Author Topic: 024AV vs. Dremel tool  (Read 452 times)
Offline Woodcutter_Mo
« on: February 26, 2019, 08:21:45 PM »
 The other day while I was replacing the fuel line on the old 024AV, I pulled the cylinder off and gave the intake and exhaust ports a little "modification" with the Dremel  ;D. After a retune and test it seems to run pretty good.
 I will be pulling the jug again to put a better base gasket on fairly soon, is there anything else that could use a bit of dremeling before I put it back together? I've not found much on the 024AV's and the 026 pics I've seen online seem to look a little different. Thanks
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline wild262
Re: 024AV vs. Dremel tool
« Reply #1 on: February 27, 2019, 07:54:40 AM »
If your after more gains, just find a 026 cylinder and replace yours with that.  That should make you smile. :)
« Reply #2 on: February 27, 2019, 01:51:43 PM »
 I was thinking about doing that, but I'm not sure if the 024 AV will fit the 026 cylinder. I know the 024 Super will as it has the longer stroke like the 026.
Offline Al_Smith
« Reply #3 on: February 27, 2019, 03:22:55 PM »
You could get some slight improvements but it would be better if the compression would be improved by either shaving the cylinder or eliminating the base gasket .It would stand to reason if you could get improvements on say an 044 or 066 you certainly could on a little 024 .
Generally speaking if you did nothing but improve the exhaust side of the engine it will get the most gains .On a two cycle you have to work backwards starting with the exhaust .Because if it can't get out it can't get in .
I've got an 024 that had a very tiny burn on the exhaust side of the piston.Traded in because the owner worried about and bought of all things a 290 .All I did was cut the baffles and screens out of the muffler and retuned the carb .Not one more thing and that pepped it up and that was 6 years ago .It's a little saw and does what little saws are supposed to .It's a firewood cutter not an oak slayer .
« Reply #4 on: February 27, 2019, 11:26:13 PM »
 Ok, I will look at improving the compression next. I watched a video on checking the cylinder squish, so I will see how it looks.
 So far what I did was opened the exhaust ports to the size of the gasket opening and widened the port a bit to where there is still enough left to seal on the skirt and the same with the intake side, and also ground out the casting imperfections in the ports.
Offline wild262
« Reply #5 on: February 28, 2019, 08:06:23 AM »
Make sure you level out the sharp edge where you used a grinder as you don't want to catch a ring.  Also make your squish no less than 20 thou clearance, if not using a base gasket you will want to use 1194 sealant of both pieces (thin coat). Dirko is another good sealant to use.  These have been proven to work.  Have fun. :)
Dremel Tool Sharpener???
Started by Woodhog on Chainsaws
Last post May 29, 2005, 07:26:25 AM
by Al_Smith
sharpening with a dremel tool
Started by Robert R on Chainsaws
Last post June 21, 2007, 01:13:10 PM
by Al_Smith
Filing or dremel tool for sharpening?
Started by wle on Chainsaws
Last post May 20, 2014, 07:06:37 PM
by shinnlinger
Convert chain tensioner on 024AV?
Started by EnglishWoodsman on Chainsaws
Last post April 28, 2017, 05:08:17 AM
by ButchC
