Author Topic: Rustic Ranch covered deck  (Read 783 times)
Offline Racerx94
« on: January 18, 2019, 04:08:06 PM »
Hi there all, Mark here been lurking for a few months. Y all have lots of great info and advice here! The better half and I are wanting to do a covered deck with some timber frame elements incorporated. The whole deck needs to be replaced it faces south and just bakes in the summer here in Missouri. We have been searching for timber framed covered decks online, but can not really find anything we like. Just wondering if any of you kind folks have any ideas and our pics o f covered decks. Thanks all! Hopefully I can attach a pic of the back of our house.
Offline samandothers
Re: Rustic Ranch covered deck
« Reply #1 on: January 18, 2019, 05:42:26 PM »
Sorry no covered deck, but wanted to say welcome!
Online Don P
    • Calculator Index
« Reply #2 on: January 18, 2019, 09:11:55 PM »
If the length of the deck is equal or shorter than the house is wide then it would be pretty easy to T off a gabled porch roof with the same pitch as the house.
Offline Racerx94
« Reply #3 on: January 19, 2019, 07:47:57 AM »
The deck is 18ft x 20ft wide. 18ft is off the back of the house and house is 32ft wide. Yes T off with gable end roof is what we would like to do. Just wondering if anyone on here has done this or has pics or drawings?
Online Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #4 on: January 19, 2019, 09:12:12 AM »
I have designed two covered decks and roofs.
One is this:
and here it is after erected:
I did another one with a lower roof pitch but I don't have those pictures in my gallery right now.
One thing to consider is that the roof system should be supported by posts next to the house walls, not by the house itself. Shrinkage of plates and beams will effect the roof system and it should be planned on and you need to allow it to happen and not effect the house roof.
Good luck with your project.
Jim Rogers
Offline Racerx94
« Reply #5 on: January 19, 2019, 09:41:54 AM »
Thanks Jim! We like something like that. Going to have to be a lower pitch on the roof though, also would like to tie it in to existing roof, but not supported by the roof. What size columns are those and about how much shrinkage would they be? Probably be using Douglas Fir.
Offline Hooterspfld
  • I'm a sucker for a chainsaw!
« Reply #6 on: January 20, 2019, 01:47:11 PM »
I would think you could mitigate the shrinkage of the post using some sort of adjustable base. Kinda like this:
Online Don P
    • Calculator Index
« Reply #7 on: January 20, 2019, 03:18:16 PM »
The posts won't shrink appreciably in length. The plate beam under the rafters will, in the neighborhood of 1/4", the rafters will, maybe half that much. I doubt it is enough to worry about. You can overhang the ridgebeam of the porch over onto the house roof and stick frame that area then frame a sided gable over the existing wall to cover that over roof area. It would be a good idea to have an engineer check out the loading and support there.
Offline Racerx94
« Reply #8 on: January 21, 2019, 06:28:19 AM »
Thank you Hooterspfld good idea. Also thank you Don P Yes that is kinda what I was thinking.
Offline OffGrid973
  • Off Grid
« Reply #9 on: February 12, 2019, 10:14:27 PM »
Nice build, getting inspired.  How high can you go with the concrete before it starts to lose side to side rigidity? That front right in the pic almost looks like it could snap in half with a full crane kick (from a rhino) but in theory, is that ever a concern even on scaled down projects?
Your Fellow Woodworker,
- Off Grid
Online Don P
    • Calculator Index
« Reply #10 on: February 12, 2019, 10:37:31 PM »
Good eye. Piers are an engineered solution under braced walls, porches and decks are kind of a grey area but that is tightening up. That would be better on a continuous foundation.
Hemlock Deck - & covered front porch
Started by Snag on General Board
Last post March 16, 2006, 06:26:11 PM
by SwampDonkey
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Back on the ranch again
Started by Nomad on Sawmills and Milling
Last post January 19, 2013, 05:55:59 AM
by customsawyer
HUSKY 455 ranch
Started by wolverine on Chainsaws
Last post February 10, 2009, 05:17:08 AM
by ladylake
