Author Topic: Portable sawmill service needed , Lagrange GA  (Read 332 times)
Offline Ga Mtn Man
  • Y'all can call me GMM
« on: February 16, 2019, 09:22:44 AM »
About 15 logs.  Reply here if interested.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Portable sawyer needed , Lagrange GA
« Reply #1 on: February 16, 2019, 09:26:21 AM »
Mtn Man,
   Did you check here on the FF extras for a sawyer in the area? If none there you can check the WM home site and under services I bet you find somebody close listed there. Good luck.
Offline Ga Mtn Man
Re: Portable sawmill service needed , Lagrange GA
« Reply #2 on: February 16, 2019, 11:52:51 AM »
Yes I did and I wanted to give my fellow FF members a crack at it before referring the customer to Wood-Mizer. :)
Offline Sixacresand
  • John and Nancy
« Reply #3 on: February 16, 2019, 12:57:10 PM »
Could be a fun over night trip and job for a GA or AL Sawyer.  Lots to do around LaGrange.  When say "Lots", I mean good eating places.
Offline Ga Mtn Man
« Reply #4 on: February 16, 2019, 05:08:56 PM »
John, are you volunteering?
looking for portable sawmill service
Started by ronmcm on Sawmills and Milling
Last post September 18, 2018, 08:46:00 AM
by E-Tex
Portable Sawmill Service, Chester County PA
Started by Srbenda on Wanted
Last post November 06, 2011, 08:50:50 AM
by Srbenda
Portable sawmill needed
Started by cut2size on Sawmills and Milling
Last post January 18, 2004, 12:24:08 AM
by cut2size
Portable Sawmill ID needed
Started by jfastman on Sawmills and Milling
Last post May 15, 2013, 10:14:29 AM
by MM
