Author Topic: New Woodstove Install  (Read 1035 times)
Offline AlpineCutter
  • Living at 10,300'
« on: January 28, 2019, 04:43:50 PM »
My pellet stove quit in the middle of December. Instead of paying around $600 in parts to fix it I decided to go back to burning wood. I purchased a Kuma Aspen stove. I've only had it going for about a week but so far so good.
Trying to plan the hearth design and dimensions
Built the framework for the hearth and test fitting the slate
Got the cement board put on
Installed the slate floor. My German Shorthaired Pointer "koda" approves
Installed the rest of the slate but decided to take it further up the wall
Finished grouting the slate and got the stove up on the hearth
Decided to frame the slate on the wall with some quaking aspen boards I milled last summer from an old dead tree out back.
The hardest part of the job was installing the chimney. I have a 9/12 roof with metal roofing. And I don't like heights!! The class A pipe from the ceiling up is 12 feet along with 7 feet of black stove pipe. Needless to say I have no problem with draft.
Online Old Greenhorn
Re: New Woodstove Install
« Reply #1 on: January 28, 2019, 04:51:23 PM »
Nice job! What goes under the platform?
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline doc henderson
« Reply #2 on: January 28, 2019, 04:55:18 PM »
I wondered as well but looks like kindling?  Could also consider plumbing with a fan and ductwork to pull air along the stove and wall and blow into the room.  At first I thought it was a duct opening.  could also consider pulling in outside air for combustion.  I would not tear up your tile job to add it now. :laugh:  Good job.
  • Living at 10,300'
« Reply #3 on: January 28, 2019, 04:56:53 PM »
Thanks! Yes it is a space for kindling.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: January 28, 2019, 08:35:42 PM »
That is a superb job Ty.  Hopefully Marty and I can see it in October.   ;D
  • Living at 10,300'
« Reply #5 on: January 28, 2019, 09:31:59 PM »
The elk are still here waiting for you Lynn! At the end of last month i  counted a herd that numbered 1200.
Online thecfarm
« Reply #6 on: January 29, 2019, 06:06:43 AM »
A very nice look you have there.
« Reply #7 on: January 29, 2019, 08:34:34 AM »
What is 'kindling'?  :D :D :D :D :D
  • Living at 10,300'
« Reply #8 on: January 29, 2019, 08:59:13 AM »
Thank you cfarm!!!!
Old Greenhorn, you can always google "kindling" and see what comes up.
« Reply #9 on: January 29, 2019, 09:27:47 AM »
I think if refers to your small relatives. :D  OG.
« Reply #10 on: January 29, 2019, 12:29:41 PM »
I looked it up, turns out it means 'small wood pieces used for starting a fire'. Turns out I knew this, but had forgotten. Started my stove back in October and it has been going ever since. It will will probably burn until April. :D ;D :D ;D 8)
« Reply #11 on: January 29, 2019, 12:38:59 PM »
might be regional lingo.  You guys up north never let the fire go out anyway.  some call it tinder as well.
  • Living at 10,300'
« Reply #12 on: January 29, 2019, 04:30:38 PM »
Hey OG, I thought you were being a wise guy when you asked what is kindling. Glad you found out what it is. Like Doc said, it might be a regional thing. I've lived in Colorado my whole life and we have always called small split wood used to start the fire Kindling.
« Reply #13 on: January 29, 2019, 05:43:31 PM »
Indeed I was. It was a failed attempt at humor. I try to only light my stove once a year, then just keep it going through the winter. Kindling is not something I need much. Now down at the mill it's a different story, but its laying all over the place. :)
« Reply #14 on: January 29, 2019, 06:37:33 PM »
 :D you did put 5 smiley faces after it.!!!  :D
  • Living at 10,300'
« Reply #15 on: January 29, 2019, 07:53:26 PM »
OG,
Thats where I'm getting my kindling from. I made a huge amount of 1x1 stickers from Doug Fir last summer that is coming in really handy this winter.
Offline Gearbox
« Reply #16 on: January 29, 2019, 10:29:45 PM »
How are you  going to keep a snow slide from tearing up your flashing . That low on the roof that snow will have a lot of power . I like your install by the way .
Offline rjwoelk
    • countrysidefirewood
« Reply #17 on: January 29, 2019, 11:04:20 PM »
I like it. Looks awesome.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
  • Living at 10,300'
« Reply #18 on: January 30, 2019, 07:45:54 AM »
This side of the roof has snow stops so the snow doesn't slide. It also faces Sothwest so what the wind doesn't blow off the sun takes care of relatively fast.
« Reply #19 on: January 30, 2019, 11:06:31 AM »
keep a hot fire going and it can divide that snow as it slides off the roof like a hot knife in butter!!! 8)
woodstove ???
Started by Mr Mom on General Board
Last post September 02, 2009, 12:03:14 PM
by Mr Mom
Need a new woodstove
Started by Handy Andy on General Board
Last post July 09, 2008, 10:38:15 AM
by beenthere
Huffing woodstove
Started by Handy Andy on Firewood and Wood Heating
Last post December 27, 2011, 10:20:02 PM
by Handy Andy
crack in woodstove
Started by robmelby on Firewood and Wood Heating
Last post October 09, 2016, 10:38:40 AM
by Ox
