Author Topic: sawmill build*very novice*  (Read 1505 times)
Offline ry597
  • days in the woods are the best days
Re: sawmill build*very novice*
« Reply #20 on: February 21, 2019, 08:09:41 PM »
That would be a bit overkill for me.. here the trees aren't that big. alot of the trees are new growth. I have a jonsered 2166 with a 18 inch bar and ive rarely seen a tree go past 18 inch. Im glad you mentioned the honda motors! i was looking at one myself but the price was way too much. we don't have harbor freight here in the north i don't see where i could buy a predator engine? i wouldn't mind having one! right now im looking at the facebook market and on other platform to source an engine thats atleast 15hp. Maybe the blade bites more onto the softer woods thats why it needs more power?
About the drive system, could you use a setup in which you actuate a lever that tights the belt? something similar to a snowblower auger mecanism? i belive thats what WD uses? For the bandwheel size, is there a way to calculate the size i need with the specs of the blade? pretty sure i would need different size bandwheel and pully to make 26 inch between the guides? how did you calculate the pieces that you need? sorry for having alot of questions but im not very familiar with the drive mecanism of a sawmill. I thank you very much for taking the time to reply and answer my questions.
Offline Mike W
  • Location: Boundary Washington - Right on the edge of the Northern Boarder
« Reply #21 on: February 21, 2019, 08:32:33 PM »
How far are you from the US boarder?  Have you thought about using a boarder crossing facility that accepts US goods for Canadian customers to pick up and haul home.  my mill has a 25hp Kohler and wouldnt want anything with less HP then it puts out for sure.  the HF predator motors have been great in my opinion, i have several all with no issues so far.  Just a thought, for the $$ they are really hard to beat and would save some $$ for other bells you might want to add to the build.
Offline ry597
« Reply #22 on: February 21, 2019, 08:37:39 PM »
i could cross over to maine which would be a 4 hour drive. i don't know if they have a habor freight in maine?
Crusarius with some research i found out the blades specs that i wouls use. (158" lenght, .042"(1mm) thick, 1.25"(32mm) wide) what size band saw wheels would i need for that ?
Offline Mike W
« Reply #23 on: February 21, 2019, 09:05:16 PM »
I was referencing ordering on line through HF, you could keep an eye on the deals they put out monthly, most times they have the predator offered in multiple HP's you could choose from.  Google search "cross boarder shopping centers in Maine" and you will find several cross boarder stores or facilities that accept delivered goods ordered by Canadian's and charge a small handling fee to pick up from them in person and take across the boarder with your new power plant in hand.  I happen to own one of these types of facilities, but wrong side of the country to be of help in this particular situation.
Offline ljohnsaw
« Reply #24 on: February 21, 2019, 09:44:47 PM »
You can use any size wheels you want.  The larger the better (less flexing).  You just need to adjust the distance between the axles.  Not too hard.  Take the diameter of whatever wheels you can find, multiply by 3.14 (Pi).  That is the distance around one wheel.  Since the blade is only going around half of both wheels, use that total.  Subtract that from the 158" band, divide by 2 and that is the distance between the axles.  You want some adjustment to have it loose enough to put it on and then tight enough to run.  Figure about 1" for hard (steel) wheels.  A little more if you are using car tires to compensate for the rubber deforming.
John Sawicky
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #25 on: February 24, 2019, 08:36:13 AM »
I like the 19" (18.75" with bet makes 19") wheels. the larger the wheel the less metal fatigue from tight bending. So blades typically last longer before they break.
Offline BigZ La
« Reply #26 on: February 24, 2019, 09:40:43 AM »
You can use any size wheels you want.  The larger the better (less flexing).  You just need to adjust the distance between the axles.  Not too hard.  Take the diameter of whatever wheels you can find, multiply by 3.14 (Pi).  That is the distance around one wheel.  Since the blade is only going around half of both wheels, use that total.  Subtract that from the 158" band and that is the distance between the axles.  You want some adjustment to have it loose enough to put it on and then tight enough to run.  Figure about 1" for hard (steel) wheels.  A little more if you are using car tires to compensate for the rubber deforming.
