Council Tool
Author Topic: Shed start  (Read 707 times)
Offline hopm
Shed start
« on: February 10, 2019, 10:59:43 PM »
I bought a carport shed to go over my mill.....full up.....built another shed.....full up....started this on Saturday. Got poles in the ground and set 1st truss. Proud to have it up but I'm even happier for what I learned doing it.
Offline 123maxbars
    • www.outofthewoodsforestry.com
Re: Shed start
« Reply #1 on: February 10, 2019, 11:13:36 PM »
Good start! PT Post?
A problem I have also, I need another pole barn for all my tractors,
keep us posted, when your done you can come help on mine  ;D
Sawyer/woodworker/logger
W/M LT35HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline xlogger
Re: Shed start
« Reply #2 on: February 11, 2019, 05:32:02 AM »
I plan on replacing a shed like you are using also (30x60). My other one collapsed during a snow storm we had here before Christmas. Plans calls 12 ft spacing on post. Is that what you are doing? I cut my 2x6's and sticker them a couple weeks ago but will put them up not dried. I'm also going to cut board and batten for side but will put boards up straight off saw as I cut. I worry about the new pt post not holding up as good as they use to, but at my age they should out last me.
Offline hopm
Re: Shed start
« Reply #3 on: February 11, 2019, 08:10:29 AM »
Mine are 10' on center.
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Shed start
« Reply #4 on: February 11, 2019, 08:15:48 AM »
Hopm, where are you located? what does one of those trusses cost?
Offline hopm
Re: Shed start
« Reply #5 on: February 11, 2019, 11:59:26 AM »
I was fortunate to buy a full kit that someone special ordered and stiffed them on......so based on my purchase I'm not sure.....but I do remember faintly seeing on the Moseley Metals site $11 per foot and they build up to 90' open span.
We call western NC home.
Offline Dad2FourWI
  • I love my job
Re: Shed start
« Reply #6 on: February 11, 2019, 04:28:53 PM »
Looking good!!
You can never have too much barn/shed space!!!
Keep us updated with pics of your progress...
LT-40, LT-10, Bobcat T750 CTL, Ford 1910 tractor, tree farmer
Offline rjwoelk
    • countrysidefirewood
Re: Shed start
« Reply #7 on: February 11, 2019, 04:41:56 PM »
In Saskatchewan we run 8ft spacing on pole barns. 6x6  poles . rafters are a truss 4 ft oc. Strap and tin. They use to be 4ft in the ground. Now with global warming they want them 6 ft in the ground with a 16x16 pad of concrete at the bottom. Something dont make sense.  Yup told the frost was going deeper. Wow.
Offline xlogger
Re: Shed start
« Reply #8 on: February 11, 2019, 05:11:05 PM »
here in NC around $340 for 30 ft
wood shed and generator shed.
Started by haywire woodlot on Sawmills and Milling
Last post October 09, 2012, 06:32:40 AM
by Magicman
cat will start
Started by woodmills1 on Sawmills and Milling
Last post February 13, 2010, 11:16:18 PM
by woodmills1
where to start ?
Started by sawwood on Sawmills and Milling
Last post April 10, 2004, 04:22:37 PM
by ARKANSAWYER
Bad start to the day
Started by Woodboogah on Forestry and Logging
Last post August 13, 2014, 08:23:42 AM
by Woodboogah
