Tally-I/O
Author Topic: Did something dumb today.  (Read 20812 times)
Online Hilltop366
Re: Did something dumb today.
« Reply #460 on: November 25, 2019, 05:36:14 PM »
I did the same thing with my bush hog only it was high tensile electric fence wire, can't cut it with regular wire cutters or linemen players very easily ..... cutting torch to the rescue.
Offline breederman
  • getting by the best way I know how
« Reply #461 on: November 25, 2019, 06:14:41 PM »
It doesn't take long to wrap about a half mile of electric fence wire around a hay tedder. It takes much longer to cut it out.🙄
Together we got this !
Offline donbj
« Reply #462 on: November 26, 2019, 12:14:38 AM »
Banjo, you are probably correct. I have to think the manufacturer included a drive shaft with a slip clutch instead of a shear bolt for a reason. It does require quite a bit of torque to get it moving, so I'll have to consider carefully before I decide to switch the drive shaft I have for one with a shear bolt.
The slip clutch is a great driveline/gearbox protector. No need to change it at all, just make sure it is operating as it should. Don't overtension it.
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065
Offline Old Greenhorn
« Reply #463 on: November 26, 2019, 12:25:34 PM »
A new entry:
 I can't say who, but somebody in my household that was not me saw one of my work jackets hanging on the back of my chair and thought it looked like it needed washing, which was nice. They threw it in the washer, then dryer.
 When I inquired as to the location of said jacket, the good Samaritan handed me a freshly laundered jacket and I thanked her for doing that for me. Then I realized the pockets felt kind of full. Wow, I said, "you even put all my stuff back in the right pockets, that's amazing". She said 'pockets?' Turns out not only was the jacket cleaned but so were my gloves, pencils, a rag, and my moisture meter. So I just ordered another cheap moisture meter last night. Try as I might I can't get this one working again. Too many corroded little electronical buggy things on the PC board to make any sense out of it. Oh well...... ;D :D :-[
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Online doc henderson
« Reply #464 on: November 26, 2019, 12:37:28 PM »
prob. never work again, but take out the batts open it up, and plunk it into a bowl of rice.  and if you wife makes stir fry, watch out for the probes!  that is funny,   :)
« Reply #465 on: November 26, 2019, 01:02:25 PM »
Did all that and more Doc, no go. It's gone. The backlight works, but nothing else. The detergent really did a number on those small surface mount components and IC's on the board. Just all fuzzy green stuff. It's gone.
Offline Southside
« Reply #466 on: November 26, 2019, 02:32:26 PM »
I had a favorite wool watch cap that fit just right, which is a real pain to find when your noggin is shaped like mine.  One day I went to put that on and "what the heck?"  It was about half the size it used to be, but all nice and clean and dry.....early on in the marriage, so we had a discussion about wool outer garments and proactively about my cast iron cook skillets and dutch ovens in order to avoid any other incidents... ::)
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #467 on: November 26, 2019, 03:48:33 PM »
Bet it overdosed in the high-moisture environment, then it pegged out again in the dryer by changing directions too fast!  ;D
But, it was a way to get a new moisture meter without an argument!  :)
~Chuck~
1995 Wood-Mizer LT40HDG25 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Oliver05262
« Reply #468 on: November 26, 2019, 04:43:29 PM »
K-guy, commo wire is pretty tough stuff, too. Also it comes on pretty long reels.................
"You can't do wrong by doing good"
It's OK to cry.
Offline Oliver05262
« Reply #469 on: November 29, 2019, 10:04:42 PM »
 Of course, I would be the next one who played "el Estupido"...............
 What do you tell your kid when you give him or her a knife to cut something? "Now don't cut towards yourself".
 cue the warning bells. Red lights blinking. What could go wrong? And I put a new blade in the folding sheetrock knife last night.
stupid stupid STUPID  STUPID
Here we are 5 stitches later. And I got to see the inside of the new Pownal clinic set up by Southwest Vermont Medical Center and met some really nice, professional people who took great care of me.
