 01:01:55 PM »
Piney, I wished you lived next door to me- for many reasons, not the least of which is all the things you find a way to fix things!👍
Offline pineywoods
« Reply #6 on: January 10, 2019, 08:52:59 PM »
I long ago got tired of the 3/8 thick 7 inch grinder disks used on the old drag sharpener. I use the 4 1/2 wheels off a hand held grinder. $.99 so I am cheap. Ok, the hole in the center is a bit larger, but a quick and dirty bushing fixes that. The smaller disk is only 1/4 inch thick, requiring a different sharpening procedure of multiple passes. A still un-resolved problem is the coolant pump. The original went west I don't remember how many years ago so I switched to a submersible aquarium pump. The permanent magnets in the motor attracts iron filings in the coolant, clogging things up. Couple of big magnets in the tank helps, but not quite enough. I use water with a little diesel fuel mixed in for coolant. Yeah water and diesel fuel WILL mix if you keep it stirred.
Offline donbj
« Reply #7 on: January 12, 2019, 11:54:43 PM »
Awesome! Thanks for this. I have one of these sharpeners as well but fortunately it's still going strong. Does the feed rate switch still work or do you use the one in the new controller?
Woodmizer LT40HDG24
Offline pineywoods
« Reply #8 on: January 13, 2019, 04:33:47 PM »
The old speed pot no longer served any purpose, so it went to the parts bin. New controller came with it's own pot, mounted in the hole vacated by the original.
WM Drag sharpener.
Started by tacks Y on Sawmills and Milling
Last post June 19, 2016, 03:45:14 PM
by woodmills1
Old WM Drag Sharpener /Resurrection
Started by Mt406 on Sawmills and Milling
Last post January 29, 2018, 08:29:02 AM
by Mt406
WM Drag sharpener (sold)
Started by Stephen1 on For Sale
Last post October 20, 2018, 12:47:59 PM
by LeeB
Rebuilt drag type sharpener
Started by pineywoods on Sawmills and Milling
Last post December 31, 2014, 10:18:44 AM
by LeeB
