Author Topic: Absence of limit cap  (Read 338 times)
Offline Air Lad
  • Onwards and upwards
« on: February 01, 2019, 05:19:45 AM »
Anyone considered using clear silicone around the screw head to prevent hi adjustment  shifting during operation when limit caps have been removed?Was not aware of them when I bought this saw 2nd hand.
I read somewhere that they can vibrate out of adjustment.
This one on MS260c is quite free in the thread.
Just an idea as the silicone is soft and would not hinder further adjustments later on as needed.
Cheers
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline Air Lad
Re: Absence of limit cap
« Reply #1 on: February 05, 2019, 05:05:07 AM »
No reply's could mean the subject is taboo. I dunno
I noticed the limit missing after fitting new carb diaphrams shortly after purchase.
Have adjusted and looked for movement
Doesn't seem to be any movement
The idea was to fill the screw head cavity with silicone once tuned to stop it winding in during use and cooking this little beauty
Is this a bad idea ?
Offline lxskllr
  • dummy with saw
« Reply #2 on: February 05, 2019, 07:42:11 AM »
I only have one saw I've used a fair amount without limit caps, and I haven't noticed the screws turning. That's an example of one, by one of the least experienced people here, so take it for what it's worth. Silicone /should/ work ok as a non destructive screw fix, but perhaps it's unnecessary.
Offline Gearbox
« Reply #3 on: February 05, 2019, 10:08:58 PM »
some of my saws have the limiter some don't . The limiter only limits adj. to a half turn . It has nothing to do with holding the adjustment . if your running your saw in north MN at 20 below and you run it at 75 above that half turn may not be enough.
Offline smmyb123
  • It's never the spark plug.
« Reply #4 on: February 09, 2019, 12:40:07 AM »
Limit caps are only something dealers and shops need to be worried about. Find a really small o-ring and install it on the adjuster screw to retain its position, some people also use a small piece of teflon tape.
Something else that could be considered is that carb body is worn out. The screw fitment should be snug enough to hold itself in place, the fact that yours doesnt indicates there may be enough space to cause air-leak symptoms and possible tuning issues.
Hello all, sorry for my prolonged absence.
Started by jjmk98k on General Board
Last post May 08, 2010, 06:57:58 AM
by Captain
Please excusse` long absence
Started by JoeyLowe on Sawmills and Milling
Last post April 19, 2002, 03:56:47 AM
by timberbeast
I'm back after a long, unwanted absence
Started by azmtnman on Sawmills and Milling
Last post September 27, 2017, 12:32:49 AM
by Brucer
What's your limit?
Started by Dave Shepard on Sawmills and Milling
Last post July 07, 2007, 12:14:53 AM
by WDH
