"Draft"
Started by Viperman, February 20, 2019, 12:30:00 AM
Viperman
I've heard people refer to there OWB's being at a 20% draft.  The one I heard mention was a Heatmaster MF5000e.  Is there a draft control on these? and where is it.
uplander
 It's usually measured in inches (or parts there of) of water column vacuum most of the time with a manometer that you hook up to your flue.
  Google "Dwyer Manometer"
Woodmizer lt40G28.  A kubota L4600 with loader and forks.
Various Stihl saws and not enough time to use them!
Finished my house finally. Completely sawn out on by band mill. It took me 7 years but was worth it. Hardest thing I have ever done.
I have a Heatmor. Mine does not have a natural draft. Open the door and the smoke comes out. That is why I can burn dead wood in mine and have a controlled fire. When the fans are not running the fire is smothered out.
E Yoder
The Heatmaster MF models have a manual damper so you can adjust the volume of airflow. It still cycles on and off with the solenoid flap and fan.
20% sounds very low though, I'd think it would be close to making creosote.
HeatMaster dealer in VA.
G7000
