Author Topic: WM sharpener pump question  (Read 812 times)
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« on: February 15, 2019, 03:57:56 PM »
Recently when trying to sharpen some blades my pump for the water/coolant died. I had bought two last time I bought them and both of them are dead.
I went and got two more at Home depot where I have been buying them for some time now.
But I was wondering what type/brand of pump are you guys using?
I am using this one:
At the end of the last one's life it just wouldn't spin until I reached in with an awl and started the impeller spinning. After I started it, it would usually run ok for that day. Until this last day, when it wouldn't spin any more.
I was also wondering if I should take it out of the water in between using it.
What do you think?
Jim Rogers
Offline Southside
Re: WM sharpener pump question
« Reply #1 on: February 15, 2019, 06:35:42 PM »
You run water in your sharpener?
Offline Jim_Rogers
    • jrsawmill.com
« Reply #2 on: February 15, 2019, 07:10:15 PM »
yes that was standard when i got it
Offline PA_Walnut
« Reply #3 on: February 16, 2019, 06:41:58 AM »
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline Jim_Rogers
    • jrsawmill.com
« Reply #4 on: February 16, 2019, 08:15:05 AM »
If you guys aren't using water, with the blue rust preventative what are you using?
And still what pump are you using? anyone?
Jim Rogers
Offline Southside
« Reply #5 on: February 16, 2019, 09:28:21 AM »
I use the WM cutting oil, some guys have gone to straight mineral oil too. Factory pump, I can get the number on it if you want.
Offline JB Griffin
« Reply #6 on: February 16, 2019, 09:42:37 AM »
Jim, what they obviously don't know is you have a Ltaga not a cbn :D
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline PA_Walnut
« Reply #7 on: February 16, 2019, 10:11:45 AM »
Mineral oil here. No stink.👍
Offline Jim_Rogers
    • jrsawmill.com
« Reply #8 on: February 16, 2019, 10:16:12 AM »
you're right
Offline Southside
« Reply #9 on: February 16, 2019, 10:26:31 AM »
Ahhh. The light bulb came on. Thanks JB.
Offline PA_Walnut
« Reply #10 on: February 17, 2019, 08:17:46 AM »
I don't use water, since cbn, but use Cotton Picker Spindle Lube for blade lube, then when I take them off the mill, wipe down with WD40 and scotchbrite pads if there's any build-up (rarely).
I have learned the error of my ways with blades, once I begun sharpening and setting my own!
Online Ga Mtn Man
  • Y'all can call me GMM
« Reply #11 on: February 17, 2019, 09:48:29 AM »
I think Jim is still hoping for a pump recommendation from someone.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline Jim_Rogers
    • jrsawmill.com
« Reply #12 on: February 17, 2019, 09:58:55 AM »
x2
Offline Percy
  • Resident trouble maker
« Reply #13 on: February 17, 2019, 10:46:54 AM »
x2
I have had great service from these Little Giant pumps....its what came with all my WM sharpeners over the years......they seem to last much longer pumping oil....
1-A Series | Small Submersible Pumps | Industrial | Little Giant | Franklin Electric
Offline Old Greenhorn
« Reply #14 on: February 17, 2019, 11:20:54 AM »
Jim, I'll second what Percy said. When I had my machine shop I probably had 3 of these running at any time and a spare on the shelf, nt as a replacement but for floating use wherever I needed it. Rock solid, but a little more pricey than the home despot 'stuff'. I have run water, oil, and soluble oil (coolant) through these for thousands of hours. They just need a little cleaning every year or two. When they finally quit, they are done, however, that doesn't happen very frequently. Check your industrial suppliers and if you can't find one, I have an online source for you.
Can You help out the Coleman Veterans Memorial by chipping in a few bucks? Go here for the full story: Can you help this year? in General Board
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Offline Jim_Rogers
    • jrsawmill.com
« Reply #15 on: February 17, 2019, 02:45:15 PM »
x2
Thanks for that.
Offline dustyhat
« Reply #16 on: February 17, 2019, 03:00:52 PM »
Little giant is what i have , there good pumps mostly used on parts washers, got my latest one at surplus center.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Offline beav
  • got any logs?
« Reply #17 on: February 17, 2019, 03:38:06 PM »
Maybe no help but for 30+ yrs I've been using a milk jug hung close to the ceiling siphoned down to the water jet on the sharpener through a small rubber tube. Still works like new!
Online Ga Mtn Man
« Reply #18 on: February 17, 2019, 07:53:22 PM »
They just donít make milk jugs like that anymore. 😄
Offline gmmills
« Reply #19 on: February 17, 2019, 08:28:18 PM »
 Jim,  Very hard to beat Little Giant pumps for sharpener application. I have two different CBN sharpeners and both have Little Giant pumps in them. You actually have three Little Giant pumps each having same size pump housings. Your LTAGA, when new, probably came with a Little Giant 1-A series pump. You have the choice of selecting  a 1-A series or a  1 series. They both look physically the same. Both have Nitrile shaft seals. The 1-A pump has a lower HP rating then the 1 Series. The 1 Series pump is capable of moving a larger per hour flow rate. You also may want to look at the 1-Y series pump. Same HP-flow rate as the 1 series, but has a Flouroelastomer seal. Actually listed as a parts washer pump. Have this pump in my Pro-series CBN sharpener for well over 10 yrs. It has never been replaced. Only neg with this pump is no plug on end of wire. designed for direct wire application.
  Back when I had an LTAGA, used water soluble cutting oil mixed in straight water as coolant. I purchased it from our local NAPA store. Our's stocked it in 2 different sized containers. Only drawback, is solution will become rancid over a period of time. Needed to be exchanged frequently. No antibacterial agents in this brand of oil.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
impellers for Little Giant 1-AA pump (WM Sharpener)
Started by BBTom on Sawmills and Milling
Last post December 17, 2006, 10:42:40 AM
by BBTom
pump question
Started by furltech on Forestry and Logging
Last post July 04, 2012, 08:14:37 PM
by bushmechanic
Hydraulic pump question
Started by pidaster on Sawmills and Milling
Last post June 09, 2015, 02:42:57 PM
by pidaster
Circulating Pump Question
Started by Autocar on Firewood and Wood Heating
Last post September 06, 2018, 02:39:39 PM
by LittleJohn
