Author Topic: Making reworked bar  (Read 343 times)
Offline TACOMATODD
Making reworked bar
« on: January 11, 2019, 04:56:21 AM »
I want to take an existing 0.063x20 saw bar and cut it down to about 16". The shortest large mount bar that I have found for my Husky so far has been 20". Considering the machine work on doing such a thing seems pretty straight forward, what's you folks opinions? It seems that the most difficult part would be the bar oil hole. I could go to a smaller gauge, but I REALLY like the way the 0.063 cuts.
Trying harder everyday
Offline mike_belben
  • Pulp Friction
Re: Making reworked bar
« Reply #1 on: January 11, 2019, 06:56:50 AM »
I have a 16" stihl 063 bar on my 372xp for bucking piled firewood. Keeps me from stabbing into logs i dont intend to cut, and not many cutters to sharpen. Cheaper chains too.
Just make bushings for the bar studs. I used trimmed off pieces from a coil spring i ground down a bit by hand. Works perfect.
Revelation 3:20
Offline Air Lad
  • Onwards and upwards
« Reply #2 on: January 24, 2019, 06:24:21 AM »
I wondered about that when I saw some bent long bars that may be able to be cut down and used as shorter ones. Drilling an oil hole I have done a couple of times. Sharp and slow. Stihl bars are open at the base. Should be able to be cut to the same shape?
Dunno?
Watching with interest
Cheers
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline HolmenTree
« Reply #3 on: January 24, 2019, 08:39:19 AM »
I made a 13" bar out of a 15" bar for a 550XP.
Only used my 4.5" angle grinder, bench grinder , file and drill press.
Here's a pic of the mod about a half ways in.
Maple syrup any one on here making it making it
Started by jocco on Forestry and Logging
Last post April 07, 2014, 07:54:22 PM
by Ed_K
Making do.
Last post February 23, 2017, 11:40:57 PM
by kensfarm
Making OSB
Started by Raider Bill on General Board
Last post May 12, 2018, 01:41:20 PM
by scsmith42
Making do when you got to . . .
Started by TexasTimbers on Sawmills and Milling
Last post March 12, 2007, 01:13:53 AM
by Brucer
