Author Topic: Dolmar 5105 have spring assist?  (Read 170 times)
Offline MNBobcat
« on: February 09, 2019, 07:49:11 PM »
The Dolmar 5105 has "easy start" but the one I looked at did not work like my 6100 where you pull slow once and on the second pull the spring starts it.   Does anyone know if it has spring assist?  I didn't notice easy start doing anything
Offline Wallydawg
Re: Dolmar 5105 have spring assist?
« Reply #1 on: February 10, 2019, 03:41:08 PM »
I have a rebranded 5105, a Maruyama, but identical and it has some kind of wind-up system. It generally takes to the third pull to fire up cold. Just pull thru slowly a couple of times and usually the third pull vroom. It took a little to get used to this procedure, as I was used to drop starting larger displacement saws. It's a great little saw and has become my go-to, as my 044 has gained compression in direct relation to my pullability :D I found out the procedure from the manual: whoduh thunk ::)
They say I'm lazy, but it takes all my time. - Joe Walsh -
Timberking 1400M
Dolmar ps-5105?
Started by gman98 on Chainsaws
Last post February 02, 2018, 07:02:31 PM
by ehp
Dolmar 5105 questions
Started by STIHLFULLSKIP on Chainsaws
Last post June 01, 2015, 05:53:43 PM
by Hilltop366
dolmar 5105 filter question
Started by gunscrew on Chainsaws
Last post September 25, 2018, 12:29:52 PM
by gunscrew
Hot start troubles Dolmar 5105
Started by maple man on Chainsaws
Last post March 29, 2017, 04:01:04 PM
by Kel71
