Author Topic: Cat choker for skidding firewood  (Read 501 times)
Offline Zackary
« on: February 10, 2019, 07:21:31 PM »
I have a Norse 350 winch that I use  on my JD 820  for skidding  firewood . I use 5/16 choker chain but sometimes when skidding smaller diameter firewood poles, - 6-8" dbh,especially if I have 2-3 poles bound with one chain, they often come loose. I thought about trying to use a cat choker to bundle them and the attach them to my winch line. Any experience/ advice greatly appreciated. Zackary
Offline Gearbox
Re: Cat choker for skidding firewood
« Reply #1 on: February 10, 2019, 07:39:35 PM »
wrap your choker around twice and try that . I use 1/2 inch cable chokers and it works for me mostly . sometimes it takes a couple of trips to get all the smalls to the landing .
Offline mike_belben
  • Pulp Friction
« Reply #2 on: February 10, 2019, 08:16:50 PM »
Ask an arborist for a few scraps off his old climbing or bull rope.. Theyre high dollar high strength ropes and should be replaced often so theyve always got more hanks of old rope than needed.  Cut those into chokers with your favorite termination on one end and a bowline or whatever on the other.  Theyll bite small stuff like no chain or cable can.  12" on down i use rope. Never falls off.
Revelation 3:20
Offline thecfarm
« Reply #3 on: February 10, 2019, 10:09:30 PM »
I run 6 slides on my 450 Norse winch,the hook on the end I use too,so I can hook up 7 logs. I can see where hooking up 3 logs and having one come out would happen. What I do is hook up one small log,than I wrap the chain around the second one and have the chain behind the one that is hooked. Hard to explain,but it works. I myself would add more slides,that is why I have 6.
I also made up some 4 foot chains for the small stuff. This helps me from pulling 4 feet of chain through a keyhole.
And I just thought of something else that helps me.Hook the chains up short and winch them up as high as you can. Sometimes when I am down in a hole,the load will get slack and I loose some of my logs. Keeping the chains short and high helps that from happening.
Offline Frozendozer
  • Frustrated wood cutter
« Reply #4 on: February 10, 2019, 11:57:38 PM »
I used chain chokers on my dozer and found that wrapping more then two trees always resulted on a loss  .  If I pull from the tops I usually cut a notch so the chain can slip inside .
Online Old Greenhorn
« Reply #5 on: February 11, 2019, 07:34:13 PM »
I assume you are using a C Hook on your choker? I have fond the two wrap method works pretty good with a slip (C) hook. Sometimes I do a full turn on the single smallest log, that's the one that usually slips free, and then a full turn on the hitch, more if I have chain.
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
choker
Started by henry co. on Forestry and Logging
Last post December 25, 2015, 01:39:26 PM
by HiTech
choker cable where to buy?
Started by davefrommd on Chainsaws
Last post March 17, 2005, 09:25:25 AM
by davefrommd
choker hooks where to buy?
Started by weisyboy on Forestry and Logging
Last post February 09, 2011, 12:42:33 AM
by HCF
Choker cable
Started by Ga Mtn Man on Forestry and Logging
Last post October 16, 2012, 10:58:38 PM
by thenorthman
