Tally-I/O
Author Topic: Fan speed controller  (Read 850 times)
Online thecfarm
Re: Fan speed controller
« Reply #20 on: January 17, 2019, 08:41:07 AM »
That is why he is asking,alot of wasted heat.
I know the top loaders are diffeant. On my Heatmor the smokes goes up in the front,into a 4x6 inch piece of rectangle tubing,goes the full lenth of the OWB and than goes out the pipe.
Offline Busysawyer
« Reply #21 on: January 17, 2019, 09:31:31 AM »
Thank you for all the suggestions. I think the dart fan controller will probably be the best long term solution. It will allow me to easily run the fan off/on or anywhere in between. This boiler isn't designed for efficiency. It is made for ease of loading with a machine, long burn times and big heat loads. In a perfect world I'd feed it nothing but 5ft long 20in diameter green red oak logs. 20f outside and heating my house , kiln, barn and domestic hot water I can easily get two days between loads. On days where I have more time to mess with it I'd like to start working through my mountain of mill scraps. I'm hoping to get 24 hours of burn time with scraps or better. I really think if I can slow the flow of air by switching the fan off I can achieve that.
Even a blind squirrel finds a nut every once in awhile
Offline ButchC
« Reply #22 on: January 17, 2019, 11:17:57 AM »
Which ever way you go you will definitely see a reduction in wood usage once you get things dialed in. Good luck with it.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline hedgerow
« Reply #23 on: January 17, 2019, 11:20:55 AM »
You will find that in the long haul the money spent on the Dart controller will be well spent.
pwm controller
Started by kelLOGg on Sawmills and Milling
Last post August 06, 2006, 10:47:21 PM
by pineywoods
c5d winch controller
Started by treefarmer rick on Forestry and Logging
Last post January 02, 2013, 11:27:39 PM
by thecfarm
E Classic controller
Started by Dyerbrk on Firewood and Wood Heating
Last post March 28, 2011, 09:13:15 PM
by Dyerbrk
Kiln Controller
Started by shopteacher on Drying and Processing
Last post May 14, 2004, 08:40:29 AM
by SawDust_Studios
