Author Topic: Did something dumb today.  (Read 11849 times)
Offline samandothers
Re: Did something dumb today.
« Reply #180 on: May 30, 2019, 08:33:08 AM »
Firefighter,  It was only about 100 grit or so but it sure acted like it was sticky!
Danny,  Thanks for sharing how this happened.  As Alan stated it is good to learn from others experiences and learn from them on how to change our practices or at least know proper technics.  Does not mean we will put into practice what we learned! ::)   Thus we post here. :o
Offline doc henderson
« Reply #181 on: May 30, 2019, 09:01:52 AM »
Something fascinating about a spinning object.  We had a blue healer that would run up and bite turning wheels on a lawn mower, he just could not help himself.  His name was scout, from to kill a mocking bird
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #182 on: May 30, 2019, 09:06:53 AM »
Wow, hope you heal up.  Those gloves will get you.  If you need a vacation, take a drive up to New Market and Ill feed you some steak and we can take a one handed cane pole down to the pond.
HobbyHardwoodAlabama.com
Offline red
  • we will never forget
« Reply #183 on: May 30, 2019, 09:54:50 AM »
Glad you are on the mend
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #184 on: May 30, 2019, 10:05:10 AM »
Danny,
   I hope you heal up soon and completely and that this does not mean you get a 10% discount on your next manicure. ???
    I lost a fingernail on my right little finger this week. Came off from mashing it on the side of my FEL loading about a 3' maple log/section a month or so back. Turned black and finally I looked down and it had just peeled back.
« Reply #185 on: May 30, 2019, 10:44:21 AM »
Yes when you get black under the nail, that is blood. and it will hydraulically separate the nail.  nail material is basically like hair, and feels no pain and can be melted.  so if there is a thick enough layer of blood, you can drill with a bit or needle, or heat something like a paper clip,  the key is to stop when the blood spurts so as to not damage the very sensitive tissue below.  this will relieve the pressure and maybe save the nail.
Danny, I wonder if the local salon could glue you on a fake nail in the future.  choice of color is up to you ;) :D :D :D
My mentor Kenny Skeels had a lot of fun with his.  with a short stub he could really fake pickin his nose, and make you pull back a little if you were shaking his hand for the first time. (he would wiggle his pinky stub!)
Offline Old Greenhorn
« Reply #186 on: May 30, 2019, 01:09:25 PM »
Ditto what Doc said, but let me add a little caution. If the digit is throbbing with pain, when you release the pressure it can be 'energetic' and also cause your ears to ring and vision blur for a second as the nerves beneath adjust to the pressure change. Shortly after, you should feel a WHOLE lot better. I have done this a time or two. Usually there is little issue, but those big ones, oh boy!
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
« Reply #187 on: June 03, 2019, 11:14:39 AM »
Well @WDH  almost karma.  I have a little Bosch palm router.  I always have a 1/8 " round-over bit for softening the edges of almost everything I make.  I make oriole feeders to put the cups of grape jelly in, and I use a hole saw to make the two holes and use a router to make a grove for the top of the cup to seat in.  so left in the same bit, but adjusted the bit lower to also make a groove.  I use this setup so often, I can start and use it with one hand.  turned it on and assumed my usual grip, and felt a sudden intense burning feeling to my R little pinky.  It hurt bad enough that I had to look to investigate the damage.  sure enough 1/2 my finger was still attached and the other half was dut, dut, dah!!!  still attached also.  got lucky and thought of danny almost immediately.  It was red from contacting the collet since the opening had now moved to where I always rest my finger.  great respect for things turning at 20,000 rpms.  will add pic later.
« Reply #188 on: June 03, 2019, 02:48:43 PM »
putting finish on the wedding gift, the red mark is gone.  got off easy compared to @WDH
the top is painted orange, and is a stove burner cover and the cups also are from the WM kitchen isles
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #189 on: June 03, 2019, 08:57:21 PM »
You are living right, Doc.
« Reply #190 on: June 04, 2019, 09:56:37 AM »
Close call on the router, glad it was your day to avoid an injury!  Very nice feeder with the engraving makes a great gift.
Great job.
« Reply #191 on: June 04, 2019, 06:43:43 PM »
Yep, must be living right.
