Author Topic: Central boiler mystery  (Read 702 times)
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« on: January 12, 2019, 10:10:08 AM »
My furnace is now 13 1/2 years old.
I check the water level virtually every day.
Yesterday morning at 8 AM all was OK and I didnt stoke it because there was a huge bed of coals that I wanted to burn down so didnt load until 10 AM or so.
Everything OK at that point.
Wife hosed off the garage floor due to a diet coke spill, and the hose was hooked up to the domestic hot water faucet.
We went to pick up grand kids at about 2 PM and checked the level then and it only showed half way on the site tube.
It has been cold out so I thought the water in the tube was partly frozen.
Checked again at 8 PM when we got home and took the tube off and it was clear, still halfway down..
In a panic I filled to the proper level and all night long wondered what had happened.
No sign of boiling over while we were home.
I cant believe that boiling would have used that much water as I have boiled it several times over the years and only had a minimal drop in the water level.
Everything is OK this morning.
This is head scratching to me.
Any thoughts?
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Southside
Re: Central boiler mystery
« Reply #1 on: January 12, 2019, 10:19:57 AM »
I am not familiar with how your unit works but can you not plumb in a feed in valve so the water would always be at the right level?  Years back I had my OWB set up that way.
« Reply #2 on: January 13, 2019, 10:07:12 AM »
Would you have to install some sort of a float system?
I have to add some water about once a month, I attribute this to evaporation.
There are no leaks evident.
LT40SHDD51
Kubota 900 RTV
Offline Southside
« Reply #3 on: January 13, 2019, 10:18:56 AM »
Mine was based on keeping a constant pressure in the system. It was pretty low.
Offline DDW_OR
« Reply #4 on: January 13, 2019, 01:59:22 PM »
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #5 on: January 14, 2019, 05:16:37 AM »
With open vented pipe there would be no pressure in a CB system, it would overflow, correct?
Anyway, the sight tube probably only shows the top 10-20 gallons I'd guess? In other words it's positioned up high, not down to the bottom of the tank.
But you may have an intermittent leak at a fitting, pump flange or somewhere. Give everything a good look over. Some leaks only drip with a temp change.
HeatMaster dealer support in VA.
GS100.
Offline thecfarm
« Reply #6 on: January 14, 2019, 06:46:26 AM »
I had a leak on the backside of the pex pipe. I bet I run my hand up and down on that pipe 20 times before I felt it was wet. More than a week. I think it was a very small drip and it was evaporating. Than it got worse and I could feel it.
« Reply #7 on: January 16, 2019, 08:55:08 AM »
I think with the open vent on the CB the pressure would have to be so low as to not keep the level up without overfilling.
I think I had a weeping leak on a line last year and it must have evaporated so quickly that I couldn't find it.
Changed the water last summer and tightened everything and now seems to be OK.
Water level has been OK since the problem.
LT40SHDD51
Kubota 900 RTV
Offline maple flats
  • Life is what you make it!
« Reply #8 on: January 16, 2019, 12:19:19 PM »
Different brand, but I was an OWB dealer for 12 years. Non pressurized like yours. They can boil off that fast, especially if your wife drew enough hot water to kick the draft fan on and the aquastat for the fan stuck on. Just keep an eye on that. Over the years I changed several aquastats for that reason. Changing is simple if yours is like ours were. The temp probe was in a brass well, you just shut off the power, remove the old, and be sure to use the silver grease on the sensor bulb when you install a new one.
My guess is that was the cause. Even a good bank of coals can boil a lot of water if the fan sticks on.
« Reply #9 on: January 17, 2019, 08:27:09 AM »
No fan on the older classic.
LT40SHDD51
Kubota 900 RTV
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #10 on: January 17, 2019, 09:24:32 AM »
I don't think any Classic has a fan. If they did, you'd have to put a grate on the stack to keep chunks of wood from going up.  :D
Offline Rebarb
« Reply #11 on: January 17, 2019, 09:49:37 PM »
Hmmm can't wrap my head around this.
I've had a 5036 classic for years and maybe add a gallon or 2 a year, if that.
If not a leak, possibly damper door stuck open " rare " .
Is your temp range the recommended 175-185 ?
My water level has always fluctuated depending on box temps but always in the circle.
Anyone with a new Central boiler Classic Edge Titanium series boiler yet?
Started by Logging logginglogging on Firewood and Wood Heating
Last post January 08, 2019, 09:07:17 AM
by panolo
Done with Central Boiler ...Boiler recomendations please
Last post January 29, 2019, 07:52:18 PM
by 1countryboy
central boiler
Started by coxy on Firewood and Wood Heating
Last post February 05, 2013, 05:09:32 AM
by albirk
Central boiler fan
Started by talldog on Firewood and Wood Heating
Last post March 03, 2013, 05:15:44 PM
by hockeyguy
