Author Topic: What do you use for material handling ?  (Read 1875 times)
Offline randy d
Re: What do you use for material handling ?
« Reply #20 on: January 30, 2019, 10:55:53 AM »
We transport our logs and lumber with a John Deere 4320 compact tractor with pallet forks works pretty good when I had my first mill we used New Holland skid steer worked good also but tore up the ground pretty bad. Randy
Offline alanh
« Reply #21 on: January 30, 2019, 11:29:06 AM »
580 case with a 4 way front bucket for the big stuff, but
 this guy does an impressive amount of work
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #22 on: January 30, 2019, 12:56:05 PM »
I often wondered how those would work everytime I drool over one. would be great for a portable job in someones backyard with very tight quarters. if the mill was built good enough you could put it right on the mill for transport.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #23 on: January 30, 2019, 03:21:41 PM »
I have a Kubota L48. My preference is a Lull type telehandler.
Offline alanh
« Reply #24 on: January 30, 2019, 03:23:32 PM »
I was actually quite surprised on what it can lift,  if it can`t lift it (16  ft, 28" oak) I get the forks under it, curl back a hair and the log is off the ground enough to push it..or roll it. very handy for the slabs, moving pallets, etc. Its so small and manueverable I find myself avoiding using the big machine., This one is 3k lbs, I wouldn`t put in on my mill but lotsa guys get them in the back of their trucks.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #25 on: January 30, 2019, 04:27:59 PM »
I would be alot happier putting it on my mill than in the back of my truck. even if I had a 1 ton. The mill was built for 6000+ pounds. of course the single 7000 pound axle is the limiting factor anyhow :)
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #26 on: February 04, 2019, 12:22:18 AM »
Cat 910 articulated loader with forks.
Given a choice, I'd got with a CAT IT-12 integrated tool carrier. It's the same machine as the 910 but has quick-change attachments and parallel loader geometry.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #27 on: February 04, 2019, 06:28:08 AM »
The cat works for me.
A&P saw Mill LLC.
License NH softwood grader.
Online Dave Shepard
    • My homepage
« Reply #28 on: February 04, 2019, 09:24:50 PM »
A telehandler is about the most versatile machine around the mill.  :)
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #29 on: February 05, 2019, 08:20:22 PM »
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #30 on: February 05, 2019, 09:07:24 PM »
   I think the Admins should move this to the Restricted thread so us underprivileged po' folks don't have to read, look and cry.
   I have a JD 750 with a bush hog brand 1648 (I think that is right model number) FEL with a bucket and 20" forks that bolt on to the bucket. It is way undersized for any big log or load of lumber. When somebody gives me a winning lottery ticket I am going to upgrade. (How many times I have I seen the old adage "How do you make a million dollars with a sawmill? Answer: Start with 2 million.)
Offline Southside
« Reply #31 on: February 05, 2019, 09:36:54 PM »
WV - that tractor sure holds a good whack of lumber.  I have a 66 HP row crop IH that would be about all full with that on the loader.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #32 on: February 05, 2019, 10:57:19 PM »
Moves the lumber.
Clears snow.
Picks up logs.from trailers with fenders
I'm happy with what I have, it meets all my needs.
Now, if I wanted to stack my lumber up to eight lifts high, I'd go with the Cat that Peter Drouin plays with!   :D
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Offline ljohnsaw
« Reply #33 on: February 06, 2019, 12:01:03 AM »
Sure are a lot of nice high lift forklifts out there!  I just have this 1986 vintage 9038:
9,000 lb lift and 38' reach.  Rebuilt 3 rams so far (another starting to leak) and replace 4 or 5 hoses.  Needs to have the head gasket replaced next.  Don't have chains so it don't like snow much.  I've done a ton of work with it building my cabin and hauling logs.
John Sawicky
Offline charles mann
« Reply #34 on: February 06, 2019, 12:49:46 AM »
@E-Tex you didn't have that tractor when i stopped by did you? what hp is it and do you like the backhoe attachment? been contemplating getting a hoe for my kubota. maybe this winter depending how well i do on fire season this yr, and how well our profit sharing bonus is, which depends on the bristow group buy out.
Temple, Tx
    • A&P Saw mill LLC
« Reply #35 on: February 06, 2019, 07:00:41 AM »
Andries, A grapple is most useful.
A&P saw Mill LLC.
Offline Sixacresand
  • John and Nancy
« Reply #36 on: February 06, 2019, 08:14:50 AM »
For the few logs per day I do, I depend on a riding lawn tractor and self built log arch.  I use this rig to move logs, slabs and pallets of lumber.  Most of the big jobs are at a customer's place who furnishes a tractor and labor.  I have a two axle trailer with parbuckling winch to pick up logs.  It is all kinda primitive but I get by.  So far I have resisted a new FEL tractor and a new monthly payment.
Offline E-Tex
    • www.L2Sawmill.com
« Reply #37 on: February 06, 2019, 09:11:10 AM »
No sir, I've just had it a few months.  65hp.....Heavy Tractor with great lift capacity.  Works perfect for me.
I love the backhoe attachment.  Its no yellow machine but its a great tool for my property.
L2 Sawmill LLC
Offline Andries
« Reply #38 on: February 06, 2019, 10:47:40 AM »
I agree completely.
This canoe got in the way once too often . . . .  ;)
Peter, you show photos of the Mr. Deere and Mr. Cat.
Great looking equipment!
Do you use the grapple on the Cat very often?
Also, if memory serves, you do a lot of timber milling for the timber framing market.
Doesn't the grapple punch dents into the timbers when using the grapple?
LT30G24
Stihl chainsaws
Material Handling
Started by Cypress Man on Sawmills and Milling
Last post June 13, 2014, 09:07:32 AM
by giant splinter
question
Material Handling
Started by Larry on Sawmills and Milling
Last post September 28, 2011, 09:15:05 PM
by WDH
material handling:new tractor or yard lift
Started by brdmkr on Sawmills and Milling
Last post February 27, 2007, 11:31:43 AM
by TnSawyer
log handling
Started by FurnDoc on Ask The Forester
Last post May 02, 2006, 04:00:02 PM
by beenthere
