Author Topic: MS250  (Read 1073 times)
Offline Doug Rubey
  • grettings
MS250
« on: February 09, 2019, 10:45:08 AM »
I have two ms 250 I keep in my farm trucks to clear limbs and such off my pasture fences can't get the things to oil the bar changed the pumps tried different oils no luck, any suggestions to cure this. I have 4 other stihl saws but there way to big and heavy for fence line work.
Doug
Offline sawguy21
Re: MS250
« Reply #1 on: February 09, 2019, 12:13:38 PM »
Welcome!! It sounds strange that both have failed. Are the saws stored outside in the cold? Maybe you need to cut the oil with diesel.
Offline John Mc
Re: MS250
« Reply #2 on: February 09, 2019, 03:23:16 PM »
Welcome to the forum, Doug!
Offline Doug Rubey
  • grettings
Re: MS250
« Reply #3 on: February 09, 2019, 04:08:34 PM »
Thanks for the response yes all my saws are keeped outside in the shed I have tried every kind of oil I have here on the the farm weather does not mater hot or cold temps.the other stihl saws I no problem with  saws are 031 av ms280 036 pro 044 mag.nothing wrong with the other saws using the same bar oil.
Doug
Offline dougand3
Re: MS250
« Reply #4 on: February 09, 2019, 04:54:07 PM »
You changed the pumps? How about the nylon worm gear? It has the J shaped spring that fits in the drum slot to rotate and drive the pump. Nylon is what normally wears and won't turn pump.
Maybe the oil tube out of the tank is clogged?
Husky: 372xt, 272xp, 61, 55 (x3) Stihl: 026, 011AVT Poulan: 315, 4218 (x3), 2375, 2150, 2055, 2000 (x3) Homelite XL
Offline philipxxx
Re: MS250
« Reply #5 on: February 09, 2019, 06:09:13 PM »
It maybe oiling but you cant see it...this happened on my husky/////////  take bar and chain off saws  run and see if oil comes out the holes..... that's what I did//// if it does......clean your bar/
Offline wild262
Re: MS250
« Reply #6 on: February 09, 2019, 10:18:07 PM »
Run your saw with the end of the bar close to a white or light colored surface, and run wide open for a few seconds.  If its oiling, it will leave a line of oil on that surface.  If not, than its not oiling.  Stihl does make a high output oiler for that saw.  I will try and find the part number tomarow.
Offline Air Lad
  • Onwards and upwards
Re: MS250
« Reply #7 on: February 10, 2019, 05:20:44 AM »
A person such as yourself who has a number of machines to use would notice if one isn't oiling because you have the others to gain comparison from.
You can tell as it starts to look dry and hot then needs tightening a bit more than usual
You will sort it out Doug
Cheers mate
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline limbwood
Re: MS250
« Reply #8 on: February 10, 2019, 09:16:38 AM »
hold the plastic worm gear in your hand tightly and try to spin wire, if you can move it by hand it needs to be replaced. the wire will spin but gear wont turn so no oil is pumped.
Offline Doug Rubey
  • grettings
Re: MS250
« Reply #9 on: February 10, 2019, 11:09:20 AM »
most of the things everyone mentioned I, already tried except the worm gear don't remember if I changed it thanks for all your help i will let you know what I did if I get it figured out
Doug
Offline realzed
  • Old Fart but - I'm new!
Re: MS250
« Reply #10 on: February 10, 2019, 01:07:11 PM »
Don't recall that you mentioned the bar/chain getting hot with use - but I certainly would expect with any amount of cutting either or both would obviously show signs of heating up - assuming a no oil situation.
If you are using Stihl oil it is very hard to detect these days verses cheaper/thinner oils on the market, but if your saw is rev'd up any decent length of time the inside of the chain case should show some level of oil coating if it is pumping out any oil at all!
Again with the new type of Stihl oil (if that is what you are using) the oil hole in the bar and the bar slot has to be super clean to make whatever oil does get pumped is useful and apparent because it certainly doesn't flow or even show up if it is, like it did previously!
