Author Topic: Diesel saws n such  (Read 1192 times)
Offline TACOMATODD
Diesel saws n such
« on: February 18, 2019, 06:38:58 AM »
Is their such a thing? I would think, that if so, you could do away with the mixing of the fuel. Has anyone had experience with running diesel in a saw, even if it didn't run QUITE as well, maybe 80%, but did run and live?
Trying harder everyday
Offline TACOMATODD
Re: Diesel saws n such
« Reply #1 on: February 18, 2019, 07:27:20 AM »
I just wonder, because of all the inherent lube property that it has, and the fact that it will, albeit poorly, light from a spark. These are the things that I think about at odd hours of the morning. Maybe like aircraft jet fuel, JP8 or something. Close relative.
Offline doc henderson
« Reply #2 on: February 18, 2019, 08:07:50 AM »
Welcome Todd.  I think that diesel will burn slowly and that makes it safer.  Gas can vaporize or in a carb. atomize and mix with air and burn quickly.  Think explode.  Diesel requires extreme compression and therefor requires injectors to put the fuel where it belongs.  If you designed a diesel engine for a handheld saw, it would likely be heavy and expensive but they do last longer.  Pure diesel in a gas engine I doubt would run at all.  gas in a diesel would poss. damage the engine.  I know some truckers will add a little gas to diesel in the winter, and I know that diesel is less refined than gas and more like an oil, but my saws are two expensive to want to try that.  I will give you credit for thinking outside the box.  :)   I bet some of the engine/chainsaw mechanics will have an opinion and or experience r.e. your question.
Offline Allar
  • Firewood Warrior!
« Reply #3 on: February 18, 2019, 08:53:46 AM »
Firewood & Chainsaw videos: Firewood Warrior - YouTube
Offline moodnacreek
  • Sawin by the notches
« Reply #4 on: February 18, 2019, 09:16:51 AM »
Diesel engines where developed to burn cheaper fuel than gasoline. Many gas engines could be ordered to burn kerosene or fuel oil. The heaver fuel required lower compression and as many as 4 different pistons might be available for the same engine. These would be spark fired engines that often started on gasoline to warm up an then switched to the cheaper fuel. The well known Wisconsin air cooled engines where offered in fuel oil burning. probably for export.  True diesels are self fired and where more expensive but the real answer to burning cheap fuel.  All this has changed as gasoline is now the cheaper fuel and you would not want to be bothered with all the problems spark firing diesel in a chain saw.  I would think fuel injection would be next in chainsaws.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: February 18, 2019, 11:10:01 AM »
Diesels are in the 16 to 21:1 compression ratio for compression ignition to occur.  Youd break pull ropes and rotator cuffs left and right.  I dont think diesel will ever be the direction saws go.  Not to mention the lower lubricity that the ultra low sulphur mandated fuels have to offer.
If youve ever tried to start a diesel genny or plate compact with pull rope and decompressor.. Theyre pretty hard to get going.  And need heavy flywheels to dissipate the twisting torsional loads on the crank so youd have to lug that around.  In general men are getting wimpier, not tougher.
Revelation 3:20
Offline sawguy21
« Reply #6 on: February 18, 2019, 11:55:05 AM »
The big drawbacks are weight and as mentioned cold weather starting. Diesels are built for torque not speed, a more aggressive chain could be used but the vibration would be unbearable. Run one of the early saws to get a taste of it. ;D
Offline moodnacreek
« Reply #7 on: February 18, 2019, 01:51:24 PM »
Anything put on a chainsaw that makes it weigh more that the current model will not sell. Men are getting wimpier and I am old and never pick up a chainsaw any bigger than the job calls for.
Offline Ianab
« Reply #8 on: February 18, 2019, 04:11:33 PM »
I'd put that down to getting smarter.... :D
Offline joe_indi
  • The older I get the more I learn
« Reply #9 on: February 18, 2019, 10:12:53 PM »
In school as an Air force cadet here I had to construct aeromodels powered by miniature compression combustion engines .75cc to 2.5cc
These were called diesel engines, quite different from glow plug engines  like Cox /Thimbledrome.
The fuel was 50% Ether (to lower the combustion point) 25% Castor oil and 25% kerosene. These engines had variable compression by way of a cylinder that could be made to move up (low comp) and down (high comp)
Starting was at low compression and then compression was increased to get better combustion.
These were 2 strokes.
Having seen these engines what came to mind was cannot the same technology be repeated in slightly bigger engines. Instead of Ether use gasoline to lower combustion point of regular diesel, have a similar setup for variable compression.
