Author Topic: Post your saw!  (Read 1356 times)
Offline Wedgebanger
  • Stirs coffee with thumb.
Post your saw!
« on: January 30, 2019, 06:31:18 PM »
Thought it would be interesting to post up what your main saw is and what you have done to it. This is my 311 with a 20" bar, Stihl yellow chain and aftermarket dogs.
Offline lxskllr
  • dummy with saw
Re: Post your saw!
« Reply #1 on: January 30, 2019, 06:48:25 PM »
I don't take a lot of pictures, but I already had this one in the gallery...
That's my big boy saw; a 362cm. The only thing I've done to it is take out the spark arrestor.
This is my cs400, which has been getting more run time lately. Shown here wearing a PoulanPro bar...
It's had the cat gutted, and the spark arrestor removed.
I also have 362(not cm) that looks the same as first, but with a 20" laminated bar, and not modified at all. Lastly, I have a cs2511t. That's had the spark arrestor removed.
edit:
I forgot I had a pic of my 2511t. Shown with an apple for scale since I didn't have a banana  :^P
That's really a fun little saw. I haven't had much chance to use it yet, but I'm looking forward to giving it a good workout. It's got full chisel green chain, and it's a little grabby. Too much so for the engine size I think. I'm gonna make a loop of semi chisel yellow chain, and see if that's a better match. Smaller chain all around would probably be better, but I like being standardized on 3/8 and 3/8lopro for all my saws. Keeps chain management simplified.
Offline Hooterspfld
  • I'm a sucker for a chainsaw!
Re: Post your saw!
« Reply #2 on: January 30, 2019, 08:00:21 PM »
No cool action shots tonight, it's 12 degrees out...
MS250 was my go too until I got the MS362 CM and the MS661 CM. Think I'm going to put a 20" bar on the 362 and take the 25" bar and put it on the 661. Really only need the 36" bar for slabbing. My 250 is probably going to sit on the shelf especially cause it's carb is acting up. The 193T is for the rare time im up in a bucket.
Offline Inaotherlife
Re: Post your saw!
« Reply #3 on: January 30, 2019, 08:36:40 PM »
Here's my pole saw. It's got a four foot extension, and cost as much as my next two most expensive saws combined.
And until I can find a bigger one that's as cheap as me, here's my big saw. I put gas in it.
Offline upnut
  • Wood Tick
Re: Post your saw!
« Reply #4 on: January 30, 2019, 09:22:26 PM »
Stihl MSA 120 C Which is bone-stock...
I plug the charger in where the toaster normally goes if I want a little more "pop"... :D
It served as back-up to the MS241 C-M...
I recently was able to purchase a Stihl MS261 C-M for back-up duties, no pics yet.
Scott B.
I did not fall, there was a GRAVITY SURGE!
Offline Old Greenhorn
Re: Post your saw!
« Reply #5 on: January 30, 2019, 09:46:28 PM »
Here's a photo I had on file from the spring. You figure out which one it is. It's my only workhorse for now. (And yes, I know the chain is too loose.)
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline lxskllr
  • dummy with saw
Re: Post your saw!
« Reply #6 on: January 30, 2019, 09:53:59 PM »
I like that pickaroon. Is that factory or hand made?
Offline firefighter ontheside
  • I like trees.
Re: Post your saw!
« Reply #7 on: January 30, 2019, 10:10:54 PM »
My Ms291 and a little lobl olly pine.  Donít have any pics of my old 025, but thatís still a great saw.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Re: Post your saw!
« Reply #8 on: January 30, 2019, 10:15:46 PM »
Ooh! I got one of those too! I use it for all kinds of stuff that it's too small to cut. And with a too big bar too😀
Re: Post your saw!
« Reply #9 on: January 30, 2019, 10:25:09 PM »
Nope, that is store bought. I got it at a local loggers supply and the name escapes me at the moment. I'll be honest and say it's too dang cold to walk through the snow to the shop in my moccasins to check the name, but I will look tomorrow. I know they are USA made.  I like the little blade on the back. When I am splitting stringy stuff I use it to cut the strings. I like it so much, I got another, longer one, without the blade for moving logs. Very handy. As you can see, I keep them both handy on my mule all the time.
Offline lxskllr
  • dummy with saw
Re: Post your saw!
« Reply #10 on: January 30, 2019, 10:44:04 PM »
That little blade's what grabbed my attention. I could use that for just what you said. Cutting split strings. I have small axes, but don't feel like dragging the whole house out to split wood, and having something to pick rounds would be handy. I usually take a maul, two wedges, a big axe, and a splitting maul out to split wood. I could make room for a bladed pickaroon since it would have more than one use.
Online Ianab
Re: Post your saw!
« Reply #11 on: January 31, 2019, 02:05:34 AM »
Dolmar 7900 with 28" bar.
Overkill for some situations, but that's it sitting on a pine tree stump that's only ~30 years old.
Need it more for trees like this cypress.
Offline Air Lad
  • Onwards and upwards
Re: Post your saw!
« Reply #12 on: January 31, 2019, 06:20:56 AM »
That's a lot of Cyprus Ianab
Great timber as the white ants don't like
Cheers
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Re: Post your saw!
« Reply #13 on: January 31, 2019, 06:50:41 AM »
I got it from Sheldon Hill Forestry. I went and checked and they don't have those two on their web site, it is made by "Peavey Mfg. Co." in Maine. The one with the blade comes in 15 to 48" lengths. I like the short length for firewood, and the longer for positioning logs. Here is the Link to the maker's site.
Offline lxskllr
  • dummy with saw
Re: Post your saw!
« Reply #14 on: January 31, 2019, 06:55:46 AM »
:^O
You guys grow some big pines down there!
  • I like trees.
Re: Post your saw!
« Reply #15 on: January 31, 2019, 09:08:11 AM »
PHoly cow Ian.....30 years.  My lobl olly that was that size was about 60 years old.  Was yours radiata?
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Online stan064
Re: Post your saw!
« Reply #16 on: January 31, 2019, 11:24:01 AM »
Offline sablatnic
Re: Post your saw!
« Reply #17 on: January 31, 2019, 12:49:09 PM »
This little farmer saw does about 80% of my sawing - believe I have six or seven of them under different names, Partner, Husqvarna, Jonsereds.
Certainly not fast, just pleasant to use.
Offline Grizzly
  • I wanna go camping!
Re: Post your saw!
« Reply #18 on: January 31, 2019, 01:12:41 PM »
That's an old 111S I inherited. 36" Cannon bar. The oiler ain't working right so it's not a daily user, just my show off saw i guess.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
2000 Miners 3-31 Board Edger
Online Ianab
Re: Post your saw!
« Reply #19 on: January 31, 2019, 01:17:50 PM »
Yup, Radiata pine. That's why it's grown on a 25-30 year rotation.
The other one is Monterey cypress, which can go huge here.
How many cords are in my truck? miss post, please read other post, thnx
Started by Kelvin on Sawmills and Milling
Last post November 04, 2008, 06:38:27 PM
by beenthere
Read post, but new post sign stays
Started by farmboy1tn on Technical Support Topics
Last post November 02, 2013, 09:50:43 PM
by Jeff
Post on mudsill vs. on post base
Started by kodl on Timber Framing/Log construction
Last post October 12, 2018, 07:48:16 PM
by Don P
Post on top of post/beam joint
Started by evjim on Timber Framing/Log construction
Last post April 03, 2017, 08:25:51 AM
by Don P