Offline doc henderson
Re: MS250
« Reply #11 on: February 10, 2019, 01:17:40 PM »
Stihl has several bar oils.  the old orange jug, the premium silver jug, and  a blue low viscosity winter oil.  you can rev the saw near a piece of wood pointing the tip of the bar at it.  it will sling the oil going around the bar tip and you should see it on the board.  My worm gear broke on my 046 when it got sawdust packed in there mixed with oil.
Offline Doug Rubey
  • grettings
Re: MS250
« Reply #12 on: February 10, 2019, 02:38:21 PM »
yes the bar and chain do heat up rapidly to the extent the clutch will not turn the chain i  shut them down at that point.I have never used the stihl bar oil but may try it just to see if it does make a difference. Thanks for the help
Doug
Offline joe_indi
  • The older I get the more I learn
Re: MS250
« Reply #13 on: February 10, 2019, 08:40:13 PM »
Is the clutch drums 'dancing' on the crankshaft? If it is then the oil worm drive might be jumping out of its groove on the drum.
As a temporary fix for this you can bend the drive upwards to engage the drum moremor
Offline Allar
  • Firewood Warrior!
Re: MS250
« Reply #14 on: February 11, 2019, 06:31:03 AM »
The worm gear on stihl ms250 is made of plastic and could easly have stripped threads.
Assuming that you checked your oil lines/filter for blockage, worm gear is your best bet.
Firewood & Chainsaw videos: Firewood Warrior - YouTube
Re: MS250
« Reply #15 on: February 11, 2019, 11:44:37 AM »
here are the two bar oils I use, the oil in the blue winter jug is thinner.  I also buy the on/off spouts so I do not get oil all over the saw and or floor.  I think they are few bucks on amazon.  cause my uncle always ends up wanting what I have, I order 5 at a time on amazon.  works great on most gallon jugs.  I use one on the brake fluid for my 76 ford f700 state dump truck.  It leaks a little when sitting and the master cylinder is on the firewall, back at the low spot under the hood.  I switch the spout back and forth, and have 2 new ones on hand.
Offline Fishnuts2
  • I'm working my way through retirement!
Re: MS250
« Reply #16 on: February 13, 2019, 09:01:52 AM »
I've had a 250 that the clutch drum bearing was shot from a lack of grease.  It allowed the clutch drum to have enough wobble as to not engage the pump drive.  Might be worth checking regardless.
Offline Loggerpro.
Re: MS250
« Reply #17 on: February 13, 2019, 01:43:45 PM »
Phew, I've  actually sprained 2 fingers trying to start a friends ms 250, I very much dislike the model.
I'm not elderly either hehe.  I would not try to fix those, I would just buy a 241c and be done with the hassle. The models I mostly use these days are the 180 c....with a 14 inch bar( the 050 bar and yellow chain )   for limbing and for the bigger limbs a 261c with a 18 inch on that.  That's my 2 cents.
Wish husky would stop making saws with outboard clutches , such a pain to clean and fit chains ! just thinking out loud.
Offline Doug Rubey
  • grettings
Re: MS250
« Reply #18 on: February 14, 2019, 03:36:58 AM »
I use to have a husky 346 xp real nice saw but i got a little carried away with the rpms and blew it up they quit making them so I just replaced it with the two ms250s
Doug
Offline firefighter ontheside
  • I like trees.
Re: MS250
« Reply #19 on: February 14, 2019, 10:26:04 PM »
The Stihl winter bar oil has not been available around here this winter. :-(
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
MS250 gets hot
Started by Delirium on Chainsaws
Last post December 21, 2014, 05:42:20 PM
by CTYank
MS250 Muffler Mod
Started by MAF143 on Chainsaws
Last post December 10, 2018, 08:19:48 PM
by lxskllr
MS250 Problem
Started by thechknhwk on Chainsaws
Last post September 24, 2012, 02:02:17 PM
by lumberjack48
Stihl MS250
Started by oscar4749 on Chainsaws
Last post October 05, 2012, 08:36:53 AM
by ladylake
