Tally-I/O
Author Topic: could my wood boiler be hooked to the oil boiler backwards  (Read 755 times)
Offline stumper
« on: February 01, 2019, 01:29:14 PM »
I replaced my Eclassic 2300 with a new edge 750.  However, I ma having issues with the oil boiler kicking on.  The run is the same, I replaced my circulator pump thinking it was weak.  I upped the temp in the wood boiler, but the oil boiler still kicks on frequently.  Before it only kicked on if the was a big issue with the wood boiler and the water temperature at the wood boiler was low, Now even with the wood boiler temp at 195 the oil boiler will kick on.  Is it possible we hooked the new boiler up backwards.  If I did would this cause the issues I am having?
Offline gspren
Re: could my wood boiler be hooked to the oil boiler backwards
« Reply #1 on: February 01, 2019, 08:32:32 PM »
How are they connected? Mine has a plate type heat exchanger so that the water from one to the other does not mix. If the heat exchanger gets plugged you might not get the proper heat transfer.
Offline stumper
« Reply #2 on: February 01, 2019, 09:11:47 PM »
There is no heat exchanger.  It is directly plumbed
Offline doctorb
  • Unofficial Team Physician
« Reply #3 on: February 01, 2019, 11:25:39 PM »
Do you have temp gauges on the inflow and outflow at the OWB as well as at the furnace?
Isnt the oil furnace a pressurized system and the OWB a non-pressurized system?  I didnt know they could be directly plumbed.
Offline stumper
« Reply #4 on: February 02, 2019, 08:28:40 AM »
Many oil boiler systems can the "de-pressurized" as long as your circulator pumps are pushing water through the base board.  There is no heat transfer lose.  It does take more chemicals but not a lot, and the cost of the extra chemicals is way less then the cost of a heat exchanger.
In reality my system is still somewhat pressurized as there is 12 to 15 feet of head at the oil boiler, because the wood boiler is that much higher then my oil boiler.
My oil boiler was set up with two extra ports, one at the bottom and one at the top.  So I have a circulator at the wood boiler that continuously pumps water through the oil boiler.
When the we hooked up the new boiler we had to extend the pex to the new location of the pump compartment at the wood boiler (side instead of back).  While we marked the lines I am just wondering if somehow they got reversed.
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #5 on: February 02, 2019, 08:38:10 AM »
We need some pictures of the plumbing at both boilers.
HeatMaster dealer support in VA.
GS100.
Offline stumper
« Reply #6 on: February 02, 2019, 12:06:47 PM »
I can try to take pictures and upload them later, but it is intended to be plumbed as shown in the installation guide for direct plumbed boilers.  Hot in the top of the oil boiler cold out the boiler.  The question is if the lines got reversed and I was adding hot at the bottom and pulling return out the top would that cause the issue I am experiencing.
Offline stumper
« Reply #7 on: February 02, 2019, 05:18:40 PM »
First picture is of the oil boiler.  lines on the right are from the wood boiler.  Second is at the wood boiler.
Offline boilerman101
« Reply #8 on: February 02, 2019, 07:05:53 PM »
Your pics look good at the Edge. I can't see the pump direction arrow, but I'm guessing you do have it pointed down. I too would think that if you did have lines crossed going into your oil boiler and feeding into the bottom it would lead to colder water running through your home. I take it that you do not have thermopex with the one line having the black line running the entire length to confirm which is which?
Offline stumper
« Reply #9 on: February 02, 2019, 07:55:27 PM »
My thermopex does have the black line.  However, to get from the original location the pex comes through the wood boiler concrete slab to where the 750 needed the line there were elbows and pex extensions put on.  While they were marked, I am concerned they got swapped.  As they thermopex is under the boiler there is no way for me to check.
« Reply #10 on: February 03, 2019, 02:41:03 PM »
Ok. Then maybe shut off the return line valve at your Edge and disconnect what you believe to be your "hot supply" line at your indoor boiler over a 5 gallon bucket and see if you have water flow from your pump. If not, it would confirm it is backwards and needs to be switched. Having a helper at the OWF with a cell phone to talk back and forth on would be helpful for turning pumps and valves off and on.
Offline wiam
« Reply #11 on: February 03, 2019, 07:36:12 PM »
Supply line should be hotter than return. Could be checked with a noncontact thermometer.
Offline E Yoder
« Reply #12 on: February 04, 2019, 10:47:12 AM »
Pump motor should be horizontal, not vertical. But I doubt that's causing your issues.
GS100.
Offline stumper
« Reply #13 on: February 04, 2019, 04:45:26 PM »
pump motor is horizontal, picture is rotated 90 degrees.
Offline E Yoder
« Reply #14 on: February 05, 2019, 07:08:31 AM »
Oh, wow, brain freeze. Sorry about that.
GS100.
Offline talldog
« Reply #15 on: February 08, 2019, 08:02:24 AM »
Stumper, Other than this issue,how do you like the new boiler so far?
moved
MOVED: wood and coal boiler for sale, oil boiler for sale
Started by WDH on For Sale
Last post January 13, 2016, 07:30:09 AM
by WDH
moved
Last post January 05, 2016, 08:31:40 PM
by WDH
Anyone with a new Central boiler Classic Edge Titanium series boiler yet?
Started by Logging logginglogging on Firewood and Wood Heating
Last post June 02, 2019, 04:32:03 PM
by WI Fire
Central Boiler - Maxim pellet boiler
Started by DDW_OR on Firewood and Wood Heating
Last post October 20, 2019, 03:01:47 PM
by thecfarm
