Author Topic: Woodmizer Setworks for parts  (Read 1365 times)
Offline PAmizerman
  • Just Another Day In Paradise!!
    • Byrne Millwork
« on: March 05, 2019, 08:24:42 PM »
I have read, understand, and agree to the terms of posting an ad on the Forestry Forum.
I have a setworks system off my 01 lt40 super. The err code says It has a bad module.
Woodmizer no longer sales parts for the setworks. I upgraded to accuset 2. I believe it cost me about $3000 to upgrade.
If interested in it for parts make me an offer on it.
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline LeeB
Re: Woodmizer Setworks for parts
« Reply #1 on: March 06, 2019, 10:41:57 AM »
Mine reads the same code. Don't guess it will help me any.
Offline PAmizerman
    • Byrne Millwork
« Reply #2 on: March 06, 2019, 11:43:46 AM »
@LeeB there are actually 4 modules that the system consists of. I believe they are all identical. I think I have 3 good and one bad but not sure. Give woodmizer a call to see what they say
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline LeeB
« Reply #3 on: March 06, 2019, 12:19:49 PM »
I need to go look at mine. Yours seems to have a lot less stuff under there than I remember mine having.
Offline PAmizerman
    • Byrne Millwork
« Reply #4 on: March 06, 2019, 02:18:30 PM »
Just checked. Here is everything I have.
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline LeeB
« Reply #5 on: March 06, 2019, 06:03:13 PM »
That looks a little more like it.  :D
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #6 on: March 07, 2019, 09:37:55 AM »
If it is the circuit board, I found one on line but not for a WM by googling the part #if it has one.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline LeeB
« Reply #7 on: March 08, 2019, 09:46:32 AM »
Rick with WM sent me the procedure for testing the mosfit boards. Seems I have three out of four bad. No idea what crapped three at once.
Offline barbender
« Reply #8 on: March 08, 2019, 11:34:15 AM »
Do you have the rotary encoder as well?
Offline PAmizerman
    • Byrne Millwork
« Reply #9 on: March 09, 2019, 05:36:59 PM »
@LeeB forwarded me the info on how to check the modules. All of my modules are bad. Sorry
If anyone is interested in any of the other parts and wants to get in contact with WM and see if there are test procedures to test any of the other parts you could forward me the email and I would be happy to test them.
@JB Griffin
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Offline LeeB
« Reply #10 on: March 09, 2019, 06:29:00 PM »
That's a bummer. I was hoping to be able to get mine going again.
Offline PAmizerman
    • Byrne Millwork
« Reply #11 on: March 09, 2019, 07:50:38 PM »
I was hoping to be able to sell it :D
byrnemillwork.com
WM bms250 sharpener
WM bmt250 setter
Woodmizer simple setworks used parts
Started by ftwjr on Wanted
Last post March 28, 2011, 09:06:02 PM
by ftwjr
moved
MOVED: Woodmizer simple setworks used parts
Started by Tom on Sawmills and Milling
Last post February 26, 2011, 09:44:16 PM
by Tom
setworks for my woodmizer
Started by DansSawmill on Sawmills and Milling
Last post July 28, 2006, 12:54:10 PM
by DansSawmill
Woodmizer setworks issue
Started by JustinW_NZ on Sawmills and Milling
Last post September 26, 2012, 09:35:43 AM
by sparks
