Author Topic: Alaskan Mill cutting issue  (Read 229 times)
Offline fluidp
  • I'm new! To this site
« on: February 14, 2019, 10:17:56 PM »
Hi all.  I have been running my Alaskan set up for several years and it has started to dive into the log, causing a binding thing and I cant figure out what the problem is.  Ive, changed bars, changed chains, tried a few different filing techniques.  Tried filing the sides of the rakers so the chain teeth will be able to cut a bit more on the sides.   Still diving.  Anyone else had this issue??
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Alaskan Mill cutting issue
« Reply #1 on: February 15, 2019, 09:38:07 AM »
Your bar may be worn out, meaning worn wider at the bottom of the groove than at the top of the groove.
Any bar that has been run awhile during diving or climbing is going to get worn like this.
Ways to measure this are 1) to put a piece of new chain in the bar and see if it rocks side to side.  Or 2) put together feeler gauges same as your groove (0.050, 0.058 or 0.063 as the case may be) and see how much those tilt when in the groove.  But you won't know how much extra  "slop" in these measurements there is unless you have a new bar and a piece of new chain to compare.
But the best to understand whether bar wear is the problem is 3) to take a new bar and new chain run tight and see how it cuts by comparison.  Or to use a side of a bar that has never been used before, but then would you be sure that side wasn't used before.
Once one does any amount of milling where the saw is run in a diving mode IMO the bar has been compromised.  Don't run in the milling mode when you feel that the chain has to cock sideways a bit to keep cutting
DJ Hoover, Terrific Timbers LLC,  Mystic CT Woodmizer Million Board Foot Club member.  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker),  Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Alaskan Mill: 066: Saw not cutting straight?
Started by bandyfro on Chainsaws
Last post August 04, 2018, 07:52:47 AM
by maple flats
Cutting a crotch with an Alaskan mill?
Started by Brad_bb on Sawmills and Milling
Last post October 04, 2014, 08:58:39 PM
by Brad_bb
thumbup
Lucas cutting 'issue'
Started by sigidi on Sawmills and Milling
Last post March 15, 2015, 04:04:54 AM
by sigidi
Know any Lucas Mill or other alaskan mill operators in N. GA?
Started by HeartwoodBurl on Sawmills and Milling
Last post February 17, 2014, 06:33:43 AM
by Seaman
