Author Topic: oil type for motor sleeve shaft  (Read 301 times)
Offline curved-wood
« on: February 06, 2019, 12:00:34 PM »
I have a motor behind my wood stove which shaft run on sleeves. It has tubes so i could oil it. What type of oil should I use for an electric motor that run on sleeves ? I thought of the automatic transmission oil but is it too fine with the heat?
Offline mike_belben
  • Pulp Friction
Re: oil type for motor sleeve shaft
« Reply #1 on: February 06, 2019, 05:02:15 PM »
Any oil is better than none. Probably a high speed spindle oil.
Revelation 3:20
Offline Old Greenhorn
« Reply #2 on: February 06, 2019, 06:29:27 PM »
Those sleeves are most likely oil lite bushings. They are made of a porous bronze that is designed to capture oil and release it over time. Very similar to the circulator motors on hot water heat systems back in the 60's and earlier. These like to see something like a straight non-detergent 30 weight oil. No heavier. Sewing machine oil will work too. The burner service companies like Sid Harvey used to provide small amounts of this oil in neat little tubes which a screw cap to reseal it. I still have some of these. Please do not use transmission fluid, which is really hydraulic oil and is flammable besides not functioning well when it hearts up from friction. Just a couple of drop every once in a while, depending on run time. On a circulator that has a 10% duty cycle, maybe once or twice a year should do. If it has been dry for a long time, perhaps do it once a day for a few days until the bearing is refreshed, just a few drops. I hope that helps.
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline curved-wood
« Reply #3 on: February 07, 2019, 08:29:53 AM »
Good thing that you mention not a detergent oil, I was just going the opposite way thinking of cleaning the gum that could built up on the shaft.
Thank you for the info
« Reply #4 on: February 07, 2019, 09:59:01 AM »
That's why I suggested going heavy for a couple of days to flush that out. Then if you are regular with it, the bushings pretty much keep themselves clean. Bronze bearing bushings are pretty neat little passive devices.
Offline hedgerow
« Reply #5 on: February 07, 2019, 11:03:45 AM »
We always used Zoom spout turbine oil on all motors that needed oiled when I did maintenance at the plant where it was a motor in a condenser on the roof that saw -20 below to 100 in the summer or a motor in a cooler that was 36 degrees all the time to pump motors in the heating hot water systems. These motors got oiled on a PM once a year and I never saw a motor fail from lack of oil in 15 years I worked there.
Offline mburrow
« Reply #6 on: February 07, 2019, 11:14:10 AM »
i use 3 in 1 oil
3-In-One
« Reply #7 on: February 07, 2019, 12:24:53 PM »
Turbine oil is a high quality, very clean, light oil and should work just fine. 3-in-1 oil was still vegatble oil based last time I looked and that is not good for oil-lite bearings. It will clog the pores of the bronze. If you use 3-in-1 on a sharpening stone, you will notice after a time that you get a build-up on the stone and it needs to be cleaned. I stopped using that stuff for anything a very long time ago. If you have some sewing machine oil in the house, that will be perfect.
Offline trapper
« Reply #8 on: February 07, 2019, 10:24:32 PM »
i use 3 in 1 oil
3-In-One
That is what my father in law told me to use in the furnace blower motor and fan bushings The motor lasted over 30 years and the fan was still working at over 40 years old when we replaced the furnace this year.
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Online btulloh
« Reply #9 on: February 09, 2019, 09:18:11 AM »
3-In-One
Motor oil
HM126
Offline mburrow
« Reply #10 on: February 09, 2019, 11:04:19 AM »
Online btulloh
« Reply #11 on: February 09, 2019, 11:21:21 AM »
3 in 1 makes more than one type of oil.  One product is specifically a motor oil.
HM126
Winch-line Hook, ring type vs. sleeve type
Started by CuddleBugFirewood on Forestry and Logging
Last post March 23, 2013, 12:25:58 PM
by lumberjack48
Motor size & type
Started by jrokusek on Sawmills and Milling
Last post March 09, 2005, 05:42:25 PM
by Doc
Vertical shaft to horizontal shaft conversion
Started by Doc Hickory on Sawmills and Milling
Last post June 08, 2012, 05:29:36 PM
by Al_Smith
speedie sleeve
Started by duckslayingpro on Forestry and Logging
Last post April 09, 2013, 02:14:21 PM
by enigmaT120
