Author Topic: woodmizer blade tilt  (Read 364 times)
Offline trickycoyote
  • Member*
« on: February 06, 2019, 02:08:42 PM »
Hi everyone, my first post here.
We have a 1992 LT-30 electric with 8000 hours. We just got it up and running recently. We had a woodmizer tech come out and help us get it adjusted and he said we should set the blade height an 1/8" higher at the outside than the inside guide. My manual doesn't say this. I've seen in another place to adjust it to 1/16" higher.
Also, the tech said that the blade should be angled front to back but I can't find my notes about what he said. I think he said it should be 1/16" lower at the leading edge. I can't find anyone talking about this tilt so I'm a bit confused.
Any thoughts on either of these adjustments would be appreciated. By the way, the saw is diving right now. We milled about 1000 bf so far with few problems (ok, except for all the mistakes we made...) but after sawing into the log holder (oops) and changing the blade, the diving began.
Thank you!
Offline Chuck White
  • Sawing Mobile since 2005
Re: woodmizer blade tilt
« Reply #1 on: February 06, 2019, 02:28:47 PM »
Welcome to the Forestry Forum, trickycoyote!
In the book for my mill (LT40) it says the tilt is to be adjusted to 1/16" higher on the idle side!
2/7/19 EDIT:  The adjustment I mentioned above is referred to as "Saw Head Tilt"!
~Chuck~
I LOVE MY SAWMILL
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: February 06, 2019, 02:55:18 PM »
    And when I got mine I was shown how to make sure the blade was level with the bed of the mill when it enters the log, with no tilt. The height on the idle side is adjusted to be higher than the drive side. I use the blade guide tilt tool that came with the mill to check and adjust that. That is what my manual shows too.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
« Reply #3 on: February 06, 2019, 07:34:44 PM »
TrickyCoyote,
not sure about your specific model, i have the LT15 Wide mill by WM, its set up like WV Sawmiller mentions, using the blade alignment tool, blade is level with bed, no tilt.  My manual (again not specific for what your mill is) shows if issues with a non square cut in very large hard woods, to adjust the outside guide a 1/16" to 1/8" higher then the drive side due to the unit will have a tendency to pull down on the inside of the cut and makes the cut out of square or level.  I currently have the mill set up with no difference between the two roller guides and the deck.  the widest i have cut so far is 30" and the unit did not tilt down as the manual mentions it might under certain circumstances.
Sharp blades, proper tension, and proper down deflection on the roller guides would be the first few things i would look at and then have another try at some additional cuts.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: February 06, 2019, 09:34:05 PM »
The horizontal blade guide tilt is probably what was referred to and is what is causing confusion.  This has nothing to do with the blade being absolutely level with the sawmill bed and the idle side being 1/16" higher than the drive side.
Proper terminology must be used or there will be confusion.  The owners manual shows the proper alignment procedure for the horizontal blade guide tilt as well as using the "blade guide alignment tool".
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #5 on: February 06, 2019, 10:31:11 PM »
Part #LTBGAT. You can also buy a 1/8"x1" aluminum bar a couple of feet long and a rubber band.
Tilt on blade wheels
Started by welderskelter on Sawmills and Milling
Last post July 01, 2018, 06:59:09 AM
by ladylake
Dozer blade adding tilt
Started by DMcCoy on Forestry and Logging
Last post February 18, 2017, 08:26:51 AM
by aussie380
Left Tilt vrs Right Tilt
Started by mhasel on Drying and Processing
Last post March 10, 2004, 05:57:59 AM
by SasquatchMan
Tilt trailer help
Started by KirkD on General Board
Last post February 19, 2017, 10:46:12 AM
by Ox
