Author Topic: I just got home with a 2011 LT35HD - I need your counsel on how to succeed.  (Read 18260 times)
Offline Southside
Watch your outlet chute, the fingers are going to catch the bark and sawdust will begin to pack in the wheel covers.  When you don't see it coming out of the chute, stop and clear off the fingers.
Offline doc henderson
for uber rustic, you can leave the lumber tapered as it is in the tree and alternate orientation end for end as you hang it.  or (less rustic) develop a U shaped cant.  2 parallel sides that will be the faces and backs of the siding.  the "bottom" of the U is the top edge of the siding. the open top of the U is the live edge. when you cut this, (bottom of the U)you can let the live edge rest flat on the bed of the mill, and cut parallel to the live edge.  you can now orient the "bottom" of the U to the hooks and now just flat saw through the cant.  you can try to make a uniform size, say 8 inch siding with a 2 inch over lap for a 6 inch reveal.  If you have a starter strip at the bottom, maybe 2 inches wide, you do not need to rotate the cant to make tapered siding boards.  It is hung like concrete siding boards.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline MikeySP
Thanks gents!
I guess the previous owner of my LT35 must have been putout by the safety fingers in the shoot, because they do not exist on my sawmill.
The owner of the logs wants both edges live, so I assume he intends to appose the ends. Not sure how he plans to deal with whitewood... maybe a water reppellent such as would be used on pine or some other lap siding.
-Mike
the white wood is not as resistant as the heartwood, but if not in contact with soil and water it should do fine.  a clear water proof could be sprayed  with a garden sprayer much like a deck
Offline MikeySP
Excellent. Thanks Doc.
Forgot to ask, if you were selecting between 4 and 10 degree blades, which would you use?
I have lots of 10, so I would like to use them, but not if they will be problematic.
I have 1 Turbo 7, but I am waiting to use it on a specific log for testing it out, so I won't use it on these cedars.
Offline WV Sawmiller
    • Green's Sawmill Services
   My limited experience with cedar is it is very soft and you should be fine with the 10 degree blades. I personally am phasing out my 7 & 10 degree blades and replacing them over time with 4 degree which, for me, works with everything.
I use 7 degree on most everything.  if you got 10 s to spare give them a try.  look to see if there is pitch at the junction of heartwood and the sap wood, if so I would use a lube/soap or check you  blade freq. to see if you need it or if you need more in terms of volume or concentration.  there is silica in the bark and wood so follow blade sharpness.  I could saw it all day long.  caution with folks with allergy (usually woodworkers who have been around it for years and developed sensitivity) or asthma inhaling the dust.  I love the grain and like an ink blot test, can see animals and other characters in the grain patterns.   @Southside   and @YellowHammer  always see chickens... not sure what that means!   8)  remember to share some pics.  Your job is easier if you have a client and they are directing how they want the wood sawed.  and that responsibility is off your back.
Online btulloh
Ive used10s on ERC with no problem. You may want slow down a bit when approaching knots or nubs to avoid a wave. Same for insulators and fence wire.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
For me, 10 blades were near prefect for sawing ERC, but I have phased them all out and only use Turbo 7 blades now.  I do still have some 4 blades, but after the success that I had with T7's on White and Post Oak, I doubt that the 4's will ever be used.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Sawing cedar is fine, easy as can be.  Lots of inclusions and wane, though, so high grade yield can be lower than expected.
HobbyHardwoodAlabama.com
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
fire it up, start cutting 8) 8) ;D ;D
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Thanks gents!
Make sure no one ever gets around that exit area. I have had them come out the shoot and even had the fingers as they are being called bent by a blade trying to get out.
  I know you have a different mill, but the resusts can be the same.  Not a good place to be even with the safety fingers installed.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Absolutely, I only have one finger missing and they can/will still exit the sawdust chute.
Another.
And this one decided to make it's own exit hole!   :o
Glad that no one was standing there.
i always keep people from that side of the mill, but a picture is worth a thousand words.  @Magicman glad to hear you only have "1 finger missing" !   :o   :D :D :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
I need to take better care of myself.  ::)
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
That might not be all that is missing :D
Read and you will succeed.....
Started by OlJarhead on Sawmills and Milling
Last post February 23, 2016, 11:27:39 AM
by OlJarhead
LT35HD LT40HD
Started by DDobbs on Sawmills and Milling
Last post October 23, 2015, 10:12:16 AM
by barbender
Woodmizer LT35hd
Started by MReinemann on Sawmills and Milling
Last post September 05, 2012, 05:58:24 PM
by MReinemann
Lt35hd mill set up
Started by jb14972 on Sawmills and Milling
Last post April 01, 2019, 05:54:42 AM
by jb14972
