Author Topic: Alaskan sawmill curvy flitches  (Read 386 times)
Offline astevens
« on: February 06, 2019, 12:58:19 PM »
 I have a question about cutting curvy limbs with an Alaskan sawmill. I am in need of curvy oak flitches and was wondering if there is a rail system for the first pass that would fit on a curvy/oddshaped log?  After that it will be straight forward. If this has already been covered then let me know but I couldnít find much on the subject. Thanks
Offline mredden
Re: Alaskan sawmill curvy flitches
« Reply #1 on: February 06, 2019, 05:03:09 PM »
1. Ladders CAN work. All depends on how curvy.
2. You can build a cutaway frame around/above the curved log or limb to get your first cut. Plywood, jigsaw and 2x4 scraps. Just be careful on nail/screw placement.
3. Now, I'm just free-flow thinking here but it might be doable. Instead of thinking of using the mill traditionally from top/down, think of cutting from bottom/up. Make "sled shoes" for the bottom "feet" of the CSM that  (1) cover the bolt heads on bottom of the mill, (2) raise the powerhead above ground level, and (3) provides a slick, low friction surface. Sawdust might help. Push the mill through the log on a smooth, VERY flat surface like a paved driveway. Wedging will be even more important. Sucky knee work for the first cut. - I gotta' look at my mill tonight and see if this is a legitimately idea or just a brain fart. ;D
Offline offrink
« Reply #2 on: February 07, 2019, 09:18:56 AM »
This is how we do it. We had a custom rail made out of 1x4 solid aluminum. The cross braces are parallel to the ground with holes drilled in them at set spaces. Then we can take a bold and jam nut it at whatever legnth we need to make it level and solid across the log. Once cut remove the bolts and use like normal.
Offline astevens
« Reply #3 on: February 11, 2019, 11:09:06 AM »
Ok Thanks for the ideas
Alaskan Sawmill ?
Started by yetti462 on Sawmills and Milling
Last post December 10, 2018, 12:01:53 AM
by Brucer
Alaskan Sawmill?
Started by JimNAZ on Sawmills and Milling
Last post August 09, 2014, 09:46:06 PM
by AllanLindh
Alaskan Sawmill Question
Started by Trees_rock on Sawmills and Milling
Last post August 30, 2010, 05:32:30 AM
by weisyboy
alaskan sawmill info.
Started by old_hb on Sawmills and Milling
Last post February 22, 2004, 10:47:56 PM
by Stan