I think the distance between the axles would be half of the figure using that formula. Just asking?
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #27 on: February 24, 2019, 09:50:06 AM »
with a 19" wheel and a 158 blade your looking roughly 49"to center of axles
Offline ljohnsaw
« Reply #28 on: February 24, 2019, 11:50:10 AM »
Yes, that is what I meant.  I went back and corrected it!  Good catch.
John Sawicky
Offline Hilltop366
« Reply #29 on: February 24, 2019, 01:29:45 PM »
Welcome ry597, from all I have read over the years 18"to 19" band wheel would be a minimum band wheel diameter, also have been told by several small mill owners that 13hp would be a minimum for gas engine.
There is a machinery calculator in the tool box at the left under the sponsors list that will help with band speed in feet per minute and pulley size. Cooks saw has lots of info and videos about horsepower, blade speed and blade guide setup.
Offline thecfarm
« Reply #30 on: February 25, 2019, 02:38:13 PM »
I have a centrifugal clutch on mine mill. I have a bum shoulder. No way could I push a handle to engage the motor. I have a Thomas mill.
Offline Deadeyeb
  • Member*
« Reply #31 on: February 28, 2019, 02:07:50 PM »
Crusarius how wide between the bedrails and what size blade do you run.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #32 on: February 28, 2019, 03:19:03 PM »
I run 158" blade I have 50.75" from outside to outside.
I made the bed wide so I could stack the lumber I was cutting next to the cant. at least till I got to that level.
I do not stack the lumber next to the cant :) it got in the way to much.
In hindsight I probably would not make the bed that wide again unless I had a way to step inside it without climbing over it. Stretching to reach the slabs is not fun. I ended up getting a hookaroon so I could grab the boards.
Offline ry597
« Reply #33 on: March 11, 2019, 07:21:05 PM »
thanks everyone with the replys! Ive had a real hard time finding parts. I will listen to everybody's suggestions and will go with 19 inch wheels. i believe i will have approximately 2 1/2- 3 feet off cut width? i underestimated the size of the project.... i will start to acquire more part before getting started on the bed build. I am planning on building a frame that extends against my shed so i could work on my mill in any type of weather. we get pretty much everything, right now we have record breaking snowfalls and its still snowing in march... im pretty good messing around with small engines so i will find a used one and rebuild it. a horizontal shaft with more than 10hp is really hard to find... I will draw a plan when i get the dimensions right. maybe start a new thread?
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #34 on: March 12, 2019, 07:18:44 AM »
I bought the 22hp predator from HF. I have not been disappointed. I paid 700 for it but it will go on sale for 650 sometimes.
My thought behind this was I really wanted a 20hp honda. but at the tune of $2300 I could replace 3 predators for the cost of 1 honda so I chose to go that route. If you are good with engines I would buy the predator and if you have problems just rebuild it. you will probably be ahead on money.
Offline bwstout
« Reply #35 on: March 12, 2019, 07:35:29 AM »
I too have the HF 22hp and have had no issues with it and the extra hp was worth is started with a 13hp Honda clone that lasted a year before it quit.
home built mill
moved
MOVED: sawmill build*very novice*
Started by chet on Forestry and Logging
Last post February 17, 2019, 07:19:36 AM
by chet
new novice
Started by pifan on General Board
Last post January 22, 2005, 09:28:36 AM
by pifan
New Guy with my Sawmill Build
Started by Jimmysmill13 on Sawmills and Milling
Last post November 14, 2018, 09:03:01 PM
by charles mann
My new sawmill build
Started by Piddler on Sawmills and Milling
Last post February 08, 2018, 07:17:59 PM
by Kbeitz
