Author Topic: Post your saw!  (Read 1318 times)
Offline HolmenTree
Re: Post your saw!
« Reply #20 on: January 31, 2019, 03:37:59 PM »
That's an old 111S I inherited. 36" Cannon bar. The oiler ain't working right so it's not a daily user, just my show off saw i guess.
Nice looking saw there Grizzly, welcome back.
Offline sablatnic
Re: Post your saw!
« Reply #21 on: January 31, 2019, 04:25:46 PM »
Grizzly
Lovely Jonsereds 111!
With a bit of luck your oiler problems could be the o-rings around the pump body having gone slack.
Look after it please, not many around anymore.
Online stan064
Re: Post your saw!
« Reply #22 on: January 31, 2019, 07:22:03 PM »
I posted my saws could not get pic and right up together ?they are  076,064,036,260, 250,jred 70E,poulan 4200,echo 340 top handle,i been running the 64 and 36 since new in the mid 80s all original
Offline Wedgebanger
Re: Post your saw!
« Reply #23 on: January 31, 2019, 09:02:07 PM »
A lot of good looking equipment, new and old!
Offline HolmenTree
Re: Post your saw!
« Reply #24 on: January 31, 2019, 09:14:56 PM »
Grizzly
I remember changing the O rings on my 621 and 90. Probably easy enough to find at any auto parts store today
Offline Air Lad
  • Onwards and upwards
Re: Post your saw!
« Reply #25 on: February 01, 2019, 04:38:44 AM »
Learning how to put up pic's
The 170 is the baby of the fleet
 Unfortunately the program takes my original pic and rotates it 90 deg left
Sorry for the sore necks
Cheers
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline lxskllr
  • dummy with saw
Re: Post your saw!
« Reply #26 on: February 01, 2019, 07:07:26 AM »
Cheers
I just figured your trees grew differently down there  :^P
Offline thecfarm
Re: Post your saw!
« Reply #27 on: February 01, 2019, 08:11:30 AM »
@Air Lad When you click onto the picture and you are ready tp post the link of that picture there is a place below to rotate it -90░ ot + 90░. Give it a try.
Offline Grizzly
  • I wanna go camping!
Re: Post your saw!
« Reply #28 on: February 01, 2019, 09:53:02 AM »
So, do you or holmentree (or anyone else) have any directions for removing the oil pump? I've looked at it and from what i see it would be easy to do it wrong and end up with something broken. I don't want to get too adventurous with it cause i can't just go buy a new one if i break something.
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
2000 Miners 3-31 Board Edger
Offline sablatnic
Re: Post your saw!
« Reply #29 on: February 01, 2019, 11:01:47 AM »
I've done it on a 90, and only once, about 30 years ago, but can't remember any complications.
I believe the pump is similar to this, right hand lower corner of page two:
http://s30387.gridserver.com/partsDiagrams/Jonsered%2070e.pdf
Remove exhaust, remove screw that holds locking clamp, and gently pull out the pump body. And make sure the piston comes out too.
Better wait for Holmentree too - he'll probably know more about it.
Offline Air Lad
Re: Post your saw!
« Reply #30 on: February 01, 2019, 05:38:44 PM »
Thanks will try again
Cheers Mate
Offline HolmenTree
Re: Post your saw!
« Reply #31 on: February 01, 2019, 06:16:47 PM »
Yep the 70e oiler is very similar to the 111 oiler with the same amount of O rings but the 111 has one more valve with 3 O rings right above it.
Here's a pic of the 111 exterior oil pump under the muffler.
The  2 screw cover holds the oil pump and the round 1 screw cover above it is the lubrication adjustment valve .
The 621 80 801 90 had a silver allen screw in plug that held the single oil pump in with a adjustment screw inside.
Offline olcowhand
  • I'm new- ish!
Re: Post your saw!
« Reply #32 on: February 01, 2019, 06:51:27 PM »
The 170 is the baby of the fleet(Image hidden from quote, click to view.)
Cheers
It does that when it crosses the Equator...ů :D
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline Grizzly
Re: Post your saw!
« Reply #33 on: February 04, 2019, 09:29:46 AM »
Thanks, Holmentree and sablatnic. It was those 3 screws that i wondered about and wasn't sure how many springs would be behind them. So, thanks again. Now once I'm able to get out to the shop I can take another look and have a go at it.
Offline HolmenTree
Re: Post your saw!
« Reply #34 on: February 04, 2019, 12:33:30 PM »
You're welcome Grizzly.
Take another look at the above 111 picture I posted. I'm not 100% sure but I think the little screw that thread downwards at the top of the picture is the adjustment screw. ???
How many cords are in my truck? miss post, please read other post, thnx
Started by Kelvin on Sawmills and Milling
Last post November 04, 2008, 06:38:27 PM
by beenthere
Read post, but new post sign stays
Started by farmboy1tn on Technical Support Topics
Last post November 02, 2013, 09:50:43 PM
by Jeff
Post on top of post/beam joint
Started by evjim on Timber Framing/Log construction
Last post April 03, 2017, 08:25:51 AM
by Don P
Post on mudsill vs. on post base
Started by kodl on Timber Framing/Log construction
Last post October 12, 2018, 07:48:16 PM
by Don P
