Author Topic: 73Int.H30 loader  (Read 588 times)
Offline Vautour
73Int.H30 loader
« on: January 20, 2019, 01:51:43 PM »
............ hi guys.bought this IH30 two years ago that had a seized up 100HP gas job.. and installed a130HP John Deer marine engine in it's place...lots a power and very fuel efficient... my power steering is on the weak side... any suggesting ???
the Gospel is WANTED by the people in 52 Countries but made illegal by their Government
Offline thecfarm
Re: 73Int.H30 loader
« Reply #1 on: January 20, 2019, 05:43:29 PM »
Yea,have it trucked to Chesterville,Maine. :D   :D
Offline Bruno of NH
« Reply #2 on: January 20, 2019, 05:48:20 PM »
That will push some snow
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,Mahindra 3540 cab tractor loader F350 4x4 dump and lot of contracting tools
Offline Vautour
« Reply #3 on: January 20, 2019, 06:03:28 PM »
   Thecfarm.... haha  good one...the problem is I don't know where Chesterville is??... besides....i'll be needing this after you stop sending this snow storm north of your boarder...(don't believe this was part of the new trade deal between US and Canada) :D ...  should have written (first Dodge Ram) in the last pics
Offline thecfarm
« Reply #4 on: January 20, 2019, 09:49:14 PM »
I will send directions. Check your mail. :D  :D  :D  :D
I was lucky,only got maybe a foot. But the wind made the storm worse than what it was. And I do mean wind. :o
Offline mike_belben
  • Pulp Friction
« Reply #5 on: January 20, 2019, 10:02:18 PM »
You need to determine if you have low pressure and good cylinders, or good pressure and bad cylinders first.  If you just want to dive in and take stuff apart, the relief valve is always a good place to find a tiny piece of junk gumming up the works.   If you have a temp gun, find the hottest spot in the sytem.  Fluid doing no work dissipates its energy as heat.  If thats near a relief valve, walla.  Also check temp on your steer valve, it could be worn.  Could be the pump, could be a flow control valve or bad tee causing a pressure drop, etc etc.  Trick is to narrow this all down in an efficient fashion.  Let us know what you find.
Revelation 3:20
Offline Vautour
« Reply #6 on: January 22, 2019, 04:12:53 AM »
          Thanks Mike_belban for the tips... will do the temp gun thing after next storm... just hopping its nope the steering box itself :'(...process of elimination rightthumbs-up... was talking to my cousin last night who had a  loader problem and everybody told him it sound like the injector pump..soooo after a $3500 pump rebuilt.. turned out to be a head gasket (me :D :D) (him :'( :'()just kidding, I did show compassion... Prov 14;12
Offline Vautour
Re: 73Int.H30 loader(stump removal)
« Reply #7 on: January 22, 2019, 06:02:20 AM »
 stump removal
Offline thecfarm
« Reply #8 on: January 22, 2019, 06:14:33 AM »
If I dig out my stumps,I get one stump and 40 rocks. Than I have to go get dirt to fill the hole, one stump and 40 rocks made. Than I find 40 more rocks to fill up one stump hole. ::)
When I had my land logged he used my road to the back field,made a mess of it. He brought his excavator over to smooth it back up. I was digging in a place to get dirt,hard on a tractor. I had him dig in that area and had him pile it up for me. Still have rocks in it,but at least it's all loose dirt and rocks now.
Offline mike_belben
  • Pulp Friction
« Reply #9 on: January 22, 2019, 02:43:19 PM »
Nice ripper.  For little grubbing i found a single moldboard bottom plow works great.  Make a pass on each side and turn it over.
Revelation 3:20
Wanted log loader trailer or truck mounted loader
Started by 03westernstar on Wanted
Last post October 09, 2014, 02:13:42 AM
by backwoods sawyer
New to me Log Loader
Started by adirondack harvester on Forestry and Logging
Last post March 04, 2007, 12:26:23 PM
by beenthere
The no name loader
Started by yukon cornelius on General Board
Last post June 08, 2017, 12:12:50 PM
by coxy
WM log loader
Started by stumpy on Sawmills and Milling
Last post April 12, 2006, 02:47:33 PM
by stumpy
