Author Topic: A SINGLE badly damaged cutter  (Read 617 times)
Offline mredden
« on: February 07, 2019, 11:15:10 AM »
I have a relatively new chain that has one VERY badly damaged cutter. Chipped beyong the witness mark! Rest of the chain is solid. Older threads indicate that you can still use the chain if you grind off the damaged cutter.
My primary question is: Do you need to do anything else after you grind off the cutter? What do you do with the rakers before and after the now-missing cutter? Do you need to do anything to the two cutters on either side of the now-missing cutter to balance out the chain?
Thanks for any help to a newbie like me.
Offline doc henderson
Re: A SINGLE badly damaged cutter
« Reply #1 on: February 07, 2019, 11:27:57 AM »
I would start by getting the bad cutter out of the way, I think you need the rakers to keep the chain on an even path across the cut. give it a try, it may be your dirty jobs chain, if it works ok
Offline luvmexfood
« Reply #2 on: February 07, 2019, 11:40:42 AM »
If you have anyone in the area that makes chains they can replace the link for you. Not sure about using a different type of chain but as long as it is the same no problem.
Give me a new saw chain and I can find you a rock in a heartbeat.
Offline sawguy21
« Reply #3 on: February 07, 2019, 11:48:41 AM »
I would grind out the bad cutter and carry on, I doubt you will notice much difference.
Offline mredden
« Reply #4 on: February 07, 2019, 12:32:50 PM »
I have a pocket breaker and some straps, but no extra cutters. It's a 32" chain. I have thought about cutting it down to a 24' inch chain, but I hate to not have a backup for my one good 3" chain. I rarely cut under 30" except when limbing, so 32" is my favorite size.
Only guy who makes loops locally is the repair man for the local Husqvarna dealer. I have no idea what they would charge for a cutter, strap(s) and his time - they ain't cheap on anything I know of.
« Reply #5 on: February 07, 2019, 01:23:18 PM »
Use it as is if it works, If not go buy another chain.  Thems the breaks! :D
Offline Skip
  • Saw hard or stay home.
« Reply #6 on: February 07, 2019, 02:02:31 PM »
Cut the bad one out and keep on truckin. You have the start of a skip tooth chain .
Offline thecfarm
« Reply #7 on: February 07, 2019, 02:54:33 PM »
I had a bad one,just once. It was bent. :o  ???  I just ground it off and kept on using it. I never even knew it was gone.
« Reply #8 on: February 07, 2019, 02:56:25 PM »
Is that why they  call you Skip?!lol .
Offline mredden
« Reply #9 on: February 08, 2019, 06:10:44 AM »
And the cutter is gone!
Thanks everybody!
Offline barbender
« Reply #10 on: February 08, 2019, 10:17:23 AM »
Grind the cutter off the rest of the way and carry on. Don't make a mountain of a molehill, you'll soon forget it's even missing 👍
Offline luvmexfood
« Reply #11 on: February 08, 2019, 10:35:47 PM »
They should have some off pieces laying around they would give you. But like everyone else said I have never noticed an difference using one with a broken tooth. Heck. I got some broken teeth and it don't slow my eating down any.
Offline sawguy21
« Reply #12 on: February 09, 2019, 12:20:29 PM »
 :D :D
Offline gspren
« Reply #13 on: February 09, 2019, 07:50:05 PM »
A missing tooth gives a good place to start when filing, easy to spot when you've gone the whole way around.
clip
Chainsaw piston badly damaged
Started by Rik on Chainsaws
Last post March 08, 2018, 11:54:27 AM
by Mad Professor
Tear out on Single cutter bits
Started by mmhailey on Timber Framing/Log construction
Last post December 01, 2008, 05:54:12 PM
by Jim_Rogers
Sawyer gets hurt badly...
Started by zopi on Health and Safety
Last post June 30, 2012, 02:10:34 AM
by giant splinter
slabs that split badly overnight
Started by bkaimwood on Sawmills and Milling
Last post May 12, 2015, 10:43:34 AM
by beenthere