Karma will always let you know shes watching.
Offline Brian C.
    • Log-Gistics
« Reply #192 on: June 05, 2019, 07:59:56 AM »
Danny, Danny Danny. There are better ways to trim your nails.
Glad it wasn't any worse and enough beverages can numb the feeling of pain or make you not care.
Offline armechanic
« Reply #193 on: June 05, 2019, 08:46:22 AM »
I did something dumb yesterday,  I didn't fire up the LT40 and saw any logs.
1989 Lt 40, D6C CAT, Home made wood processer in progress.
Offline crowhill
« Reply #194 on: June 05, 2019, 03:13:46 PM »
Mondays are Mondays! I grabbed a couple of my Dads axes when he passed in 2004, one of which looks as if it drove a number of fence posts over the years. The eye looks like its started to bulge the slightest amount and the handle was in pretty sad shape. Decided time to do something with it so thought Id see if it would sharpen up and it did with some time n elbow grease. Nice n sharp! Been sitting for a few weeks, recently bought a new handle, grabbed the axe head, looking it over to see how best to get the old wood out of the eye and it slipped in n through my hand, bent over to pick it up and saw blood dripping. Never felt it but it sliced my left pinky in good shape! Put some super glue on my finger n wrapped some black electricians tape around it. Cant wait to get that old heavy head hung to see how it tackles limbing, fingers doing fine..
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #195 on: June 05, 2019, 09:11:48 PM »
Super glue is the best. Just be sure to clean the cut good first.
Sometimes I use a plastic scrubber with peroxide then glue.
A&P saw Mill LLC.
License NH softwood grader.
Offline firefighter ontheside
  • I like trees.
« Reply #196 on: June 06, 2019, 09:15:45 PM »
Oh that hot feeling where you know something is not right, but how bad youre not sure.  I was using an angle grinder with a thin cut off wheel to cut steel.  I was not using the guard or the little screw in handle.  It felt like my glove got really hot.  There was a clean cut thru the glove and a nice cut in my finger.  Put a bandaid on and went back to work.....and did it again.  I put the handle on after that.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline alan gage
« Reply #197 on: June 06, 2019, 10:02:36 PM »
When I got my first planer I, for some unknown reason, very lightly ran my finger down the length of one of the blades. But certainly not pressing hard enough to get cut. About halfway down the blade I started to wonder why the blade was burning my finger. It certainly couldn't be hot. Pulled my finger away and found a nice deep cut. Guess those blades are sharp.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 783 Skidloader.
Offline crowhill
« Reply #198 on: June 30, 2019, 04:33:46 PM »
So I needed 4 bolts to replace the 4 that are used to adjust the head position on my B-20. They keep coming loose and I believe the best way to keep them tight is to start with new bolts. So I drove 15 minutes to the local auto parts store, didnt have them. Drove another 10 minutes to the heavy equipment dealership, nope but would be happy to order them. No thank you. So on another 15 minutes to a Manufacture Supply store. YES! Its Friday afternoon, hot and I sure would like to get this project started. Get the 4 bolts, 8 flat washers, 8 lock washers and the 12 nuts needed, go to check out counter, pay and head home. Grandson is with me and since we skipped lunch to run this errand we stop for a bite to eat, another half hour out of my way. Finally get home, couple chores to do before working on the mill. Get the tools out and set up to work. Wouldnt you know coarse thread bolts n fine thread nuts. The excitement of finding the bolts over powered the common sense to double check. That was dumb, now a second trip to make it right😟
« Reply #199 on: June 30, 2019, 09:28:15 PM »
@crowhill , i bet if you get them to tighten down, they will not loosen up any time soon. :D
i pulled a dumb-dumb...
Started by Dan_Shade on Health and Safety
Last post August 06, 2005, 06:10:46 AM
by sawguy21
I'm such a Dumb---
Started by jargo432 on Firewood and Wood Heating
Last post March 10, 2016, 06:43:15 PM
by jargo432
I did a dumb
Started by alan gage on General Board
Last post July 25, 2019, 12:13:15 PM
by alan gage
How dumb can I be? VERY!
Started by tmbrcruiser on Sawmills and Milling
Last post April 14, 2017, 09:22:37 PM
by Magicman
