Tally-I/O
Author Topic: Drying Gun Stock Material  (Read 339 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
« on: February 27, 2019, 06:12:24 AM »
I have a few nice crotch walnut logs that are around 2feet in length, With some help from some plywood and my small jig I can still saw them on my LT35. Since these are short slabs I was thinking of sawing them into 12/4 for future gun stocks. What is the best practice for air drying short material like this?
I will deal with trying to dry it in my kiln later on down the road which is another topic probably on placement of the stock.
 I was thinking maybe a short stickered stack in the corner of my barn and forget about it? Just seeing what others do when drying gun stocks. This will be my first attempt at sawing them.
Sawyer/Woodworker/Timber Harvester
W/M LT40HD, W/M KD150 Dehumidification Kiln Mahindra 4550, BMS 250 Sharpener, BMT 150 Setter, MS880 chainsaw mill,
outofthewoods
Youtube page
Out of the
Offline doc henderson
Re: Drying Gun Stock Material
« Reply #1 on: February 27, 2019, 06:42:38 AM »
My question is do you need to create a buffer so it is not so much dryer on the surface, such as some burlap or cardboard.  I have got lucky with 12/4 walnut doing as you have stated and just letting it happen.  has the wood been sealed on the ends?  are the logs green or been air drying for awhile?  sorry more questions than answers.
these are flitches.  I have a big crotch log and I am sure the grain patterns we are looking for in crotch wood, will make the drying more complex.  @GeneWengert-WoodDoc
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: February 27, 2019, 07:38:20 AM »
I have issues with small cracks in the crotch.  That would ruin them for gun stocks.  You are going to have to keep the drying slow.  A vacuum kiln would be nice.
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
« Reply #3 on: February 27, 2019, 09:19:57 AM »
Try to anticipate where the highly figured target wood will be, stay away from the pith when milling.
Dry the pieces in a moist, damp place, if you have one.  I have a very damp, dark, condensing, gravel floored barn that I use for these types of pieces.  High humidity helps reduce drying rate.
I would apply some Anchorseal on the face of the crotch area as well as the ends.  Short pieces will really try to dry too fast.  Anchorseal is your friend.
Sometimes, crotch wood just cracks.
HobbyHardwoodAlabama.com
Cutting Gun Stock Material
Started by DR_Buck on Sawmills and Milling
Last post February 06, 2013, 02:58:53 AM
by drobertson
Peg material
Started by DWM II on Timber Framing/Log construction
Last post March 21, 2008, 09:12:16 PM
by peter nap
log bed material
Started by bedway on Wanted
Last post December 06, 2006, 08:36:03 PM
by 4woody
Peg Material
Started by S.Hyland on Timber Framing/Log construction
Last post March 04, 2014, 05:16:56 PM
by Tom King
