Author Topic: Killing PPB by freezing  (Read 267 times)
Offline jpm717
  • I'm new to milling!
« on: February 05, 2019, 02:01:17 PM »
I wrapped some boards with plastic wrap and put them in my freezer for 3 weeks  + and that seemed to kill the ppb. So far no sign of sawdust from the holes. Has anyone else try this?
Jerry
Offline GeneWengert-WoodDoc
Re: Killing PPB by freezing
« Reply #1 on: February 05, 2019, 03:52:33 PM »
I believe that this is not true if you are talking about the lyctid PPB that infects dry hardwoods, as the freezer has to be close to -40 degrees.  You need to kill both insects (larva) and eggs.  When the eggs hatch, a larva (looks like a small worm) tunnels into the wood.  It can be 2 years until they emerge from the wood.  They emerge most often when it gets warm after cold weather.  They are not active in cold weather or when they first warm up.  We do not know exactly what triggers their response to go from larva form to insect with wings and as an insect for them to tunnel to the surface and emerge in order to mate.
Online moodnacreek
  • Sawin by the notches
« Reply #2 on: February 05, 2019, 08:19:53 PM »
How about dead packing infested boards for a year or so they can't get out and start over?
Online tule peak timber
  • roborob
    • tule peak timber
« Reply #3 on: February 05, 2019, 08:28:03 PM »
Dr Gene is correct.We have had to kiln previously frozen woods from another vendor to kill ppb.Passing ppb can ruin a businesses reputation !
Offline Larry
« Reply #4 on: February 05, 2019, 09:07:37 PM »
Wood turners use a lot of junk wood loaded with bugs.  Several of us have been putting the turnings in the microwave with what seems like good results. No fresh fras has been observed after the nuking.
« Reply #5 on: February 06, 2019, 07:43:43 AM »
The lyctid PPB, that infects dry and mostly dry hardwoods and bamboo, is killed by heating to 133 F.  Such heating can easily be achieved in a microwave for small pieces.
Unfortunately, the ultimate test of any new or different treatment requires waiting two years to see if the insects leave the wood; that is, there is no way to determine if the lyctid PPB is still active unless we see exit holes, which may not develop until two years after the initial infection.  Usually, exiting does not occur until the wood is around 70 to 100 F.
 The insects are inactive when the wood is cooled to under about 50 F, but cooling does not kill them.
  • roborob
    • tule peak timber
« Reply #6 on: February 06, 2019, 08:56:33 AM »
For us that trigger is the warm fall weather condition call a "Santa Ana ". Wood assumed safe from insects suddenly comes alive after long periods of storage.Besides cleanliness , good kiln practices, I'm now going to use more preventive chemicals after milling -especially for certain high risk materials (ash , walnut , myrtle, etc). I've learned  the hard way >:(
How to Tell if the Temp is Above Freezing
Started by Norm on FOOD! FOOD! FOOD!
Last post February 14, 2011, 10:29:28 AM
by Burlkraft
below freezing saw lube
Started by W on Sawmills and Milling
Last post December 27, 2005, 10:03:54 AM
by Coon
Keep well lines from freezing?
Started by mitchstockdale on Firewood and Wood Heating
Last post December 21, 2018, 12:19:24 PM
by DelawhereJoe
question
Freezing Broccoli
Started by DanG on General Board
Last post November 16, 2005, 07:27:55 PM
by DanG
