Author Topic: Is burning Sweet Gum advisable?  (Read 582 times)
Offline LaneC
  • Traveling Man
« on: January 29, 2019, 10:41:54 PM »
    I just had quite a few sweetgum trees cut from a piece of land I have and I hate to see it go to waste. Is it advisable to burn it in fireplaces, or wood stoves? I know it will have to dry, and I am pretty sure it will pop a good bit, but will it build up inside the chimney or stove pipe? As usual, all comments are appreciated.
Man makes plans and God smiles
Offline Southside logger
Re: Is burning Sweet Gum advisable?
« Reply #1 on: January 29, 2019, 11:52:48 PM »
It won't give you heat like oak will, but it burns just fine for me and has never caused a chimney issue.
Offline Rebarb
« Reply #2 on: January 30, 2019, 01:39:42 AM »
Never had any problems burning it but it's a pain to split.....it actually tears.
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #3 on: January 30, 2019, 03:39:05 AM »
Same here with black gum. Different species but I think the wood is similar. Brutal to split. Burns decent.
HeatMaster dealer support in VA.
GS100.
Offline LaneC
  • Traveling Man
« Reply #4 on: January 30, 2019, 10:31:53 AM »
  Thanks a bunch fellows.
Offline pineywoods
« Reply #5 on: January 30, 2019, 10:49:19 AM »
Be prepared to deal with a lot of ashes. Burns ok, but a cubic foot of wood will make a cubic foot of ashes.. ::)
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #6 on: January 30, 2019, 05:01:36 PM »
Does fine if it's dry.  Like Elm, it's a pretty good sponge and has fewer BTU per volume to make up for it.  As such it needs to be drier than you can get away with on an Oak or Hickory, but if dry, it's fine.
Just don't bother splitting it.   ;)
Offline LaneC
  • Traveling Man
« Reply #7 on: January 30, 2019, 08:11:10 PM »
  Thanks for all the info. Much appreciated. I never really looked in this category before, but just like in all the other ones, yall are a big help, and thanks again. If the smoke smelled like it does when cutting, that would be good :D
moved
MOVED: Is burning Sweet Gum advisable?
Started by chet on General Board
Last post January 29, 2019, 11:42:22 PM
by chet
Sweet Gum......SWEET!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post February 13, 2013, 12:27:03 PM
by hackberry jake
something sweet
Started by northwoods1 on FOOD! FOOD! FOOD!
Last post April 07, 2011, 08:47:27 AM
by Magicman
sweet gum ???
Started by Po-Jo on Sawmills and Milling
Last post March 14, 2014, 10:27:22 AM
by MattJ
