Author Topic: I just got home with a 2011 LT35HD - I need your counsel on how to succeed.  (Read 6871 times)
Offline MikeySP
Re: I just got home with a 2011 LT35HD - I need your counsel on how to succeed.
« Reply #80 on: February 09, 2019, 09:02:46 PM »
Thank you for the ideas gents.
I will look into the material options, but the tracked skid can't be on the menu anytime soon.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #81 on: February 09, 2019, 09:55:23 PM »
Green crushed concrete is the best mud base Iíve ever used.  All (most) concrete plants have green tailings, waste, and other pieces that donít cast well, such as concrete block, and will crush it and sell it for $7 per ton here.  I get it routinely by the dump truck load, and when put out thick on the ground, say 6 inches or so, and packed, will finish curing and will set up a hard as concrete within a few months.  We once built a road into a 20 acre swamp with this stuff, and it is still being used 20 years later. Significantly cheaper than gravel.
HobbyHardwoodAlabama.com
Offline MikeySP
« Reply #82 on: February 10, 2019, 12:52:45 AM »
Thanks for seconding that tip with your experience Yellow Hammer. I will make some calls Monday to see what I can find.  -Mike
Offline MikeySP
« Reply #83 on: February 15, 2019, 07:17:03 PM »
Howdy!
Can anyone help me understand the correct rotation direction of a debarker? One of you kind gents sent me pics of a debarker and it looked pretty simple, so I got hold of a debarker manual. After reading about direction of rotation and then seeing the debarker manual, I think I had it backwards. The manual makes me think rotation direction is as my images below depict. However, when I read men's comments about rotation, it sounds like the rotation is the exact opposite of what I have depicted below. Knowing that there are times when a blade is used in the opposite direction from convention, I wanted to get the facts. Thank you for the clarification. -Mike
Manual image... my red arrow.
Offline Southside logger
« Reply #84 on: February 15, 2019, 08:41:59 PM »
Yup - that's how mine runs.
Offline MikeySP
« Reply #85 on: February 19, 2019, 08:38:24 AM »
Thank you SSL!
Look at the images. On left is illustration of LT35 debarker and on the right, I think, is an LT40 debarker.
Notice the bearing and support on the right. Wondering which way to go? I assume they have the same motor. I have a woodmizer 3/4HP motor for my build. Would not cost much to add a support and bearing, but if it ain't broke, why fix it. Anyone with experience with both?
Of interest: when editing image for this post, I was surprised to see the debarker rotation is opposite in the two images.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #86 on: February 19, 2019, 08:49:39 AM »
My Debarker shown on the right does indeed climb out of the cut and throws the chips toward the operator.  I understand the reasoning behind this technology and am completely comfortable with it.
The Debarker shown on the left turns in the opposite direction and needs a limiter plate to prevent it from digging too deeply, stalling the motor, and kicking the breaker.  Of course it throws the chips away from the operator.
I have no thoughts regarding the support bearing and was not aware that the other did not have one.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #87 on: February 19, 2019, 11:13:22 AM »
I have a friend who has an LT35, and the only issue he has with his debarker is once in a while he moves it in too soon and runs it into the end of the log, and it wants to just saw into it.
He's new and he's catching on, and learning that the debarker has to contact the log on the side!  :)
~Chuck~
I LOVE MY SAWMILL
« Reply #88 on: February 19, 2019, 08:15:50 PM »
Double checked both of mine to be sure, they both spin away from the operator, the 35 does not have the support bearing or a depth disc, the 70 has the support bearing but no depth disc.  I have only ever tripped the breaker on the 35 once, done it more times on the 70 actually.  I think that's because the 35 has the old hand lever and double spring tension system, it can't dig in as the two springs let it float.
Offline MikeySP
« Reply #89 on: February 19, 2019, 09:54:30 PM »
Thanks for the info gents. Odd thing: Woodmizer sent me the LT35 debarker manual and it has a 1/30HP geared motor on top in the manual vs the hand-lever that your LT35 has Southside Logger. Must have been a later development.
Magicman, I hope you were able to get your sawing done on that road trip. We are expecting 7-9 inches of rain over the next few days my neighbor tells me.
PS. I contacted my first potential customer today. Gentleman who lives up the road a few miles has an 18"x12' walnut log. He asked me if he is to deliver it to me. I told him that he can do that, or I can pick it up or come to him with my portable mill. When he learned I could come to the logs, he wanted to look at having his son cut down several poplar trees to get some 2x6's for some barn repairs and have me come to site. May be some time yet and we did not discuss price yet. He is supposed to call me at some point. I will need to figure out my price. I am inclined to do it by the board foot, so he is not paying for my snail operation as a newb. I have received some good tips from one of you gentlemen on the forum and will likely seek more info as the mission develops. I am thinking for the first few jobs, not to have a minimum for close customers; and, will consider it getting paid to put spurs to this rodeo, and staying in the shallow end of the pool. In my old profession, we had the mission to turn farmers into soldiers under the enemy's nose; so, the early missions of the troops in this theoretical ragtag army were called - confidence targets... these are easier missions such as graffiti propaganda before high risk toe-to-toe missions. I think it would be a great benefit to have a few confidence targets under my belt. Already thought to saw up his poplar 2x6's before touching his walnut log.
