Author Topic: Ripping chain okay to cross cut too?  (Read 298 times)
Offline wspier
  • Member*
« on: February 07, 2019, 02:12:28 PM »
Looking to use a Husky 3120 with a CannonBar and ripping chain for milling. Is it okay or a no-no, to use the same bar and chain to also fell the tree and prep trim the trunk for milling? Or should I have a second, dedicated saw (or at least another std chain) for that? I won't be using it to cross cut countless times like one would use for firewood. Thank you!
Offline offrink
Re: Ripping chain okay to cross cut too?
« Reply #1 on: February 07, 2019, 04:38:28 PM »
It will be slower but ok. It may dull your chain that you want to use to mill. A standard chain is about 30 and a milling chain is 10.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #2 on: February 07, 2019, 08:25:28 PM »
Myself I would leave the mill-bar-chain assembly together and remove the saw, use a different bar/chain for felling.  I would want the highest performance for felling and limbing.  And the bar will not have to be as long as that being used to mill. But will a rip chain cross-cut? Sure.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline charles mann
« Reply #3 on: February 07, 2019, 09:06:43 PM »
yes, it will work, but as already stated, slower. iv even used a cross cut chain to rip, just to see if it would, and it does work, but a lot more aggressive and didn't produce near the finish as a ripping chain. i use the same bar for both felling and ripping, mostly bc i want to cut all the way through in 2 cuts, rather than the face cut, then several back cuts. teat-for-tat, 6 1 way, half a dozen the other, as for the bar.
Temple, Tx
ripping chain
Started by steve phillips on Chainsaws
Last post January 30, 2012, 05:26:31 PM
by hamish
Ripping chain
Started by chainspinrunner on Chainsaws
Last post December 11, 2010, 07:29:27 AM
by Al_Smith
where to buy ripping chain
Started by oakiemac on Sawmills and Milling
Last post December 20, 2018, 07:41:11 PM
by charles mann
ripping chain
Started by etat on Chainsaws
Last post January 09, 2004, 11:09:55 AM
by woodbeard
