Author Topic: Very Durable Portable Generator  (Read 1195 times)
Offline Percy
  • Resident trouble maker
« on: February 08, 2019, 10:31:13 AM »
4 years ago almost to the date, I bought a Briggs and Stratton "Elite " portable generator rated at 8000 running, 10,000 starting watts. Its a 15 hp model. Cost 1099.00 Canadian which would be around 750.00 US.  THis thing runs every day for around 8 hours. Uses around 20 liters(5 gallons) of purple gas and powers sawdust conveyor(2 hp) and roll case(3 hp) and compressor (2 hp) along with lights and BMS250 and grindstones, drill press, yaddayadda. It has used oil since new, enough that I dont change it, just add a quart every month of the same I put in everything else..15-40 diesel engine oil. I change the air filter every couple months. I have a boneyard of broken down old generators of various offshore brands that pre dated this one and I use for parts as they all seem to be clones of eachother.
I have had to change the brushes several times and lately, all the springs that control the throttle and governor are busting from old age and vibration. I have lots of used parts.
Point of this thread is...this particular brand/model of offshore type generators seem to be a cut above the rest...Well over 4000 hours on it and going strong.
Offline John S
Re: Very Durable Portable Generator
« Reply #1 on: February 08, 2019, 10:37:16 AM »
I am impressed!
2018 LT40HDG38 Wide
Offline Old Greenhorn
« Reply #2 on: February 08, 2019, 11:21:25 AM »
SWEEETTTT! You got lucky and found a winner. I wish all gear would run like that. The stuff they make today seems to have the 'throw out and buy another' attitude toward design and build. 2 years ago I bought a gas water pump, just 120 GPM for a specific task. I set it up, test ran the system, everything was good. Arrived at the 'job' and it ran just 45 minutes before the rocker arm snapped off. Ruined my weekend and made a lot of unplanned labor for the rest of the crew moving water all weekend.
 After the fact, the seller would not even answer emails. I finally found a clone part on ebay and took a chance. Perfect fit. When I was doing the repair, I noticed the un-broken rocker arm was too tight (no clearance), and I am assuming the one that broke was the same. So, the defect came from the factory. I since have put about 100 hours on that pump without a glitch, and the pump performed that same duty it was bought for, the following year.
 You find something that runs, take care of it, and it will take care of you. Which reminds me, I should probably make sure I drained the water out of that puppy, but if I didn't, it might be too late.  ;D
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline sawguy21
« Reply #3 on: February 08, 2019, 02:39:53 PM »
Percy, you have had exceptional service from a piece of equipment that was designed for occasional use. Your dollar was well spent.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #4 on: February 08, 2019, 05:09:21 PM »
That Briggs engine (of the Vanguard / Intek family) is one of the most durable engines out there.  Running it for long periods is probably your best bet for long life as it gets hot enough to boil out any moisture that might accumulate in the crankcase.  It also ensures that you always have fresh fuel in it, thereby avoiding the risk of stale fuel contamination of the carb.  Some years ago Briggs bought the residential generator division of Generac.  Generac always built top end stuff, so "if" the power generating end of yours is indeed a Generac then you have a good unit.
Keep running it.
If it was me I'd change the oil (and filter if there is one) just to flush out any accumulated dirt - not because of any deterioration of the oil ...
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
TECH: portable electric mill, powered by portable electric generator
Started by woodbowl on Sawmills and Milling
Last post July 16, 2005, 06:11:01 AM
by rebocardo
Most durable softwood?
Started by jph on Drying and Processing
Last post May 13, 2005, 11:12:14 AM
by beenthere
A more durable driveway
Started by tyb525 on Alternative methods and solutions
Last post April 25, 2011, 05:00:35 AM
by Al_Smith
Bibs - which brand is the most durable?
Started by Ox on General Board
Last post January 26, 2016, 08:59:40 PM
by Ox