It's OK to cry.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #470 on: November 30, 2019, 02:56:46 AM »
At least itís your left hand.  Thatís the only good news I see here. Probably stung like a bugger.
Save a farm today or starve tomorrow.
« Reply #471 on: November 30, 2019, 06:09:45 AM »
That's a bummer Oliver. Now it looks like you are only down to three. (sorry, I couldn't resist)
 At least it was a sharp knife, dull would have been much more painful.
 Heal up quick.
« Reply #472 on: November 30, 2019, 06:56:52 AM »
did it last week.  we had the power damaged to the shop 2 years ago with an ice storm and a neighbors tree branch that fell on overhead wires.  bent the mast, ogled the rubber seal, had to retention the wires to get me by. the stars aligned and a friend had 50 feet of 3 inch conduit, I had time off, so my son and I began placing the conduit. 130 feet pole to meter can.  got a 1/4 inch rope to pull the wires.  stretched it out to paint a line.  My son rolled it up and thought he put it in the shop.  dug and placed the pipe.  blew the fishing line and cotton ball through the pipe to pull the rope.  where was the rope?  my son thought he put it in the shop, but where?  decided it must be under the dirt, so with the back hoe, raked some dirt around thinking I would snag it.  needed a little dirt on the pipe anyway.  may place a 1 inch conduit 18 inches above the power line for cable.  next day.  looked in the shop again.  put a bucket on and moved most of the remaining dirt into piles.  "Wil where did you put the rope?".  " I do not remember".  poor guy. so after moving nearly all the dirt, I told him after class the next day to stop by Lowes and pick up another 36 dollar 150 foot bundle of rope.  he went inside.  the last place I saw it was on a pallet of old fence posts.  was parking the skid steer and as I crossed the trench, picked up one more scoop of dirt at the very end by the pallet,  there it was.
he did coil it up nice.  now have underground 4-0 ice proof electric service to the shop.
Offline Nebraska
  • I'm new! Lurked for quite a while, learning !
« Reply #473 on: November 30, 2019, 07:49:04 AM »
First thing I ever put sutures was my veterinarian fathers thumb when he had a little accident involving scalpel and a calf,  I think I was 12.
I forgot my log tongs and lifting straps were in the loader bucket the other day when I went to get a scoop of asphalt grindings, some how while the tractor was warming up I remembered to check the bucket..,
Never leave bright orange or hot pink livestock marking paint stick in your coveralls pocket....There's a reason there are two sets of Laundry equipment in the house,,,, ::)
Offline breederman
« Reply #474 on: November 30, 2019, 03:40:01 PM »
Orange paint sticks in the dryer do not make momma happy!.....so I have heard . Lol
Offline sawguy21
« Reply #475 on: November 30, 2019, 07:57:57 PM »
 :D :D I'm sorry, that is just to funny.
Offline Nebraska
« Reply #476 on: November 30, 2019, 09:29:16 PM »
It's very  much like the song lyric about crayons melting in a Maytag dryer.
Offline Southside
« Reply #477 on: November 30, 2019, 11:41:57 PM »
Yea - a pump bottle of Blue Kote left in a jacket pocket has the same spouse inciting effect..... ::)
i pulled a dumb-dumb...
Started by Dan_Shade on Health and Safety
Last post August 06, 2005, 06:10:46 AM
by sawguy21
How dumb can I be? VERY!
Started by tmbrcruiser on Sawmills and Milling
Last post April 14, 2017, 09:22:37 PM
by Magicman
I'm such a Dumb---
Started by jargo432 on Firewood and Wood Heating
Last post March 10, 2016, 06:43:15 PM
by jargo432
Was this dumb?
Started by biziedizie on Sawmills and Milling
Last post March 25, 2003, 01:01:32 PM
by biziedizie
