Author Topic: Got my Woodmizer MP360.......Finally...  (Read 509 times)
Offline Percy
  • Resident trouble maker
« on: January 18, 2019, 11:27:31 AM »
Got the unit after nearly an 8 month wait.....Canada's electrical codes being the major hurdle(allthough there are many 360's in Canada under the Logosol brand that meet Canadian electrical codes).
Got to making chips finally. First job was "channel siding"
It had to be 7/8 inch thick and rough on the exposed side. Ran all the 2500 board feet of 1x8x8 through with just the top head spinning, thickness planing to 7/8. Then ran it thru again profiling as seen above....lots of work. I need to build a more user friendly input and output system to save on the back....Bending over was the motiff of the day.
If my resaw was not down for repairs, it would have been much quicker to size with it.
My 50kw genset runs like a top. I had to reconfigure it because Woodmizer wasn't able to supply a 460 volt unit....I am learning lots about three phase.....and regulations......Did it all myself.....lots of reading...
Here it is on the "profiling" pass
The machine works quite well except for the up/down indicator...Its an anolog counter{like the numbers in an old speedometer)and is pretty much
useless. After a hangup you cant find your mark. The wide profile channel was done with the top head and needed to be dangerously close to the steel fence. I trusted the indicator only once with near catastrophic results. Gary from woodmizer said to go below the intended spot and come upto it....like tuning a guitar......Still useless...can be about 1/4 inch out......I think I may attach a digital caliper to  the appropriate stationary and moveable portions and just turn it on when I need it...Any suggestions???
Offline Southside
Re: Got my Woodmizer MP360.......Finally...
« Reply #1 on: January 18, 2019, 02:36:24 PM »
I have one of these Digital planer gauge   on my 4000. Works perfectly, I set my zero at 3/4" so I reference from there. Double checking with a micrometer it stays within .001" all the time.  If I get a snag I just back off enough to get the issue fixed and then bring it back to zero, don't have to waste the work piece that way.
Offline Percy
« Reply #2 on: January 18, 2019, 09:45:28 PM »
Thanks. This is the type of unit Im looking for...Unfortunatly they only ship to US addresses. There are similar units available so I will hunt around.
Edit: Found the same unit from a Canadian supplier so we are all good.. Thanks again
Shed For Woodmizer Finally (pics)
Started by woodweasel on Sawmills and Milling
Last post February 07, 2015, 08:34:03 PM
by woodweasel
Woodmizer hydraulic mill and Woodmizer Edger
Started by Keith Edge on For Sale
Last post December 22, 2008, 08:11:51 AM
by Keith Edge
finally its here
Started by snowstorm on Forestry and Logging
Last post April 18, 2015, 12:12:03 PM
by snowstorm
Tom is finally here
Started by Fla._Deadheader on General Board
Last post February 23, 2003, 08:26:39 PM
by CHARLIE
