Author Topic: Kiln Chamber  (Read 819 times)
Offline K-Guy
  • Board Moderator
    • http://www.nyle.com/
Kiln Chamber
« on: January 31, 2019, 04:30:16 PM »
Hi Guys
I'm curious to hear what your chamber sizes are. We always think we know but I want to hear from you and what model your kiln is.
Stan
Nyle Kiln Sales & Service
“If you don't read the newspaper, you're uninformed. If you read the newspaper, you're mis-informed.” Mark Twain
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Kiln Chamber
« Reply #1 on: January 31, 2019, 09:07:21 PM »
L53.  Chamber is 11.5' wide, 10' deep, and 8' high.  Double doors open wide and load the kiln with tractor with forks.
Offline Southside
Re: Kiln Chamber
« Reply #2 on: January 31, 2019, 09:11:50 PM »
A Yellow Hammer 40' Sea-can Special with a KD250 and 6 fans overhead. Sure is breezy in there!!
Offline scsmith42
    • Whispering Pines Farm
Re: Kiln Chamber
« Reply #3 on: January 31, 2019, 09:42:10 PM »
I built a container kiln 16 years ago.  I started with a 45' high cube container and insulated it.  Maximum stack width is 48" and maximum height is 72".  It has 6 fans, three of which can be closed off for low bd ft loads.  The L200 is installed in a "bay window" sized chamber on the side of the container.  Stickered lumber is forked onto kiln carts outside of the kiln and then winched in. It's been in almost constant use for 15 years.
Having processed many hundreds of loads through this system, I can state that I am not a fan of it.  What worked well on paper (offbearing from the sawmill directly onto a kiln cart) was more labor intensive in practice than in theory.  I also feel that it takes me at least an hour longer to load per charge versus forking directly in from the side.
Additionally, it is my opinion that the air flow inside the long, narrow chamber is not optimum.
It is my plan to build two new kiln chambers this year (I have a second L200 bought years back from a FF member).  The kiln chamber will be sized for up to 4000 bd ft of 4/4 oak to be forked directly in from barn style doors on the side of the chamber.  I will keep my current 4' deep stickered stacks, because that is a good size for many forklift fork lengths.  The chamber will be designed in terms of height, width and depth to allow me to place four 1000 bd ft stacks inside - two side by side and stacked 2 high.  I am anticipating a depth of 13', give or take, in order to have 3-4' of clearance in front of and behind the stacks, and also for the L200 unit to be located along the back wall w/o impeding walk access by the lumber.
The main new addition that I would like to make to it is a fast and effective method of baffling the stacks.  Currently I drop down hinged plywood panels on top of the stacks but it takes a while to baffle under the carts and on the ends.  This I would like to expedite.
There are benefits to container kilns, but in 15 years of operation I have noted consistent deltas between drying rates for lumber placed at the far ends of the container versus what is stacked on the middle carts.
My 2 cents.  YMMV.
Tom's 3638D Baker band mill
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Kiln Chamber
« Reply #4 on: February 01, 2019, 12:02:26 AM »
High cube shipping container. I have very comsistent drying by providing a larg flat plenum area in front of the kiln machine and angling the top baffle fans to create a corkscrew effect for the airflow to blow out the corners.  I’ve checked with my handy annemoter, and have very consistent airflow from one end to the other.  Heavy canvas drop down baffles that the carts slide under without doing any handling.  I couldn’t be happier, and if I needed 10 more kilns they would be in this configuration.
Stickered lumber, 4 packs, is loaded via pallets and forklift onto kiln carts and 3,000 lb loads of granite palletted and loaded in top of each stack. Then the carts are simply pushed into the kiln with the forklift. The L200M moisure prones are sweet.
I also have a stick built kiln, and it is a pain in the keyster.  Door seals, vents, concrete floors, etc, all cause trouble.
HobbyHardwoodAlabama.com
Offline jimbarry
    • WoodchuckCanuck
Re: Kiln Chamber
« Reply #5 on: February 01, 2019, 09:41:34 AM »
L200M. Bldg is 10x20x8ft.
Jim
WoodchuckCanuck.com ? Livin' the rural life in Nova Scotia.
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
question
Kiln Chamber
Started by Stump Jumper on Drying and Processing
Last post October 18, 2018, 10:40:32 AM
by K-Guy
Kiln chamber?
Started by Kevin_H. on Sawmills and Milling
Last post October 06, 2003, 05:39:39 PM
by Kevin_H.
12 X 8 X 8 KILN CHAMBER
Started by KDEC19 on Drying and Processing
Last post March 22, 2004, 05:11:24 PM
by Den Socling
Kiln chamber?
Started by Kevin_H. on General Board
by Kevin_H.