Being two strokes they were relatively light weight
Thinking out of the box. ;)
The video shows a .75cc Mills, a classic
Offline mike_belben
  • Pulp Friction
« Reply #10 on: February 18, 2019, 10:51:19 PM »
The diesel cycle makes more torque than gas largely because the injector is post intake valve and can inject for far longer duration than a gas fuel injector spraying into the manifold at a closed valve.  This puts diesel bmep peak [cylinder pressure] at much closer to 90* crank angles where it has vastly more leverage to put torque into the crank despite much lower rpm and HP comparatively with gassers of similar size.  The kind of torque our puny clutches cant take.  And worse, its at much lower RPM than a 2stroke saw.  With centrifigul flyweights rpm is everything.
So now we need a stouter piston and rod, a tougher jug and block with bigger bolts to hold the pressure in.  a steel injection pump and injector, a decompressor, a heavy flywheel and heavy clutch, a stout starter and pull rope.  Problem is above maybe 6000 rpm or so there just isnt gonna be enough time for a stratified direct injected diesel charge to find air, so the result is smoke which epa is not gonna allow, nor will the consumer want to stand in a coal plume cutting a tree.  And how much extra patience has anyone got to go back to 1950s chain speed?  A crosscut bucksaw might be faster.
Basically theres nothing wrong enough with gas saws that warrants the switch.  The consumer today is thinking lithium ion or gas, not gas or diesel.   This is all in my opinion and i could be mistaken, nor do i intend any offense. Its a good discussion to kick around.
Revelation 3:20
Offline TACOMATODD
« Reply #11 on: February 19, 2019, 03:11:13 AM »
No offense has been taken and I have only taken good educational experience and opinions from this thread. After all, that is why I asked. As always, when I ask a well formulated question, I get very good responses. It's like I have told people and learned SEVERAL decades ago, "you don't know if you don't ask". Treat people like you want to be treated, and say please n thank you. To me, those VERY simple things will take you a long way in life. THX!
Offline Air Lad
  • Onwards and upwards
« Reply #12 on: February 19, 2019, 04:46:25 AM »
Saw a 4 stroke also
Too heavy
When two stroke is dead batterys will probably prevail
And I will cryingsmiley_cry
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
Offline mike_belben
  • Pulp Friction
« Reply #13 on: February 19, 2019, 06:57:57 AM »
I agree with you there todd.
Revelation 3:20
Offline HolmenTree
« Reply #14 on: February 19, 2019, 11:37:31 AM »
Diesel saws can be lightweight,  in 1949 a Norwegian invented one that weighed only 18 lbs. :)
Offline sawguy21
« Reply #15 on: February 19, 2019, 11:41:21 AM »
Saw a 4 stroke also
Too heavy
Shindaiwa had an 80cc 4 stroke prototype, a rep said the torque was unbelievable but they are not yet ready to market it.
Offline HolmenTree
« Reply #16 on: February 19, 2019, 11:50:48 AM »
There's a few Chinese 4 strokes on the market already that are surprisingly lightweight.
Offline Somewhat Handy
  • Hi.
« Reply #17 on: February 19, 2019, 02:03:51 PM »
So, do these diesel saw prototypes use special alloys and/or forged parts to keep crank, piston and cylinder lighter? Also could a diesel saw sacrifice some of its prodigious torque with added gearing to keep rpms up? This just begs more questions...
  • Hi.
« Reply #18 on: February 19, 2019, 02:10:30 PM »
Here is a neat read about an 18cc diesel that powered bicycles back in the 50's:
1951 LOHMANN 18cc DIESEL ENGINE (New-old-Stock, Unused) | The Online Bicycle Museum
I guess these things can get pretty small
« Reply #19 on: February 19, 2019, 04:43:29 PM »
that is cool, I would get one just to have.  I assume that is an old comment or are they still available, "new old stock".
A case for old Vintage Homie & Mac saws vs. new home owner grade saws..
Started by weimedog on Chainsaws
Last post November 25, 2013, 09:01:56 AM
by Bret4207
MF135 Diesel Tractor --- Diesel leaking into crankcase
Started by Left Coast Chris on General Board
Last post May 25, 2008, 08:29:56 AM
by zopi
LT-15 Diesel vs. 25HP (now vs. 19hp diesel on TK1220)
Started by Piston on Sawmills and Milling
Last post May 21, 2009, 07:56:29 PM
by Don K
Any Pro's using Kit Saws or Clone Saws
Started by Thunderfist on Chainsaws
Last post November 02, 2018, 12:43:51 PM
by motzingg
