Author Topic: Cold/hot weather covers  (Read 402 times)
Offline Air Lad
  • Onwards and upwards
« on: February 11, 2019, 04:57:12 AM »
Noticed after looking at a mates 029 that it has some things that my 039 doesn't
Mine has the plastic rear slide in cover that has mesh on one side and blanked out plastic on the other (like a piece of angle iron).
His has a piece of rubber ring around the spark plug and a flap that slides into a keeper.
Then I look at the 260c and can see there are some things missing as well
Could someone explain what I need for  036 and 260c for hot conditions
Looking at 40 C on wednsday...104 to you guys
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline lxskllr
  • dummy with saw
Re: Cold/hot weather covers
« Reply #1 on: February 11, 2019, 07:04:37 AM »
Looking online, I found this in the Stihl manuals. It's the same for both saws...
Honestly, I find Stihl's setup confusing with regards to manual pics, and iconography on the saw, but if you compare the pics with what's on the saw, the gist is you want to block hot air from getting to the carb. If you're missing the pieces that block hot air, you may be able to make your own out of plastic, or just use something like duct tape. The Stihl manuals are available on their website.
edit:
BTW, if you want my personal recommendation for cutting in those temps...
Take your saw, and put it on the front seat of your car. Drive to the nearest pub and carry the saw inside. Place it on the barstool next to you, and have a beer. Repeat until the weather's reasonable for cutting wood  ;^)
Offline HolmenTree
« Reply #2 on: February 11, 2019, 12:19:24 PM »
It's a Stihl it will work fine in 40C/105f heat. Just make sure the airbox shutter is closed so no heat gets back to the carb.
Make sure the air filter and cylinder fins are clean . Same with the spark arrestor screen in the muffler.
Removing the rear cover so the air filter is out in the open may help too.
Run 32:1 or 40:1 fuel mix.
Sharp chain always.
Offline Air Lad
« Reply #3 on: February 11, 2019, 03:23:28 PM »
Thanks for the help blokes
It makes sense now
Probably won't be running them on Wednesday but
the instructions said temps over 20 deg C use the covers
I have been using 40/1 semi synthetic with a fuel additive in
non ethanol 91 with no issues
Cut a fair few rings to help a mate on Saturday and it
 wasn't 40 but it was still hot.
Cheers
Need some cold weather!
Started by reswire on General Board
Last post August 26, 2014, 10:00:36 AM
by red oaks lumber
question
Cold weather clothing
Started by Larry on General Board
Last post January 15, 2010, 10:40:39 PM
by SwampDonkey
648 cold weather start
Started by timberjack 450 on Forestry and Logging
Last post February 19, 2015, 02:44:05 PM
by jnicol6600
Cold Weather Cooking
Started by Norm on FOOD! FOOD! FOOD!
Last post January 03, 2010, 03:09:38 PM
by Chris Burchfield
