Author Topic: Advice on buying a new chain saw Johnsered RedMax  (Read 611 times)
Offline schoeny
« on: January 22, 2019, 11:06:10 AM »
My Johnsered Dealer  has a RedMax GZ5000 which is a re-branded Johnsered 2252 and a Johnsered 2258 i like them both going to use the saw for  heavier limbs  when clearing fence rows have a Johnsered 2245 for cutting smaller limbs
Offline wild262
Re: Advice on buying a new chain saw Johnsered RedMax
« Reply #1 on: January 22, 2019, 11:25:55 AM »
 Good morning, and welcome to the forum.   You have you eye on a couple of fine saws.   Never owned a GZ5000, so I can't say.  It is a 50cc saw.  The 2258 is nothing more than a Husky 555.  Its a 60cc class saw which I have own at one time.  It was a very smooth running saw which I liked using.  It has auto-tune as well.  My pick between these 2 would be the 2258.  But wouldn't be afraid of either.  Dealer support on the RedMax is something I would check into.  Husky owns both, so you should be ok with either.
Online Allar
« Reply #2 on: January 22, 2019, 04:26:20 PM »
So Husqvarna 545 vs 555.
For limbing, it's kinda a no brainer. Get the 2252 because it's lighter.
I  have a few videos on my channel of 545 if you want to see what it's capable of.
I guess you have no issue the saw being redmax rather than jonsered?
Check out my  videos: Xtreme Landlife - YouTube
Offline schoeny
« Reply #3 on: January 22, 2019, 04:46:51 PM »
the saw i looked at was a  johnsered 2252 with redmax labels on it
Offline schoeny
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #5 on: January 22, 2019, 05:02:28 PM »
JonseRed-Max
Offline lxskllr
  • dummy with saw
« Reply #6 on: January 22, 2019, 05:12:12 PM »
I *really* hate the name Red Max. Sounds like a box store's Chinese made house brand. They should have tried harder.
Online Allar
« Reply #7 on: January 23, 2019, 01:25:52 AM »
Yeah Jonsered 2252 = Husqvarna 545 with different colors.
It's a really good saw. And for limbing it'll be one of the best,
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« Reply #8 on: January 23, 2019, 07:44:24 AM »
Of the all the Husqvarna Autotunes, I think the Husqvarna 555 and Jonsered 2258 were the least quirky over their time on the market. I have one of the early ones, excellent farm saw. Haven't had to do a thing to it other than add bar oil and gas & sharpen chains. Unless there is a burning reason not to, I would pick one of those two saws ( 555 2258 )as a general farm saw over any 550 545 variant. Every time. When the MK2's happen that may be a different story.
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline wild262
« Reply #9 on: January 23, 2019, 08:25:38 AM »
I agree.  Since you already have a good 2245 limbing saw, why not take a bigger leap to the 2258/555.  Just 15cc difference here.  The 2258 isn't that much heaver than the 2252/545.
Offline KEC
« Reply #10 on: January 23, 2019, 04:12:23 PM »
I have a Jonsered 2252 and I like it. You do have to follow the recommended
procedure when starting it or you'll do a lot of yanking. For it's size it's a real worker.
Online Allar
« Reply #11 on: January 24, 2019, 08:19:33 AM »
Which is?
Offline KEC
« Reply #12 on: February 04, 2019, 11:23:20 PM »
Allar, I can't put my finger on the manual right now. I think they say to set the choke by setting the Choke/kill switch to the up position, then push the primer bulb (don't overdo this), then pull on the starter pullcord. As soon as it starts to fire, shut the choke off(just push the switch down) and pull again. Setting the choke and then pushing it back down when the saw is not running will set the high idle. When using the saw they say to run it at full throttle or it screws up the autotune. Hope I told you right and it helps.
Buying my first chain saw. help!
Started by BBQPitts on Chainsaws
Last post April 15, 2017, 02:27:55 PM
by Puffergas
Buying new chain saw
Started by Garry on Chainsaws
Last post January 14, 2005, 05:36:07 PM
by rusted
log buying advice
Started by Part_Timer on Sawmills and Milling
Last post May 22, 2005, 12:34:23 AM
by Ironwood
Advice on Buying ~ J D 648 E or 648 D
Started by H60 Hawk Pilot on Forestry and Logging
Last post August 27, 2014, 04:22:03 PM
by Maine logger88
