Author Topic: Central Boiler eClassic 2400 blowing fuses  (Read 224 times)
Offline Doug Dawson
  • Member*
« on: January 25, 2019, 04:30:16 PM »
Unit is about 6 years old and it was working until last week.
The fuse on the internal box, below the rocker switch, blows. The circuit breaker in the house does not.
I've read online that solenoids are a common issue.  So, I replaced all 3 of them with new solenoids.  Still blows the fuse.
Dealer on the phone told me that if I unplug the solenoids and the fuse still blows there is a wiring issue.
I unplugged them all and the fuse still blows.  I checked all the connections and it doesn't look like anything broke or came loose.
Any other solutions before I call the repairman and let him deal with it?
Offline Southside logger
Re: Central Boiler eClassic 2400 blowing fuses
« Reply #1 on: January 25, 2019, 08:14:13 PM »
Not familiar with your unit, but what circuit does the fuse protect?  Does the fuse blow right off?  How many amps is the fuse? Is it a fan, circulator pump, or some other motor?  If so do you have a multi-meter and can check the amp pull for each of those motors? Can you check wiring for a rub or damage due to heat?
Offline boilerman101
« Reply #2 on: January 26, 2019, 12:24:25 PM »
Try uplugging one lead from each solenoid spade, make sure it does not ground. Also unplug fan and I think there is a transformer in the box for the LED's as well. Unplug transformer from the 110v side. Then reset breaker. Plug one back on a spade at a time until breaker trips again. If does not trip plug in fan. If does not trip plug in transformer. I imagaine the 5 amp breaker switch itself could have gone bad. I don't think there is much else unless the FireStar computer dead shorted, but that would be my last guess. try eliminating these components one at a time. Good luck, hope you find the bad component.
Offline burnswin
« Reply #3 on: January 27, 2019, 07:48:44 PM »
My fuse blew Thursday and the Central 2400 is still out of service. The fuse holder actually burned and the outside of the junction box blackened. I put a new fuse holder and fuse in and power goes to the solenoids - they jump when turning on power - and the controller powers on. The system isnt functioning - the solenoids do not open nor does the fan come. The led lights do work.
When cleaning out the reaction chamber there was water in with the ash. Thursday we had a couple inches of rain. Im thinking the rain had something to do with my troubles.
Is there something Im missing or is it a bad controller?
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #4 on: January 28, 2019, 06:41:18 AM »
I hope it hasn't leaked low in water and overheated, melting a wire?
HeatMaster dealer support in VA.
GS100.
Eclassic 1400 blowing fuses.
Started by overclocking on Firewood and Wood Heating
Last post October 17, 2015, 06:57:17 AM
by bobby s
Central Boiler 1450 or 2400?
Started by Den69RS96 on Firewood and Wood Heating
Last post January 16, 2014, 07:50:26 AM
by Den69RS96
Central Boiler Eclassic 1400
Started by holder73 on Firewood and Wood Heating
Last post April 01, 2013, 08:34:35 PM
by Ohiowood
Central Boiler - 2400 or alternatives in Mass
Started by TimGago on Firewood and Wood Heating
Last post February 06, 2011, 09:17:46 AM
by bull