Thanks again!
-Mike
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #90 on: February 19, 2019, 10:29:37 PM »
The weather/rain made me postpone this week's sawing, so my plans now are to return next week to hopefully finish that job.
Offline MikeySP
« Reply #91 on: February 21, 2019, 10:28:12 PM »
OK Gents, I have an ad up and I have had two inquiries besides the folks wanting to buy my sawmill :).
So, now I need to give the potential customers some info if they start to probe for more. I put the attached PDF together this evening; but, I am flying by the seat of my pants
. So, I request a brutal critique on my draft document. Thank ye kindly!
-Mike
PS. Magicman, I don't know which way you are going on that sawing next week, but we have been getting rain, rain, rain, and austensibly we have another serveral inches coming over the next two days. I am thinking there may be  market for SCUBA Sawyer.
Offline MikeySP
« Reply #92 on: February 21, 2019, 11:18:55 PM »
BTW Gents, so I can learn proper forum etiquette: should I keep asking my educational questions on this thread... or should I make a new thread for each new subtopic? For example, the request of a critique on my customer information sheet, should it have been a new thread? Always learning. -Mike
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #93 on: February 22, 2019, 07:16:03 AM »
Keeping everything is this thread will make the your experience easier for others to understand and learn from.
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #94 on: February 22, 2019, 07:50:18 AM »
Mike, Iíve enjoyed reading this thread. Your questions are great and you are on the right path.  Iíve learned a some things as Iíve read.
I was in your place a year ago.  The members here have continued to give me excellent guidance.  Much of the success Iíve had is a result of that guidance.
Keeping your questions here will provide other rookies access to your questions and the responses in one place.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #95 on: February 22, 2019, 07:51:54 AM »
Good sheet, covers a lot of bases. Minor comments-you might say it saves  two hauling trips logs one way, lumber the other. Also you get to participate in sawing your logs if you like.
In your bf definition, two points, maybe simplify a bit and  give an example 10' 2x6 has bf = 2" x6" x 10' /12 = 10 bf.
Also when you mention the scaling of bf in logs it might be confusing how you charge, is it by log or by lumber.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
« Reply #96 on: February 22, 2019, 08:00:36 AM »
When quarter sawing I switch over to hourly rate, as setting the log alignment and sawing technique is critical and takes some time to get the best results.  So I like to slow down and get it right, and my board foot production rate suffers.  Also, since quarter sawing has more waste than conventional sawing the board foot production is lower anyway.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #97 on: February 22, 2019, 08:55:17 AM »
MikeySP,
  On setting up your policies and pricing I would go ahead and do that before your first customer but remember you can always waive certain charges such as mileage or set up or minimum quantities or such on any given job until you feel comfortable applying them.
Online GAB
« Reply #98 on: February 22, 2019, 10:11:54 AM »
If I am reading your sketch correctly your finished lumber is too close to the mill.
When you get done you will be locked in.
I charge $10.00 plus what I last payed for blades for destroyed blades.
The $10.00 is to pay for lost production.
Gerald
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #99 on: February 22, 2019, 11:19:21 AM »
With me the finished lumber always goes to the end of the mill, not to the front.  Closer and doesn't require dodging the sawmill head and crossing the sawdust.  Boards are pulled immediately as they are sawn.  I always require that the tailgunners and their activities remain in my sight.
I edge as I saw so the flitches go on the loader arms.  In the event that I need to wait and edge a couple of logs, the flitches simple lay on the staged logs.  I never wait until all of the logs are sawn to edge.
My slabs go where the sawhorses/flitches are shown which is closer so less handling.
P.S.  The weather forecast looks good for me next week.  I am sawing ~75 miles South of Memphis which is ~200 miles SW of you.  Actually you are closer to that job than I am.  :D
Read and you will succeed.....
Started by OlJarhead on Sawmills and Milling
Last post February 23, 2016, 11:27:39 AM
by OlJarhead
LT35HD LT40HD
Started by DDobbs on Sawmills and Milling
Last post October 23, 2015, 10:12:16 AM
by barbender
Woodmizer LT35hd
Started by MReinemann on Sawmills and Milling
Last post September 05, 2012, 05:58:24 PM
by MReinemann
LT35HD Best 1 day output
Started by thechknhwk on Sawmills and Milling
Last post August 01, 2013, 07:36:20 PM
by thechknhwk
