Author Topic: Hot water Plate heat exchangers  (Read 283 times)
Offline Viperman
« on: January 17, 2019, 11:24:58 PM »
Was wondering when hooking up a plate heat exchanger
How many hook it up on the hot water side?
Do you use a mixing valve?
If hooked up on the cold water side are any of you using a 10 or 20 plate
and what temperature is your water on the hot side?
Offline E Yoder
  • Heating with a HeatMaster GS100
Re: Hot water Plate heat exchangers
« Reply #1 on: January 18, 2019, 05:55:49 AM »
I always hook it up so it preheats the water entering the water heater. Less fluctuating temps and less need for mixing valve (I almost never use them). With doing the outlet side if the stove goes cold the electric can't back it up without stopping the pump on the outdoor furnace, otherwise the heat goes back to the stove.
Temp drop through the tank varies depending on volume of usage, usually less than 5 degrees, I've measured 135 at my sink. That varies a bit depending on stove temp and flow rate to the house.
A 10 plate might clog with grit more easily. ? I use 3x8" 30 plate ones.
All that said I know people do the outlet side and it works fine most of the time.
HeatMaster dealer support in VA.
GS100.
Offline ButchC
« Reply #2 on: January 18, 2019, 08:05:20 AM »
Pluses and minuses to either location but IMO the inlet side has far less potential issues. Personally I would never consider heating domestic water in a manner that can be dangerous to the unknowing who stick their body parts in harms way. Blending valves do not work perfectly but are cheap and and easy to install insurance.  Consider that the very top end of safe domestic hot water is around 130 and you have the potential to be very near loop temps.
We started out with a side arm and it couldn't keep up so I added a plate exchanger to the inlet side. We now have the best of both systems. A lot of capacity from the plate and the water heater is kept to temp by the side arm when there is no usage. Our water heater is turned off and just a holding tank.
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline hedgerow
« Reply #3 on: January 18, 2019, 02:14:18 PM »
Welcome Viperman
I run a 20 plate I do run a pump on the domestic side also I pull out of what would be the drain on the tank threw the exchanger and back in the hot side. I have a thermal well I have set up on the hot water heater and run a Ranco that turns that pump and the two pumps out in the Garn barn on and off to maintain temp. We like our water hot no small kids around so in the winter when the Garn running temp is higher I kept the domestic set at 130 in the summer the Garn temp is run down lower the domestic is set at 110. If I get lazy in the summer and don't fire the Garn quick enough the gas burner will kick on.
Great tool to clean Heat Exchangers on Central Boiler
Started by Bob Lentz on Firewood and Wood Heating
Last post March 13, 2015, 05:44:11 PM
by Bob Lentz
On demand domestic hot water using water to water heat exchanger?
Started by Fether Hardwoods on Firewood and Wood Heating
Last post July 26, 2015, 09:50:11 PM
by r.man
moved
MOVED: A little off topic. Water to water heat exchanger.
Started by chet on Forestry and Logging
Last post February 08, 2015, 11:30:45 PM
by chet
Heat Exchanger Wanted - Water to Water
Started by DR_Buck on Wanted
Last post October 21, 2009, 02:48:20 PM
by DR_Buck
