Author Topic: "laser" indicator for sawmill.  (Read 1566 times)
Online doc henderson
« on: February 22, 2019, 02:26:23 PM »
I am looking for a laser to mount on my mill.  12 v ideal prob auto. style application.  i want to set it so it is just in front of my blade to help me see when I am behind the log enough to drop the head and, to help signal when I am about to enter the log.  i know someone use a dewalt one to show height of the blade on a scale.  what-cha got?  prob. needs to project a line, not a dot, and needs to be of and intensity, color and brightness to see in daylight.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
Re: "laser" indicator for sawmill.
« Reply #1 on: February 22, 2019, 08:05:07 PM »
Use the search function. Lots of good threads there.
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
« Reply #2 on: February 23, 2019, 04:01:52 PM »
thanks pa, got one ordered.
Offline PAmizerman
    • Byrne Millwork
« Reply #3 on: February 23, 2019, 08:35:13 PM »
You go with a green one?
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
« Reply #4 on: February 24, 2019, 02:42:24 AM »
yes, 50mA.  I got the cheaper one, if it does not last, I will order the several hundred dollar model.  It is not mandatory, but milling all day, a person can get sloppy and fatigued watching to drop the head as soon at the blade is behind the log.
Offline PAmizerman
    • Byrne Millwork
« Reply #5 on: February 24, 2019, 09:10:10 AM »
Once you have one you really get used to it. They are a nice feature. I have the stock red one from woodmizer.
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline boonesyard
  • I've got a little sawdust in my pocket
« Reply #6 on: February 24, 2019, 09:39:54 AM »
Can you see it in the daylight?
LT50 wide
"I ain't here for a long time, I'm here for a good time"
Offline PAmizerman
    • Byrne Millwork
« Reply #7 on: February 24, 2019, 11:02:42 AM »
I have my mill under a shed roof. There are times when the sun is in a certain position and I cannot see the laser.
My laser  is useless outside.
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline tawilson
« Reply #8 on: February 24, 2019, 01:52:31 PM »
Here's a 50mw.  Even though the sun washed it out at the far end, there was enough to site down and see where the blade was going. It shows up better than in the pic. When the suns moved away it will light up the whole log.
PA, for $35 you could swap that red factory laser out for one of these. I used the Woodmizer mount.
2017 LT40HDG35 WIDE
Offline PAmizerman
    • Byrne Millwork
« Reply #9 on: February 24, 2019, 04:06:27 PM »
@tawilson  do you remember what model that laser is? Did you get it at cemar?
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline tawilson
« Reply #10 on: February 24, 2019, 04:12:28 PM »
Nope Amazon.  I put a little electrical tape on it to snug it to the woodmizer mount.
2017 LT40HDG35 WIDE
Offline PAmizerman
    • Byrne Millwork
« Reply #11 on: February 24, 2019, 04:36:21 PM »
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
« Reply #12 on: February 24, 2019, 04:47:16 PM »
I think that is the same one I got.  Those of you at home, be sure and do the "air quotes" when you say "laser"
Online btulloh
« Reply #13 on: February 24, 2019, 08:26:36 PM »
Righttttt.
With the right mount that could go on a seabass.
HM126
Offline PAmizerman
    • Byrne Millwork
« Reply #14 on: August 08, 2019, 10:58:49 PM »
@doc henderson are you running the laser on 110 volt or a 12v battery?
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
« Reply #15 on: August 09, 2019, 08:16:49 AM »
I went to walmart and got a 12 v cigarette lighter attachment (rv and trailer area) and wired it to my battery.  then I got a 12 v to 110 v inverter that plugs into a cig lighter.  then I plug the laser into that.  it came with a ball mount that has a flat base.  I used "industrial" strength double sided tape to attach it to a flat front guard on my mill.  after use, I unplug and dismount and take the tech parts inside.  It makes a straight line just in front of the blade so I can better tell when I am past the end of the log to raise, and behind the log to drop down.  I have computer set works and it makes you swear a little if you get on a roll, and drop to soon and catch the blade on top of the log.  I can add pics later if that would help.  I do not use it for little projects, but it is helpful and fun when planning a long day at the mill.
Offline PAmizerman
    • Byrne Millwork
« Reply #16 on: August 09, 2019, 09:14:01 AM »
I ordered one for my edger. I did a little research last night and ordered a step down converter for it. Thanks
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
