Author Topic: Woodmizer LT40 28 Kohler how to reset ECU  (Read 493 times)
Offline jovol
« on: February 09, 2019, 12:43:10 PM »
I replaced the O2 sensor on my 28HP Kohler Command, and I started adjusting the idle RPM since they were very low. Now, the engine RPMS oscillate over a period of like 10-15 seconds. I think I need to reset the ECU and do the "TPS learn procedure". The Kohler service manual has directions on shorting two wires together, turning the key on-off for 10 sec, and that should reset the ECU, but the wiring diagrams don't match up to my Bosch ECU, so I don't know which wires to short together. Anyone successfully done this before?
Thanks, John
WM LT40HD, ms250, ms661 42” granberg, Logrite fetching arch
Offline Ben Cut-wright
  • I'm new here! I'm old everywhere else
Re: Woodmizer LT40 28 Kohler how to reset ECU
« Reply #1 on: February 10, 2019, 10:18:22 PM »
Not sure what you mean by "wiring diagrams don't match up"?  Why did you replace the O2 sensor?
These instructions are in the manual for that engine.
Reset:
1.  Connect (jumper) white wire to black wire in four way diagnostic port.
2. Turn key on, then off for ten seconds.
3. Turn key on, then off for ten seconds a second time.
TPS learn:
1. Turn idle screw clockwise one full turn prior to key ON after ECU Reset.
2. Start engine, run at low idle until engine is warm.
3. Idle speed must be above 1500 RPM. If below 1500 RPM, turn idle screw up to 1700 RPM and then shut down engine and perform ECU Reset again.
4. Adjust idle speed down to 1500 RPM. Allow engine to dwell at 1500 RPM for about 3 seconds.
5. After this, adjust idle speed to final specified speed setting.
6. Turn key OFF for 10 seconds.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #2 on: February 11, 2019, 05:12:55 PM »
I was going to look this up and take it out of the book. Ben has it done.
Marty
I would check the TPS and the throttle plates make sure the screws on the plates are not loose.
“A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty.” -Winston Churchill
Broken Crankshaft on Kohler 25 HP on LT40 HYD
Started by DR_Buck on Sawmills and Milling
Last post June 14, 2017, 11:08:06 PM
by Gary_C
Guess I will settle for a 25 HP Kohler to repower my 92 LT40 HD
Started by RayMO on Sawmills and Milling
Last post October 07, 2013, 06:35:32 PM
by RayMO
Kohler on a Woodmizer.
Started by DJL50 on Sawmills and Milling
Last post February 28, 2009, 07:06:59 PM
by MartyParsons
Woodmizer LT28 19 HP Kohler ready for pickup. Is powerfeed a good choice?
Started by Subururban600 on Sawmills and Milling
Last post June 06, 2018, 03:38:52 PM
by CX3
