Author Topic: All Terrain Dump Trailer  (Read 2049 times)
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« on: February 11, 2019, 05:34:39 PM »
Hello,
  Here are some pictures of the All Terrain Trailer from Logrite Tools!
I did add some bolts and wing nuts to keep the sides from moving. Then went to 3/8" nylock nuts and bolts. The wing nuts kept coming loose.
The Yamaha Rhino lowered more than the trailer did.
You can see it got dirty. I washed it and was waxing it when the new owner arrived to pick it up. It looked new. The paint was amazing.
I did not use the tool hauler much as I kept the saws and equipment in the rear of the Rhino.
The only issue we had with the trailer is that one of employees sold it.  :o  I had only 1 hour to get it ready.
It worked well in the woods. It went anywhere the Rhino did. Backing the trailer was a little bit of a challenge.
Kevin is building us another one with wood sides. I am not sure how this may work.
I would recommend this cart. The person that purchased it is using it on a golf course and pulling it would a golf cart to limit damage to the greens.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline red
  • we will never forget
Re: All Terrain Dump Trailer
« Reply #1 on: February 11, 2019, 06:15:00 PM »
Amazing things are happening at WMPA every day with a little help from Logrite.
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline trapper
« Reply #2 on: February 11, 2019, 11:08:07 PM »
When I want to keep the sides quiet I put a ratchet strap under and over  the box close to the front.  With my other lawn trailers I use threaded rod to stiffen  them up.  This trailer is too nice to drill holes in.  I use it for wood with the sides on and take them off to move lumber.
stihl ms241cm ms261cm  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #3 on: February 12, 2019, 07:56:51 AM »
Works the same just a lot quieter!
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #4 on: February 25, 2019, 08:39:19 AM »
Quote
I have several years use on mine and haven't had any issues with the sides.   Yes, they do rattle some but they haven't bent out at all.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40 Super- Wide HDG38
Lucas Dedicated 60" Slabber
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #5 on: March 04, 2019, 03:31:53 PM »
I don't use anything to keep my sides together as I like to be able to quickly remove one or more sides.  But for those who want or need them we provided holes for you.
Kaufman Trailers Deluxe Light Duty 10000 GVWR Dump Trailer
Started by submarinesailor on General Board
Last post November 28, 2016, 11:07:02 PM
by submarinesailor
homemade axles for rough terrain log trailer
Started by Woodchuck53 on General Board
Last post April 24, 2008, 01:59:15 AM
by Woodchuck53
Dump trailer ?
Started by Bruno of NH on Firewood and Wood Heating
Last post January 28, 2018, 10:02:58 PM
by starmac
Dump trailer for ATV
Started by sprucebunny on For Sale
Last post August 03, 2019, 06:09:53 PM
by sprucebunny
