Author Topic: SKILSAW 16" Sasquatch worm drive feedback?  (Read 406 times)
Offline AMB30518
  • I really enjoy your forum!
« on: March 08, 2019, 12:57:05 PM »
Hello everyone. I've been away from the site for 6-7 years other than dropping occasionally.
I plan to build a retirement timberframe cabin next year, since I recently retired.
Can anyone give feedback on the SKILSAW 16" Beam saw?
I'm considering getting one.
I have an older Makita 16" but not crazy about the base on it, although it does ok for non critical cuts. I just ordered a new Diablo blade for it..
I'd appreciate any feedback.
Aaron
I did some chainsaw milling, learning sketchup & timber framing for home projects but not an expert..... I learn as I go and go as I learn.
Aaron
Offline Tom King
    • HistoricHousePreservation
Re: SKILSAW 16" Sasquatch worm drive feedback?
« Reply #1 on: March 08, 2019, 04:50:28 PM »
I don't know anything about the Skil, but I put an Oshlun blade on the Makita, that I've had for over thirty years, and it's the best cutting blade that's ever been on it.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #2 on: March 09, 2019, 12:20:41 AM »
Seems the big timber framing outfits are giving the Skil very positive reviews. I have not used one, but I agree that the Makita base seems a little dinky sometimes. That being said, I always check the saw before a critical cut and have had good luck with that. If you get one please leet us know how it performs.
Offline hrees
  • Member*
« Reply #3 on: March 12, 2019, 10:40:57 AM »
My dad and I got one last year for a timber frame lumber drying shed we are building. Very heavy duty, the base is magnesium, and motor is very powerful. Also comes with a nice plastic base that it sits and latches into so you can easily store it. Cuts through 6x6 beams with ease and square every time. Haven't used it to cut anything bigger but I would assume it would have no problem as the cut capacity is 6-1/4". We have also used it to square up some 4 inch thick cherry slabs roughly 7 feet long to be used for fireplace mantles. I love it and have no problem recommending it if you have and are willing to spend the money on one. It's actually cheaper than the Makita at the moment as well.
Online TimFromNB
  • New guy here.
« Reply #4 on: March 13, 2019, 09:14:09 PM »
Actually ordered one this week - it was priced down slightly on amazon.ca. Should be getting it tomorrow. I've been watching the price since September and it was at its lowest since. The 10 1/4" is also about $160 cheaper than it has been for the longest time...even cheaper than on amazon.com with the exchange rate.
Offline AMB30518
« Reply #5 on: Yesterday at 07:55:13 PM »
I appreciate all the feedback!
I put the new Diablo blade on the old Makita today after seeing the loose screw for the guard cushion, which was under the blade.
Sure cuts better now and I double checked the 90% to the narrow base.
Tom, I may try the Oshlun for my next new blade.
Flyingsparks, will do.
Hrees, thanks for your review and feedback!
TimFromNB, did you get your 16" SKILSAW yet and try it out?
I'm thinking about ordering it in a couple of days.
Thanks again for the feedback everyone ....
Aaron
Aaron
Online TimFromNB
  • New guy here.
« Reply #6 on: Today at 05:47:25 PM »
I received it and tried a few cuts. Cuts mostly square but it's a big saw to handle. I am seeing improvements in my cuts as I get used to it. I will most likely stay away from the line 1/16th then clean it up with a chisel. I think it will be quite useful in the long run.
Worm Drive Saws
Started by Solomon on Timber Framing/Log construction
Last post February 20, 2014, 11:15:08 AM
by giant splinter
That white grease on the worm drive
Started by ChrisN on Chainsaws
Last post November 14, 2004, 01:58:21 PM
by SasquatchMan
Worm drive chainsaw milling attachment
Started by Roland on Sawmills and Milling
Last post September 29, 2018, 10:18:13 PM
by mike_belben
small mouth are just killing the 6" watermelon worm!
Started by drobertson on The Outdoor Board
Last post August 15, 2012, 07:46:42 PM
by drobertson
